Old 07-02-2004, 03:29 AM   #5926
How many shims etc are you running in your rear diff chris?
Mine is just getting annoying with the rear diff jumping teeth on the bevel after a couple of runs
Rich_p is offline   Reply With Quote
Old 07-02-2004, 03:47 AM   #5927
pro4_chris's Avatar
im running 1 std and 1 copper shim on the end furthest away from the bevel gear and 1 std shim on the other end. this seems to work pretty well for me.
hope this helps
chris
pro4_chris is offline   Reply With Quote
Old 07-02-2004, 03:51 AM   #5928
Cheers, I am only running one each side so i'll try adding one where you suggest
Old 07-02-2004, 04:12 AM   #5929
VenomWorldOrder's Avatar
hopefully the new gears solve the issue. funny how i moved from evo3 surikarn to pro4 for gear issues, now it's the other end giving people woes!
can't you just copy the associated tc3 gear design?
i got 10 sets of 1.1's comming!
VenomWorldOrder is offline   Reply With Quote
Old 07-02-2004, 04:17 AM   #5930
Maybe but the gears are not actually breaking, I havnt broken any yet, the diff and bevel just seem to go out of line really easily and start skipping.
Old 07-02-2004, 04:22 AM   #5931
hope this helps
chris
if possible can people do a small "windows paint" picture to describe were they place the shims. all the descriptions i read are hard to understand just makes it easier for all of us.
here is my setup copied from someone at the track haven't tested it yet but they don't seem to have issues;
Old 07-02-2004, 06:07 AM   #5932
JohnA's Avatar
Originally posted by Pit-racer
75t 48p thanks. u running stock or mod? Also do you guys put a piece of tape or something to cover the bottom of the chassis, under the spur?
The hole under the spur allows small stones to drop back out, taping up the hole would make matters worse as the majority of debris comes off the wheels, not through the hole.
JohnA is offline   Reply With Quote
Old 07-02-2004, 06:26 AM   #5933
kewdawg's Avatar
I guess I missed the boat, but... Where can I get the heat sink Hara is using on his motors (Not the Motor heat sink)? I saw it on Hpi's website, Reedy Race pics. Any help?
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 07-02-2004, 08:46 AM   #5934
Erik Shauver's Avatar
kewdawg: This is the heatsink that is seen throughout the site.
Erik Shauver is offline   Reply With Quote
Old 07-02-2004, 08:54 AM   #5935
rc-zombies's Avatar
Originally posted by Entropy
The Twister is a KO VFS.
identical
Old 07-02-2004, 09:02 AM   #5936
pro4_chris's Avatar
3 racing also do a pretty good heatsink
www.3racing.com.hk and they do them in loadz of colours too
Old 07-02-2004, 09:29 AM   #5937
Frank McKinney's Avatar
Default RE: Shimming
I just use the same shimming from the current version of the manual. I've busted up some of the ring gears on the one-way on tracks with tough barriers but those were the early version gears. In fact, when taking apart my gearboxes I've forgotten where the input shaft spacers go, I've just put them back where ever and haven't had a problem with them.
Minimal signature to save screen space! Big sigs suX0r
Frank McKinney is offline   Reply With Quote
Old 07-02-2004, 09:45 AM   #5938
Pit-racer's Avatar
Thanks, I just needed to know.
www.igthobbies.com / Serpent Cobra GT / 748 TQ / Serpent Eryx 3.0 / Desoto Racing / Veytrex.com / JZRacing / Flo-Control
Pit-racer is offline   Reply With Quote
Old 07-02-2004, 09:49 AM   #5939
Pit-racer's Avatar
Default Re: RE: Shimming
How do we know if we got a new version or an old?
Old 07-02-2004, 12:41 PM   #5940
Registered User
When you open the box.
Aku-Man is offline   Reply With Quote
