Hpi Pro 4
#5913
I race stock but primarily 540 motors. I usually run a 72T spur.
I dont cover the bottom. Ive never had a need to and i'd think air flow in that areas is a good thing not a bad thing.
Cheers,
Mossie
Cheers,
Mossie
#5914
What is the standard spur gear type? I will need to get some tomorrow morning as my car should be here early next week. What size spur and pinion should I run with a stock motor, a 540, a sport tuned tamiya and a 14x2 does anyone know?
#5915
540 - 70T spur 44 rollout
Stock - 72T spur 28 rollout
ohers i dont know.
You can calculate pinion sizes from www.rollout.com
These are just estimates and will change depending on tracks.
Im pretty sure all spurs fit.
Hope this helps.
cheers,
Mossie
ohers i dont know.
Hope this helps.
cheers,
Mossie
#5916
Thanks Mossie
I havent got the Pro4 yet, and i dont know if i will get any pinions with it. I only have the .06 module ones for my TA04S tamiya, so i want to go get a few for the Pro4 tomorrow, but I dont know what pitch to get either, what is the pitch of the standard spur?
#5918
it says the domain name is for sale?
#5919
standard spur is 64P. The Pro4 doesnt come with any pinions. I swapped to 64P cos I was forever stripping spurs. Where I race its a little bit bumpy so 48P is more efficient.
Sorry Pit racer my apologies I gave the wrong address www.gearchart.com
Cheers,
Mossie
Cheers,
Mossie
#5920
Originally posted by rc-zombies
Don't know..here's the specs to the Twister..
http://www.hotbodiesonline.net/04reedyrace.html
I've had very bad experience with the quantums...mine went up in smoke after 2 runs... will never buy one again. I've had my twister since the Pro4 was released...and not a single problem. I also have the handheld setting adapter as well as the PC adapter... you can program different frequencies in 32 steps.
mine poofed out of the package, then after being rebuilt, it poofed again after a couple runs - it would poof smoke out proportional to the amount of throttle given.
I paid $30+ to have it fixed the second time, the first time I sent it back with Mike Reedy after the Novak race. It works now, thus far.
#5921
Originally posted by X-Garage
RC-Zombies
Does this Twister Speed Control has the same spec. as Quantum 2?
RC-Zombies
#5922
Originally posted by pro4_chris
hi Rich_p: have you got the newer copper shims
Z891 WASHER 10x12x0.1mm (COPPER/10pcs)
No I hadnt seen those, do they make a differance?
Are they any think or are they just less likely to kink like the standard ones can do?
#5923
Registered User
#5924
Originally posted by Aku-Man
Newer kit come with updated manual and that new copper shim.
#5925
No I hadnt seen those, do they make a differance? Are they any think or are they just less likely to kink like the standard ones can do?
