Hpi Pro 4
#5806
Yeah thats the ones I was thinking of, I'll have a play about with those. Many thanks.
Is it worth replacing the gears just incase though?
#5807
If there is visible wear or stress, I would.
#5808
A temporary fix would be a drop of medium or thin CA around the nut, to help hold it in place. You'd be better off with new T-nut part and then CAing the nut in that, though.
#5809
Well I just installed my new HPI heatsink motor mount and all I can say is...
Who designed this damn thing? Now I have to put the pinion on and take the pinion off before installing and removing the motor. Arrrrggghhh!!!! Unless of course I run mod and/or binary stock motors with a 27T or less pinion. Something tells me this is gonna be more hassle than it's worth. Especially for me since I swap motors constantly while running Stock and 19T at my local club races.
#5810
At least it looks nice.
#5811
You have to take the pinion off at some point….correct?
#5815
Re: Re: HPI motor heatsink...
Originally posted by JDM_DOHC_SiR
You mean this one
-Dave
You mean this one
-Dave
for the rear aluminum hubs. is it better to use titanium ball ends to fasten the turnbuckles. or the stock ones is good enough?
#5816
Re: Re: Re: HPI motor heatsink...
Originally posted by racer
JDM_DOHC_SiR,
JDM_DOHC_SiR,
-Dave
#5817
Re: Re: Re: Re: HPI motor heatsink...
I use the Ti ones but the Stocks ones work just fine... but I did snap on off at the base before( steel )
-Dave
-Dave
btw...i sent you a PM regarding another issue.
#5819
Originally posted by Thad Garner
Hassle
Hassle
