Old 06-21-2004, 01:00 PM   #5701
Michal101's Avatar
Originally posted by RCBuddha
Venom,
I tried various solutions to the problem, but i've concluded that its the arrangements of the diff parts (i.e, having the spring on the same side as the thrust bearing) is a design that cannot keep its settings. Period.
Did I try the AE spring and nut combo? Yes. Did it still loosen? Yes. Was the diff loosening to a point where its noticeable? A little. Did I wanna keep trying to make something work? Why bother?
I had the same problems with my plastic AE diffs and my SD diffs. I've asked numerous times for SOME explanation of why HPI decided to go with the design; with NO answer...
Erik Shauver,
Care to explain why that design was chosen?
My best recommendation is to keep the diff as tight as possible without locking it up completely. The downside is that you'll have to keep tightening after every run.
Buddha,
I must be one of the lucky ones since the only thing that I did was use the AE diff spring when I assembled it and the diff has stayed nice and tight yet smooth and I have raced the car approximately 5 or 6 race days.
I did, however, use the Accer ceramic diff balls, but I do not think that would be why the diff is staying tight.
Just food for thought.
Mike
(Team Driver)
R/C America
Team Tekin
ProMatch
Parma
Michal101 is offline   Reply With Quote
Old 06-21-2004, 03:51 PM   #5702
TeamPRP's Avatar
For those interested in our HTS racing chassis kit, our special offer ends June 30th. Check out our site or our Team PRP forum here on RC Tech if you are interested in checking it out.
Thanks guys!
B
TeamPRP is offline   Reply With Quote
Old 06-21-2004, 04:49 PM   #5703
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
With the diffs and and how they work loose....I have tried the Associated parts and they still loosen....the only fix is a little blue lock tite. Once I did this I never had them loosen up again.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 06-21-2004, 04:57 PM   #5704
JDM_DOHC_SiR's Avatar
Trader Rating: 30 (100%+)
This works great!! but also I have given the nut a little squeeze with a set of plyers to helps a little to
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64d
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 06-21-2004, 05:02 PM   #5705
DT-Skyline's Avatar
Send a message via AIM to DT-Skyline Send a message via Yahoo to DT-Skyline Send a message via Skype™ to DT-Skyline
I've been trying to drfit with my Pro 4 latly, and i've been using the Yokomo Drifting tires and rings, but it seems that every time i try to drift into a corner, i lose my torque and it also seems to slip too much in the in back. Help?
DT-Skyline is offline   Reply With Quote
Old 06-21-2004, 05:50 PM   #5706
Oasis's Avatar
Trader Rating: 36 (100%+)
Dave said nut and squeeze in the same sentence..
Oasis is offline   Reply With Quote
Old 06-21-2004, 06:00 PM   #5707
Dang I knew someone would catch that
-Dave
Old 06-21-2004, 06:09 PM   #5708
Even mentioned of pliers along with it.. ouch
wcoyote is offline   Reply With Quote
Old 06-21-2004, 06:11 PM   #5709
HuDy WiNnEr's Avatar
Send a message via AIM to HuDy WiNnEr
Default lol
jeez am I in the right thread? I thought this was the pro 4 thread haha jk
HuDy WiNnEr is offline   Reply With Quote
Old 06-21-2004, 06:46 PM   #5710
popsracer's Avatar
Default Woo-hoo!
Guys;
Finally got the Car working good.
Moving the Antenna to the upper deck really made a BIG difference in helping with the glitching problem.
The suspension changes that I made helped make the Car very drivable and it was a pleasure to drive for the first time.
2 comments:
1) The rear diff comes loose every run. I have to agree that I also believe that it is design related, as 'RCBuddha' has stated.
Really only a minor issue, but it would be nice to have 1 less thing to worry about on race day. I already have the AE parts and Loctite handy to help minimize the problem.
2) I also had some problems with the Steering not staying centered and realized that the Servo had moved after a few side impact from some other cars. My solution was to Shoe-Goo the servo to the chassis along with the Aluminum mounts (bling factor).
Thanks to everyone,
Steven
popsracer is offline   Reply With Quote
Old 06-21-2004, 10:02 PM   #5711
RCBuddha's Avatar
Trader Rating: 33 (100%+)
Thanks guys!
B
PRP,
Just a "thought" if I may. How about designing some diff outdrives that assemble the diffs like AE uses in their B4 and T4? I dont' think aluminum outdrives would be too much heavier, and if they are designed like this:
http://download.teamassociated.com/p...rawing_tc3.pdf
I think the diff setting won't come loose as badly. I can remember not having to reset my diffs as much on my RC10's when the diff was built like this.....
RCBuddha is offline   Reply With Quote
Old 06-21-2004, 10:50 PM   #5712
Hey Buddha,
Where have you been? I've been doing really well with the Pro4 at socal. Slim tried to move me up this last Sat. but I asked him not to, cause I don't think I can handle the extra minute yet. Hope to see you there soon.
Jei
jbackslash is offline   Reply With Quote
Old 06-21-2004, 10:56 PM   #5713
RCBuddha's Avatar
Originally posted by jbackslash
Hey Buddha,
Jei
YGPM Jei.....
Glad to hear your doing well, i was getting worried that the EVO was keeping you from the front of the pack....
Old 06-22-2004, 03:25 AM   #5714
raving-monkey's Avatar
Send a message via MSN to raving-monkey
i finally give in after not being able to get it running right for me.
so i decided to put it on ebay..here it is
http://cgi.ebay.co.uk/ws/eBayISAPI.d...905396524&rd=1
maybe one of you guys get get it running awesome, i guess it just wasnt made for me
raving-monkey is offline   Reply With Quote
Old 06-22-2004, 09:57 AM   #5715
JusBox's Avatar
what couldn't you get it to do?
JusBox is offline   Reply With Quote
SEO by vBSEO 3.5.0
