Old 06-20-2004, 07:02 PM   #5686
rc_square24's Avatar
WHY????
just why do u have to make a new brace when theres already a company who makes it??? huh?? atleast make sometihng that would work with the originals!! i just ordedered a few sets of gears from hk and now theyll be 1.1 gears.......darn it... what am i gonna do with the prp? i mean its a great brace but when the gears wear out.....itll be useless...
why why why???!!!
rc_square24 is offline   Reply With Quote
Old 06-20-2004, 07:32 PM   #5687
Thad Garner's Avatar
Originally posted by rc_square24
WHY????
just why do u have to make a new brace when theres already a company who makes it??? huh??The gear design was improved. atleast make sometihng that would work with the originals!!That would be a compromise in performance. i just ordedered a few sets of gears from hk and now theyll be 1.1 gears.......Most likely. darn it... what am i gonna do with the prp? i mean its a great brace but when the gears wear out.....itll be useless...I understand your frustration
Thad Garner is offline   Reply With Quote
Old 06-20-2004, 07:55 PM   #5688
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
WHY????
why why why???!!!
The HPI brace is not that pricey it's about half the price oof the PRP one about 5~6$ thats all
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 06-20-2004, 09:49 PM   #5689
RCBuddha's Avatar
Trader Rating: 33 (100%+)
Originally posted by VenomWorldOrder
i've found with my pro4 that the rear diff keeps loosening itself. i run a hacker 6T...is there a safe way to keep the diff a consistent tightness?
Venom,
I tried various solutions to the problem, but i've concluded that its the arrangements of the diff parts (i.e, having the spring on the same side as the thrust bearing) is a design that cannot keep its settings. Period.
Did I try the AE spring and nut combo? Yes. Did it still loosen? Yes. Was the diff loosening to a point where its noticeable? A little. Did I wanna keep trying to make something work? Why bother?
I had the same problems with my plastic AE diffs and my SD diffs. I've asked numerous times for SOME explanation of why HPI decided to go with the design; with NO answer...
Erik Shauver,
Care to explain why that design was chosen?
My best recommendation is to keep the diff as tight as possible without locking it up completely. The downside is that you'll have to keep tightening after every run.
RCBuddha is offline   Reply With Quote
Old 06-20-2004, 09:54 PM   #5690
Speed Demon's Avatar
Default KingCrab's custom 3mm chassis..
Did anybody tried the 3mm custom chassis made by Kingcrab???
I remember earkier in the thread there is a post regarding the chassis......
CUSTOM CRAWLER & ROCK STACKER
Speed Demon is offline   Reply With Quote
Old 06-21-2004, 12:48 AM   #5691
Registered User
Look what I found at Rainbow Ten:
3263432637888,ALEX RACING,1600YEN,PH-001 PRO4 TITANIUM COATING SHAFT 4Pcs.
Alex Racing make part for Pro4?
Aku-Man is offline   Reply With Quote
Old 06-21-2004, 01:05 AM   #5692
You would be surprised what ALEX is making for other cars now..they now make stuff for ...
HPI, Tamiya and AE
-Dave
Old 06-21-2004, 01:08 AM   #5693
Entropy's Avatar
What shaft is this?? the CVD shaft or universal shaft?? or something else??
Entropy is offline   Reply With Quote
Old 06-21-2004, 01:09 AM   #5694
Registered User
shock shaft.
Old 06-21-2004, 01:17 AM   #5695
shock shaft.
Yep..
But I`ll give you all a little heads up...it`s the same size as the Barracuda shock shafts
-Dave
Old 06-21-2004, 01:22 AM   #5696
Registered User
I'm using HB Pro3 Ti coating shafts. Its 0.3mm longer than stock. I think its ok, but HB shaft look thinner than stock shaft. The stock shaft look bit wider. Should I change?
Old 06-21-2004, 03:09 AM   #5697
VenomWorldOrder's Avatar
Originally posted by RCBuddha
Venom,
Erik Shauver,
thanks for the reply mate, i seem to always ask questions that very few people have answers for do you recon it's safe to drill a hole in the screw head side of the diff so it is easier to tighten?
VenomWorldOrder is offline   Reply With Quote
Old 06-21-2004, 08:08 AM   #5698
rc-zombies's Avatar
I measusured them...they are identical...
Old 06-21-2004, 11:05 AM   #5699
Registered User
Thanks, z
Old 06-21-2004, 11:34 AM   #5700
coastaltony's Avatar
I have not been able to
get my lap times down to where I was
while running the Axis, Mission Pro,
or xxxs.
I just got 1.0 & 1.5 pivot blocks, now I have 1.0, 1.5, 2.0 & 3.0.
I'm planning to remove the .5mm spacers front & rear, and install 2 C hubs.
Any suggestions on the blocks.
Or do I take one step at a time?
Like leave chassis alone, change to 2 rear, and 1.5 front blocks and see how it reacts.
Meucci pool cue collector
coastaltony is offline   Reply With Quote
