Like Tree6Likes
Old 06-18-2004, 02:30 PM   #5641
rc-zombies's Avatar
Originally posted by raving-monkey
currently, my car is roughly 20-30grans underweight (going by my mams scales).
the weight limit over here at BRCA events etc is 1500g.
i havent put any weight on mine.
but yet wouldnt it just be better for you to add stick on weights instead of buying this..imo pathetic...alluminium chubbys, hub carriers etc?
For serious racers..the stock parts are the best and you can add the extra weight where it's needed...basically on the electronic side... but for us immortals...or Hara wannabees... a little blink blink doesn't hurt....
Old 06-18-2004, 02:32 PM   #5642
X-Garage's Avatar
I want a used one.
X-Garage is offline   Reply With Quote
Old 06-18-2004, 02:33 PM   #5643
raving-monkey's Avatar
Send a message via MSN to raving-monkey
i'd rather drive a pro4..not a sherman tank
raving-monkey is offline   Reply With Quote
Old 06-18-2004, 02:36 PM   #5644
rc-zombies's Avatar
I know what you mean... the car is pretty much built like a tank..takes alot of abuse... I haven't broken the stock arms or hubs on it yet....
Old 06-18-2004, 02:55 PM   #5645
Registered User
I won't do it, if I have national skill. Those weight won't make me any more slower.
Aku-Man is offline   Reply With Quote
Old 06-18-2004, 03:25 PM   #5646
Trader Rating: 16 (100%+)
Originally posted by X-Garage
I want a used one.
Me too.....used one are still $230-250 range....stock.
Old 06-18-2004, 03:56 PM   #5647
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Thumbs up Version 1.1 gears
Hey Guys the new Gears are out along with HPI`s new Backing plate..( smaller than the PRP one but is heavier )
Have a look
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 06-18-2004, 04:10 PM   #5648
when are the new gears coming out...whenin the UK if anybody knows
Old 06-18-2004, 05:11 PM   #5649
tomdav's Avatar
Trader Rating: 42 (100%+)
Default ver 1.1
Are these a new material or design? I took some nice hits at last weeks regionals. One turned the front cvd into a pretzle. My gears are still working good though.
Tom
The Couve, WA
davesrctracks.net
tomdav is offline   Reply With Quote
Old 06-18-2004, 06:02 PM   #5650
rc_square24's Avatar
it saids 'new shape that endures crashes' on the sticker, donno about material
rc_square24 is offline   Reply With Quote
Old 06-18-2004, 06:03 PM   #5651
what are good springs to start on foam tires? carpet
Old 06-18-2004, 07:50 PM   #5652
Oasis's Avatar
Trader Rating: 36 (100%+)
The only problem I have ever had with aluminum parts has been with the front hubs,they will bend and it will change your camber and caster enough to make a change in the way your car handles.Then their is that sprung weight issue..and the fact that it's no better than the stock parts,plus you get to pay extra for your idea of the bling bling..to each his own..
Oasis is offline   Reply With Quote
Old 06-19-2004, 01:35 AM   #5653
Skill's Avatar
I am still running the stock springs on carpet with foams. What has also suprised me is that I can run the same shore tyres all round and get a good handling car, this is the first HPI which doesn't have inherrant oversteer.
I am soon to be getting some alloy hubs for the front, simply because I am breaking a steering block and C-hub about every 2 meetings. It's exactly the same thing that happens, I clip the inside of a fast sweeping corner and the bottom of the steering block breaks where the screw screws in, and this then forces the C-hub to break. I do like bling bling so I will be getting other bits too, but the front hubs are for durability, and they only cost at the most 3 times more than the stock parts, so if they are bent after 10 meetings I will have easily got my money worth.
The performance difference for a club racer like me will probably not be noticed with having a lot of alloy. Also, I like my car to have that individuality factor and I'm proud of how my car looks
Skill is offline   Reply With Quote
Old 06-19-2004, 01:39 AM   #5654
coastaltony's Avatar
Nothing wrong with a bit
of the bling factor.
Meucci pool cue collector
coastaltony is offline   Reply With Quote
Old 06-19-2004, 06:04 AM   #5655
RBLove's Avatar
Trader Rating: 72 (100%+)
I never got a reply to my last post. Why are arms and hubs not available in the USA? Every single part for the car is readily available for purchase from the LHS and Distributor's. Just seems odd everything is available and arms and hubs are backordered..............
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, BSR Racing Tires
RBLove is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
