Old 06-17-2004, 01:43 AM   #5596
Eirik's Avatar
Default Re: Re: HEATSINK MOTOR MOUNT
Originally posted by Skill
You have to position the motor so that the slot where the pinion screws onto is facing one of the slots of the motor mount. In other words, you can tighten it easily if you put the driver in one of the slots and line up the grub screw with that.
If you have understeer theres a couple of things you can do:
If on smooth surface lower the suspension mounts right down so they are against the chassis with no spacers (note: this changes the droop so you'll have to change that too)
Run with rear sway bar and no front sway bar.
Lay down the front shocks
Stand up the rear shocks.
Skill,
Did you lower both the front and rear suspension mounts to gain steering or only in the rear?
Could you please explain what your experience is with this tuning?
regards,
Eirik A
Eirik is offline   Reply With Quote
Old 06-17-2004, 07:59 AM   #5597
rc-zombies's Avatar
Originally posted by Entropy
An alternative is the Square heatsink motor mount, which is basically a finned version of the HPI one without the closed end and is probably lighter.
Too late...already have the HPI one.. I thought about getting the square version when they came out...
yea I did that..but the hex shaft is still to large to really get good alignment.... I may have to just machine out a larger slot...or get a thinner hex wrench.
Old 06-17-2004, 08:00 AM   #5598
Frank McKinney's Avatar
You'll want the slight bit of extra weight on the motor side anyway, if you use tape to hold the batteries in.
Zombies - what "ends tonight?" I'm been curious about that.
Minimal signature to save screen space! Big sigs suX0r
Frank McKinney is offline   Reply With Quote
Old 06-17-2004, 08:06 AM   #5599
rc-zombies's Avatar
That's old....American Idol contestant that should have been booted out many weeks before the finals...
I'll have to change that avitar soon....
Old 06-17-2004, 08:13 AM   #5600
some old-school avatars: http://www.frankmckinney.org/random/avatars.htm
Old 06-17-2004, 08:15 AM   #5601
rc-zombies's Avatar
Old 06-17-2004, 08:27 AM   #5602
rod_b's Avatar
Send a message via AIM to rod_b
LMAO
I'd use one except you don't have any filipino/asian pics. I like the male teacher from 1985 though. Reminds me of this guy that used to feed birds at my local park. LOL
rod_b is offline   Reply With Quote
Old 06-17-2004, 08:39 AM   #5603
rc-zombies's Avatar
Originally posted by rod_b
LMAO
You can use this one....
Old 06-17-2004, 10:54 AM   #5604
lazyboy's Avatar
Send a message via AIM to lazyboy
could someone help me?
i was at the track yesturday doing some testing with my pro4 and i noticed it had the biggest off-power push going into the corner. i add some droop to the rear and they helped a little bit, even when i run no tire-compond on my tires i still get the push on cold tires, so does anyone have any suggestions to getting ride on this problem,
BTW: my car is on the stk setup for the most part
lazyboy
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 06-17-2004, 11:18 AM   #5605
rod_b's Avatar
What is the track condition? Try 2* or 4* c-hubs.
Old 06-17-2004, 11:29 AM   #5606
rod_b's Avatar
How do I look?!
Old 06-17-2004, 11:37 AM   #5607
rc-zombies's Avatar
How do I look?!
Lookin' good!
Old 06-17-2004, 11:38 AM   #5608
lazy,
what tires do you have on the car? that may be a part of it too. it sounds like the fronts dont bite until you get heat in them...
just a thought
thanks eirik. i'll give that a try
punkboy is offline   Reply With Quote
Old 06-17-2004, 11:49 AM   #5609
Skill's Avatar
Default Re: Re: Re: HEATSINK MOTOR MOUNT
Originally posted by Eirik
Skill,
I was experiencing understeer in the initial turn-in. A couple of other guys at my club were running Pro 4's and were running both front and rear suspension mounts without any spacers. This seemed to get the back end to come out a little on the turn in and made the car much more driveable.
However, I'm sure you could get even more of an effect by only lowering either the front or rear, one way will give you more grip and the other less but I'm not sure which way around it goes.
I find the setup tips in the manual very helpful to find out what things do, the first thing I would try is to run the standard rear sway bar but not the front one.
Skill is offline   Reply With Quote
Old 06-17-2004, 03:25 PM   #5610
Good ones there
I've been wanting to update my avatars page...the ones I have on there now need to be enlarged and I found all of them in about 10 minutes. It took longer to edit and upload them.
Anyway, enough of little ol' getting-off-topic me, back to your regularly scheduled program.
