Like Tree6Likes
Old 06-16-2004, 08:10 AM   #5566
StewartFan20's Avatar
Default HPI Shocks
Has anyone tried other brands of shocks on the Pro4? Just wondering if another manufaturers shocks will fit/work.
StewartFan20 is offline   Reply With Quote
Old 06-16-2004, 08:17 AM   #5567
coastaltony's Avatar
I developed a glitch last week. After changing everything, I ended up with Airtronics receiver on top of top deck, and antenna mounted like Ray's.
Meucci pool cue collector
coastaltony is offline   Reply With Quote
Old 06-16-2004, 08:50 AM   #5568
Regional Moderator
Darkseid's Avatar
Default Glitch
I think my 'glitch' was because I had something stuck in my right rear outdrive. Every once in a while it would get caught between the outdrive slot and the diff case and cause the car to make a hard right turn. So I thought it was glitching. I think my motor was also due for a rebuild.
Since I've removed the obstruction from the diff outdrive and changed motors, I've had no glitching problem. Knock on wood...
TLR 22...Tamiya F104...
Old 06-16-2004, 09:06 AM   #5569
rc-zombies's Avatar
Default Re: HPI Shocks
others will work...but why would you want to? the stock shocks are very smooth already..
Old 06-16-2004, 09:07 AM   #5570
rc-zombies's Avatar
Originally posted by rc_square24
guys...which outdrives/diff halves other than the pro4 ones will fit for a diff cuz ill need one for carpet and i cant get the hold of one.
i have a ring gear and everything but just the halves
will tc3 ones work?
you do not want to mix apples and oranges...they will not work.
Old 06-16-2004, 09:13 AM   #5571
After further
investigation I came up with this. Two
of my P2K Pro motors had a cracked
diode in them.
I popped a NEW Epic in
, after 300 sec. of 3v break in, and
BINGO.
Old 06-16-2004, 10:21 AM   #5572
speedxl's Avatar
R/C Tech Charter Subscriber
hey coastal i need a body you coming to coralspring to night!
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 06-16-2004, 10:23 AM   #5573
John Tag's Avatar
Trader Rating: 42 (100%+)
Hey guys sorry im laxy and dont have time to read back about40 or so posts, but heres my question. Whats the deal with 28mm foam tires do they fit? ,I herad someone say they hit the shocks or something.Well ive been running the tc3 but i wanted a change and the pro4 sounds great.I run a lot of stock racing and it sounds like the pro4 has a super free drivetrain so im in. yhx in advance.
John Tag is offline   Reply With Quote
Old 06-16-2004, 10:34 AM   #5574
RCBuddha's Avatar
Trader Rating: 35 (100%+)
Originally posted by S15Racer
Hey guys I'm in a bit of a predicament here. The kit comes in tomorrow, and I dont have a tap. I looked all over the place today and no one around here has a stupid 3mm tap! I found 4mm taps, 5mm, 40 peice sets with a 3mm, but not just an individual 3mm. My question is, well actually I have 2. First of all, do I really need a tap? If I just put some muscle behind it could I manage without one? And second, is there a standard sized equivelent that I could use instead? Cause I do have access to a set of standard sized taps that might work, but Im not positive.
I HIGHLY recommend using a 3mm tap, it will make building the kit A HECK of ALOT easier. Yes, you have to be very careful, you need to make sure that you tap straight and with a little grease on the tap threads. I would say to try and locate a tap, b/c the hex can get stripped out when too much force is applied to turn the screw (as when you are building w/o tapping).
I don't think there is a standard sized equivalent....for more tips see this link:
Hpi Pro 4
RCBuddha is offline   Reply With Quote
Old 06-16-2004, 10:38 AM   #5575
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Default GT 7
Here is how I have my car wired up.....
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 06-16-2004, 10:42 AM   #5576
Hector, YGM
Old 06-16-2004, 01:48 PM   #5577
crazy4rc's Avatar
Default Pro4 with Tobee & Square Hopups
I finaly rebuild my Pro4 with Tobee and Square Stuff.
crazy4rc is offline   Reply With Quote
Old 06-16-2004, 01:55 PM   #5578
crazy4rc's Avatar
Here is the one.
Old 06-16-2004, 01:55 PM   #5579
crazy4rc's Avatar
And another one.
Old 06-16-2004, 01:57 PM   #5580
crazy4rc's Avatar
Sorry. i hit the wrong button...
