Like Tree6Likes
Old 06-15-2004, 09:14 PM   #5551
popsracer's Avatar
Default Glitching Problems
Guys;
Just want to thank you all for your suggestions.
I specifically bought the Pro-4 to run in Stock because of the free drivetrains that shaft cars are famous for.
Will let everyone know how it goes after this weekend.
Thanks again,
Steven
popsracer is offline   Reply With Quote
Old 06-15-2004, 09:21 PM   #5552
coastaltony's Avatar
Cool, keep us
informed. I switched to 100t spur, and
have been going back & forth with 34,
35, & 36t pinion depending on which
Monster stock I run. Hope this
helps.
Meucci pool cue collector
coastaltony is offline   Reply With Quote
Old 06-15-2004, 09:37 PM   #5553
rod_b's Avatar
Send a message via AIM to rod_b
Originally posted by RBLove
Any news on arms and hubs becoming available in the "U.S."??
My LHS had 3 sets of arms and 2 sets of hubs that I asked him to order for me. Of course he shows them to me a day after my order from rcmodel came in. I may pick them up anyway.
rod_b is offline   Reply With Quote
Old 06-15-2004, 09:37 PM   #5554
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Originally posted by coastaltony
Cool, keep us
helps.
I ran pretty close to the same pinion setup as you are running with the monster motors.
ST Racing Concepts (STRC)
Old 06-15-2004, 10:00 PM   #5555
Send a message via Yahoo to Doug Gaut
S15Racer,
We decided that with a 60% chance of storms we would go south to Enid instead. The thought of driving over 3 hours for a possible rained out race didnt settle with me or the other guys. Sorry, I wish we had went ahead and came up now!!
Doug Gaut is offline   Reply With Quote
Old 06-15-2004, 10:25 PM   #5556
rc-zombies's Avatar
S15racer
no tap needed... if you have an electric variable speed drill and a 2mm hex you can use that and it will be faster and saves your wrist from getting sore...just make sure you grease the threads...and go slowly with the drill...
Old 06-15-2004, 11:12 PM   #5557
rc_square24's Avatar
guys...which outdrives/diff halves other than the pro4 ones will fit for a diff cuz ill need one for carpet and i cant get the hold of one.
i have a ring gear and everything but just the halves
will tc3 ones work?
rc_square24 is offline   Reply With Quote
Old 06-16-2004, 01:29 AM   #5558
Mercury Racer's Avatar
Anybody noticed that the pro4 is lacking forward traction? it handles great, but im always getting beaten off the line.
Mercury Racer is offline   Reply With Quote
Old 06-16-2004, 02:12 AM   #5559
Frank McKinney's Avatar
Try using the same final drive ratio and motor (winds/turns) as the guys that are beating you. You could have a slower reaction time also or your radio setup might be delaying the signal to the speedo. That's the first time I've heard something like that.
Minimal signature to save screen space! Big sigs suX0r
Frank McKinney is offline   Reply With Quote
Old 06-16-2004, 04:36 AM   #5560
at my track i don't have aproblem off the line it' s just a bad push changed springs will see what that does.
sportracer is offline   Reply With Quote
Old 06-16-2004, 05:04 AM   #5561
Default GT7
Has anyone used a GT7 in their Pro 4?
If so any picitures please of which way round you have mounted them?
I ask As I am about to purchase one and am worried sbout space issues, there doesnt seem much room even with a Novak Atom in there!
Rich_p is offline   Reply With Quote
Old 06-16-2004, 07:36 AM   #5562
jedi's Avatar
Sorry I dont have pics but a GT7 will fit just fine. I mounted mine with the wires facing the shaft, if that makes sense to you.
jedi is offline   Reply With Quote
Old 06-16-2004, 07:57 AM   #5563
rod_b's Avatar
Default Re: GT7
Here's a pic of mine. It has a JR RS300 receiver sitting up on it's side but it used to have a Novak XXtra lying flat on the chassis in between the GT-7 and my servo.
Old 06-16-2004, 08:03 AM   #5564
rayhuang's Avatar
I mounted mine with the cap on the ooutside and the schottky Diode wired into the circuit board tabs and run under the driveshaft to clean up the install and have really short wires.
Heres a pic or two.
Old 06-16-2004, 08:04 AM   #5565
rayhuang's Avatar
This pic is from a Tc3-but the way I wired the diode is the same:
