Like Tree6Likes
Old 06-15-2004, 04:01 AM   #5536
Entropy's Avatar
Originally posted by JDM_DOHC_SiR
I See
Actually we LOVE everyone... even blue boys...
Entropy is offline   Reply With Quote
Old 06-15-2004, 04:37 AM   #5537
VenomWorldOrder's Avatar
Default rEAR SHIMMING
ay pro4 dudes i'm running a hacker 6t with a comp esc and i'm experiencing rear crown gear strippage. i know it requires correct shimming so all mod drivers (8 turners and less i guess) can you tell me how/were and how many shims you run on your rear case bearings. please pm and post the answer as i don't often check the pro4 thread anymore.....i'm out racing.
so far i am running 4 shims in total. 2 infront of the shim closest to the spur gear and then another 2 straight after the bearing spacer on the case.
PLEASE PM ANSWER.
VenomWorldOrder is offline   Reply With Quote
Old 06-15-2004, 05:47 AM   #5538
kewdawg's Avatar
Default Re: rEAR SHIMMING
PLEASE PM ANSWER.
Shim according to the manual and you'll be good to go. Also, the manual setting keeps the drivetrain "free".
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 06-15-2004, 05:55 PM   #5539
RBLove's Avatar
Trader Rating: 72 (100%+)
Any news on arms and hubs becoming available in the "U.S."??
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, BSR Racing Tires
RBLove is offline   Reply With Quote
Old 06-15-2004, 06:14 PM   #5540
S15Racer's Avatar
Hey guys I'm in a bit of a predicament here. The kit comes in tomorrow, and I dont have a tap. I looked all over the place today and no one around here has a stupid 3mm tap! I found 4mm taps, 5mm, 40 peice sets with a 3mm, but not just an individual 3mm. My question is, well actually I have 2. First of all, do I really need a tap? If I just put some muscle behind it could I manage without one? And second, is there a standard sized equivelent that I could use instead? Cause I do have access to a set of standard sized taps that might work, but Im not positive.
S15Racer is offline   Reply With Quote
Old 06-15-2004, 06:17 PM   #5541
Registered User
never use standard on metric.
Tower Hobbies have 3mm tap.
Aku-Man is offline   Reply With Quote
Old 06-15-2004, 06:18 PM   #5542
coastaltony's Avatar
S15Racer
Be VERY careful with a 3mm tap, IF you find one. The droop screws will be sloppy, you want them TIGHT.
Meucci pool cue collector
coastaltony is offline   Reply With Quote
Old 06-15-2004, 06:23 PM   #5543
Send a message via Yahoo to Doug Gaut
You dont need a tap. In the directions it says to use the supplied grease (red cap) on the screws to help in installation. It worked as described. Have fun building!
Doug Gaut is offline   Reply With Quote
Old 06-15-2004, 06:30 PM   #5544
Just order them from rainbowten by EMS and they're at your door in 5 days. If you order enough parts it's cheaper. And they have all the hopups out so far.
Downforce is offline   Reply With Quote
Old 06-15-2004, 06:45 PM   #5545
S15Racer's Avatar
I guess I 'll put the standard set away and just go with the grease then, thanks for the advice guys.
btw doug, where were you last saturday?
Old 06-15-2004, 06:48 PM   #5546
Registered User
Make sure you wear glove because your hand is going to hurt.
Old 06-15-2004, 06:56 PM   #5547
S15Racer's Avatar
thanks...
Old 06-15-2004, 07:10 PM   #5548
does anybody know if there are aluminum diff halves available yet?
SCHMACHER is offline   Reply With Quote
Old 06-15-2004, 07:21 PM   #5549
rc_square24's Avatar
is the foam setup for the gate in the back of the manual a good starting point for most carpet tracks?
rc_square24 is offline   Reply With Quote
Old 06-15-2004, 08:12 PM   #5550
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
I have had good luck with it as a base line setup so I would start with that one.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
