Old 06-13-2004, 09:48 PM   #5491
jedi's Avatar
Default Raving-Monkey
I got my Pro4 about a month ago. It came from the lastest batch produced. I noticed that the chassis and upper deck are slightly thicker than that on my brother's car which he got a couple of months earlier. Maybe your car is from the lastest batch like mine. I measure the thickness of my chassis with a digital caliper and it came out to between 2.71 to 2.86mm as opposed to my brother's which is between 2.3 to 2.5mm. You'd be surprised that the chassis thickness is not the same althroughout.
jedi is offline   Reply With Quote
Old 06-13-2004, 10:00 PM   #5492
Originally posted by JDM_DOHC_SiR
This car is the most Quiet Shaft car I have heard and the Drive train is very free out of the box...very little work is needed to make it really free
-Dave
Anybody else want to add feedback? (Look for my earlier post)
aviaar is offline   Reply With Quote
Old 06-13-2004, 10:40 PM   #5493
Super Steve's Avatar
Send a message via AIM to Super Steve
If you like quiet cars, i would suggest belt car of some sort. Pro 4 is very quiet but shafts are not always the quietests.
Maintenance is easy and driveterrain in stock form is very very smooth
Super Steve is offline   Reply With Quote
Old 06-13-2004, 11:27 PM   #5494
kewdawg's Avatar
The Pro 4 is THEE quietest shaft-drive car to date! If, you didn't know, you would swear it was a belt-drive car, that just shot past you!
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 06-13-2004, 11:30 PM   #5495
onnetz's Avatar
Default pro 4 balance
thanks for the info raygun.
I just tried some stiffer springs and it became loose one direction and had a severe push the other..
and was wondering if maybe the stiffer springs just made the balance ( or unbalance) more pronounced..
onnetz is offline   Reply With Quote
Old 06-14-2004, 12:36 AM   #5496
Skill's Avatar
To get this car to handle well you really don't need any other parts, on carpet I am using the stock springs, the rear sway bar, 6 deg C-hubs and the shock positions are slightly different.
You might want to buy a ball diff though, or if you like one-ways then go for PRP's backing plate.
Skill is offline   Reply With Quote
Old 06-14-2004, 08:12 AM   #5497
Regional Moderator
Darkseid's Avatar
Anyone else having problems with 'shaving' their spur gear under breaking? This was my first time running mod with the car, I set the gear mesh as tight as possible while still having play, but still when I hit the breaks, the spur would get 'shaved' by the pinion.
I would come off the track with a pile of white dust just below the pinion from all the material that was taken off!
Like I said, the mesh is right, the motor is tighted down, so what gives?
Should I just go to 48 pitch gears instead???
TLR 22...Tamiya F104...
Old 06-14-2004, 08:53 AM   #5498
raving-monkey's Avatar
Send a message via MSN to raving-monkey
the electrics i use are in my sig (except i now use a reedy Kr or a V2 instead of the d5)
and the other guys i have compared my cars with in the past seem to be similar weight electronics...well kinda.
one runs
gt7
kr297
2143 servo (i think)
demon/matrix spec motors and a Ti mod (again, i think he does)
GP3300 batts
the other guy runs
QC2
2143 or 2173 (cant remember)
V2 mod and spec motors
the rx that comes with the futaba 3pk
GP3300 (i think he does anyway)
so there isnt much differene between my car and the first guys car....but obviously the 2nd guys car is running a lighter esc...and maybe a lighter rx.
i have had my car since around april time so around 3 months...and it was bought from the same place as the guy that runs the GT7 etc.
ahh well...my car seems to run ok for me so i suppose i will shut up now and let you guys talk sense
raving-monkey is offline   Reply With Quote
Old 06-14-2004, 09:13 AM   #5499
chinamonkey7's Avatar
hi, i have a tc3, but thinking about changing car, should i get a Pro4?, because i going back to Hong Kong this summer.
chinamonkey7 is offline   Reply With Quote
Old 06-14-2004, 09:17 AM   #5500
JusBox's Avatar
yes.
JusBox is offline   Reply With Quote
Old 06-14-2004, 09:22 AM   #5501
is the pro 4 a hard car to set up
Old 06-14-2004, 09:23 AM   #5502
rayhuang's Avatar
What up? Remember me from the week from hell @ Snowbirds?-The Pro4 is an awesome car and so much more tuneable than the Tc3. Saw your pic in the magaziones a couple months ago for winning the Kyosho Mini Z stuff!!!
Dont let H.G. beat on you anymore!!
Ray
Old 06-14-2004, 09:28 AM   #5503
rayhuang's Avatar
hahahaha!!
I knew you would ask that next!! HOws racing been going? Are yo u going to do the Birds next year? I think you can make the A-Main next year.
Old 06-14-2004, 09:36 AM   #5504
Ray, i will try to going to the snowbird next year,i have fun this year, i still thinking........ but i scare about set up is because, in F.L., not many of my friend have pro4, i will get lost in set up
Old 06-14-2004, 09:51 AM   #5505
coastaltony's Avatar
So what am I, chopped
liver?
Meucci pool cue collector
coastaltony is offline   Reply With Quote
