Like Tree5Likes
Old 06-12-2004, 09:00 PM   #5476
Send a message via Yahoo to Doug Gaut
Pops, I have my XXtra on top of my servo with fuel tubing covering the antenna wire from the receiver to the tube that is mounted on the top plate. So far so good. I can run any mod motor or stocker unless its a monster. The D5 does not even glitch and it has the same board as a monster so who knows.
Doug Gaut is offline   Reply With Quote
Old 06-12-2004, 10:04 PM   #5477
Smile
I've had the same glitching problems for quite a while, especially with Monsters and Chameleons (it wasn't bad with Reedy motors) ...........................until today.
I did two things.
1. Put a fiber washer (the ones used to space the armature) between the motor and the motor mount.
2. Put electrical tape between the motor mount and the chassis (thanks to Scott for this one-they used this with the Xpress car
NO GLITCHING AT ALL!!!!!!!
jrrc is offline   Reply With Quote
Old 06-13-2004, 03:10 AM   #5478
jedi's Avatar
Default Popsracer
I have zero glitching with any motor with the Rx Ant. mounted on the upper deck. My bro had a lot of glitching with the rx ant. mounted at the stock location. He moved it tp the upper deck and everything was fine.
jedi is offline   Reply With Quote
Old 06-13-2004, 07:11 AM   #5479
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
I did two things.
HMMM I don't a Pro4 anymore but I think I will try out the setup you mentioned. Can't hurt me at all and seems like some simple but great precautions. Never thought of these but I'm going to do those simple mods.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 06-13-2004, 09:51 AM   #5480
raving-monkey's Avatar
Send a message via MSN to raving-monkey
went racing last night with no interfearence problems
so looks like moving the rx to the upper deck has worked fine....i have still got a dodgey motor though...just been skimmed and new brushes...still get same problems.
but no problems with the rest of my motors
raving-monkey is offline   Reply With Quote
Old 06-13-2004, 11:35 AM   #5481
rcdougie's Avatar
Could be the servo causing the glitching. Thats what happened to me with a hitec 5625. Put in a trusty old futaba i had in the box and it runs great with no glitching.
rcdougie is offline   Reply With Quote
Old 06-13-2004, 11:36 AM   #5482
onnetz's Avatar
Default balance
has anyone here ever checked the balance on a scale with the out of box setup?
onnetz is offline   Reply With Quote
Old 06-13-2004, 02:40 PM   #5483
Pit-racer's Avatar
I will be getting a Pro4 soon. What are the parts that are a must have for asphalt racing and also some carpet.
www.igthobbies.com / Serpent Eryx 3.0 / Desoto Racing / Veytrex.com / JZRacing / RcShox / IGT8 Red
Pit-racer is offline   Reply With Quote
Old 06-13-2004, 04:07 PM   #5484
Pops.....one thing to check that nobody has mentioned...pull the case off your reciever check for DIRT..especially were the crystal prongs fit....It happened to me!!!!! now no problems(what happened was the dirt arced across the prongs and gave me massive interferance.
The total weight ready to race was 1425gm ....I got caught out at the first meeting with the Pro4.....had to add heaps of weight......be sure to balance the car with the extra weight.
Barger is offline   Reply With Quote
Old 06-13-2004, 05:00 PM   #5485
how come my pro4 seems to be much heavier than other pro4's at my club?
Old 06-13-2004, 05:26 PM   #5486
Super Steve's Avatar
Send a message via AIM to Super Steve
How are we suppose to know?
lol
Super Steve is offline   Reply With Quote
Old 06-13-2004, 05:42 PM   #5487
JusBox's Avatar
They might have lighter parts, electronics, etc. Could be anything.
JusBox is offline   Reply With Quote
Old 06-13-2004, 07:46 PM   #5488
raygun's Avatar
Default PRO4 Balance
I had to put 20g of weight on the motor side (next to the motor) to balance the car. I used the hudy balancing posts and the 2 holes given on the chassis.
That's with the transponder mounted next to the servo as well.
equipment mounted :
servo : Sanwa/Airtonics VR
receiver : Sanwa/Airtronics RX311
ESC : Schulze 58ce
Motor : LMT 4200 Brushless
raygun is offline   Reply With Quote
Old 06-13-2004, 07:59 PM   #5489
How is maintainence and upkeep for the car? How much work does it take to keep the drivetrain free and the car as quiet as possible?
And how does the car perform box stock, specifically on carpet?
aviaar is offline   Reply With Quote
Old 06-13-2004, 08:03 PM   #5490
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
This car is the most Quiet Shaft car I have heard and the Drive train is very free out of the box...very little work is needed to make it really free
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
