Like Tree5Likes
Old 06-03-2004, 09:03 PM   #5206
raving-monkey's Avatar
Send a message via MSN to raving-monkey
Originally posted by Entropy
Forgot... I used a Hudy system to measure the toe.
looks like you dont want them unsoldered sanyo 3300's
i will send you a PM with my address in it
hehe, j/k mate
raving-monkey is offline   Reply With Quote
Old 06-03-2004, 09:04 PM   #5207
i also just checked my toe in on the rear and it is 3 degrees per one side.
pops..do you ever stop?
first it was looooooads of tweak, now its complaining about toe in.
if your car runs great then whats the problem?
Old 06-03-2004, 09:06 PM   #5208
Send a message via AIM to True R/C Racing
Default Re: Toe or NOT
Originally posted by popsracer
Downforce;
When I double check my Car that has the 3 degree toe block currently installed. I am reading 1.5 degrees PER side/Wheel.
My Pro-3 which has the 2 degree block in it, measures 1 degree PER side.
These are taken with a set of Integy alignment gauges, so accuracy is spot on.
Either way, I have always used the combined measurement when setting toe and 3 degrees (or 2.5) PER side is excessive, especially for an Electric Car.
Maybe your integy system are Warped?
True R/C Racing is offline   Reply With Quote
Old 06-03-2004, 09:27 PM   #5209
Super Steve's Avatar
Send a message via AIM to Super Steve
Goodies.....
Super Steve is offline   Reply With Quote
Old 06-03-2004, 09:30 PM   #5210
CraigH's Avatar
Spool anyone?
CraigH is offline   Reply With Quote
Old 06-03-2004, 09:31 PM   #5211
Send a message via Yahoo to Doug Gaut
Please stop guys!! You are killing me! If it aint broke, dont fix it.
Can we talk about setups or something? Has anybody tried the Reedy setup yet? Maybe with a oneway instead of a spool, swaping the sway bars since with the oneway you will have plenty of steering?
Doug Gaut is offline   Reply With Quote
Old 06-03-2004, 09:31 PM   #5212
Entropy's Avatar
hehe, j/k mate
LOL, those are cells I won in a lucky draw during a race. I might use them as practice packs since GPs are da bomb. Incidently, I won a pack of GP shorties one week after that in another race... guess why they aren't in the photo
Entropy is offline   Reply With Quote
Old 06-03-2004, 09:32 PM   #5213
Where did you find that Craig? Hey, are you going to the race next weekend at Fastlane?
Old 06-03-2004, 09:35 PM   #5214
CraigH's Avatar
Yes I will be @ Fastlane. The spool is fresh off the lathe. Took about 2hours to make. Here it is before I was done. (actually my roommate cause I would have screwed it up somewhere)
Old 06-03-2004, 09:37 PM   #5215
Entropy's Avatar
That spool looks heavy man
Old 06-03-2004, 09:39 PM   #5216
can anyone explain t me what a spool is and why you would want one?
Cheers,
Mossie
Mossie is offline   Reply With Quote
Old 06-03-2004, 09:39 PM   #5217
CRASH's Avatar
Trader Rating: 26 (100%+)
Default Spool
Nicely done Craig. See ya at Fastlane the 12th.
Later,
CRASH is offline   Reply With Quote
Old 06-03-2004, 09:39 PM   #5218
Craig, check your pm.
Old 06-03-2004, 09:41 PM   #5219
Entropy's Avatar
Cheers,
Mossie
Its basically a locked diff. You get excellent power out of corners without the braking penalty of using a one-way (back of car slides).
Really depends how much steering you want and your style of driving.
Old 06-03-2004, 09:41 PM   #5220
Mossie, a spool acts like a diff off power but like a oneway on power but more extreme in both instances. Some races require no oneways so the next best thing to run is a spool. The car will push slightly off power but you have full braking effect. On power the car will turn on a dime where a diff will push out mid to exit some. Hope that helps.
