Like Tree5Likes
Old 06-01-2004, 09:49 PM   #5131
RCBuddha's Avatar
Trader Rating: 33 (100%+)
Originally posted by racer
which body would all of you prefer?
proline's Mazada 6 or hpi's nsx?
sorry to get off topic.
just need to get some input as to which car is better.
Thanks!
I like either the Aero 2 or the Mazda 6. both handle very well, much better than the stratus 2.0
RCBuddha is offline   Reply With Quote
Old 06-01-2004, 10:26 PM   #5132
rc-zombies's Avatar
Originally posted by Super Steve
i'd say someone with bmi chassis conversion butcher their original front shocktower and see if they can mount a nsx body!
I already butchered mine...mounted the top hole in the lower mounting position on the diff housing...still will not work....
Old 06-01-2004, 10:28 PM   #5133
rc-zombies's Avatar
Originally posted by RCBuddha
zombies,
How are you running your diff? Did you put the spring and nut on the same side (i.e. opposite side from the thrust bearing)?
I'll have to try the parts this weekend, will let everyone know...
per the pro4 instructions...thrust bearings and spring on one side.
is there another way they go together?
Old 06-01-2004, 10:37 PM   #5134
RCBuddha's Avatar
I was thinking about assembling my diff with the AE parts like they have with their steel outdrive diffs: Thrust bearing on one side, spring and nut on the other. Like the way they have it in their b4/t4....I've NEVER understood why AE, yokomo and HPI all got away from this placement of the diff parts. This new design never seems to hold its settings without some serious tightning.... Perhaps Erik S. can provide some insight????
I think I may have to relocate the thrust bearing to the other other outdrive, but I think this may be the solution to the loose diffs that many are experiencing.....Will build one tonight and try on saturday....
Buddha
Old 06-01-2004, 10:43 PM   #5135
kewdawg's Avatar
Originally posted by azenis
hi guys
quick question...
aside from the difficulty in getting spares, what is your biggest beef with the Pro4? Or any other major problems?
Keeping the beautiful chassis from scraping on the asphalt, arrrggghhhh! I don't know... maybe, trying to drive w/ a one-way and not hitting anything that will strip the input gears! To be honest, I only had this problem when I went outdoors w/ PVC and a hot mod motor in the car.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 06-01-2004, 10:51 PM   #5136
azenis's Avatar
I guess some tape underneath will help there?
Yeah... Car I am looking at has a ball diff for the front as well. I will use my TA04 for drifting with PVC or are you using PVC to lay out a track?
Nige
X-Ray T4 '14 | 3Racing Sakura D3 CS | Durango DEX410v4 | HPI Blitz | Tamiya WR-02 VW Bus
azenis is offline   Reply With Quote
Old 06-01-2004, 10:59 PM   #5137
RCBuddha's Avatar
Zombies,
Here's the diagram for the tc3, which has an exploded view of the way I just built my spare diff:
http://download.teamassociated.com/p...rawing_tc3.pdf
I JUST put my spare diff together like the diagram shows, so I'll test it this weekend....
Buddha
Old 06-01-2004, 11:03 PM   #5138
kewdawg's Avatar
Yeah, I was referring to the track boarders being PVC. It's pretty easy to break, strip or mangle any internals in a touring car, moving at speeds of 30 - 40 mph.
Quinn Moon
Old 06-01-2004, 11:18 PM   #5139
azenis's Avatar
i guess with a shaft drive you "may" not have the protection of a belts "give" so something will crunch... do people find that durability is better with a ball diff in the front?
We use planks to do our layout, thin bits of wood that look a bit like ripple strips, car usually just goes over the top of them, though a new model park is being built and i dont know what method will be used there...
Nige
Old 06-01-2004, 11:34 PM   #5140
kewdawg's Avatar
The "Diff action" of the ball diff unloades power / force to the other wheel, moving forward or backward, eliminating the stripping of the gears. Using a one-way (the bearing turning in one direction only) doesn't allow the force from a crash to go anywhere - except to the drivetrain, where the gears are! So, the gears are virtually impossible to strip with a ball diff.
Quinn Moon
Old 06-01-2004, 11:53 PM   #5141
azenis's Avatar
brilliant!! Just what I needed to hear
Nige
Old 06-01-2004, 11:58 PM   #5142
kewdawg's Avatar
Glad I could help. Off to bed I go. My eyes are burning. See ya'!
Quinn Moon
Old 06-02-2004, 12:05 AM   #5143
azenis's Avatar
Cos I have found a 2nd hand one for sale, has both one way and a ball diff for the front.
So this is good - id rather a ball diff on our tracks anyhow as sometimes you need BRAKES
Do you have any other problems with it? Cos I am still deciding between the pro4 and xray (but i really dont want belt if i can avoid it as we get too much debris on the track that gets in the belts and pulleys on my ta04)
Nige
Old 06-02-2004, 04:27 AM   #5144
racer's Avatar
rc-zombies, rcbuddha
Thanks you both for the input on which shell better
time to get an M6!
racer is offline   Reply With Quote
Old 06-02-2004, 08:02 AM   #5145
rc-zombies's Avatar
Zombies,
Buddha
ahh..IC.... that's what I thought... thanks! when I had my TC3 never did have a problem with the diffs coming loose...may have to take the car apart again and redo the diffs...
