Hpi Pro 4
#5056
rc-zombies- If you know something please spit it out.
#5057
I dunno...I think there's more to it than that. The way he was talking, there's basically a "black hole" that all the new parts fall into and they all seem to surface at the asian distributors and dealers. They get the parts, we get the B/O's
The guy is hardly "disgruntled", he was just trying to explain what was going on...
#5059
hi, i just picked up a pro4, any one have any building tips i should know before building it? i'm racing this car in a small tight track with low traction any setup suggestion?
thanks.
thanks.
#5060
Build it per the manual setup and start there. The stock setup is real stable. I did drop to 40wt oil but that is about all I have changed so far. If you keep the oneway in you need to invest in a backing plate like the one that PRP or HPI sells otherwise the gear will flex and you will chip a tooth off. I am sure you will enjoy the car.
#5061
The only aftermarket parts I have on my car are the PRP gear plate, and TruSpin. The one-way gear plate is a must have if you run the one-way, imho. Otherwise you run the risk of loosing teeth off either gear due to the flex in the gear itself. http://www.teamprpracing.com Ben has them in stock now.
I still have not damaged a single gear since running PRP's plate.
zombies - Sneaky... Question of the day shouldn't "be whats up with the X-ray?", but "Who is that in your avatar? "
#5062
Yea, forgot about the rear lower shock mount! Thanks Troy. Kinda late for me.
I just installed both the gear plate and the truespin Friday night. Went together great as usual when you get items from PRP. Ran mod Saturday and NO gear problems! YEA!!!
#5063
Originally posted by rc-zombies
I know naaaaaathing...
I said too much all ready....
#5065
Alloy diff gear
Not sure if this is old news but it looks like Square will be releasing an Alloy diff gear for the Pro4.
#5066
pardon my ignorance but what is a TruSpin?
#5067
It shows both the plate and the truspin on my car.
#5068
just like the carbon spur gear holder for the ta04
cool
so everyone here is happy with the pro4?? Should I get one?
cool
#5069
thanks for the help guys, how come you guys are looking for spare parts? is this car like the tc3? the arms on the pro4 looks pretty beefy already. the prp stuff looks pretty good. i'm going to have to pick up one of those. i'll post pics after i'm done.
#5070
