Like Tree6Likes
Old 05-28-2004, 06:09 PM   #5011
popsracer's Avatar
Default Pro-4 parts
Guys;
'Buy HPI' has the 6mm clamping Hex Hubs back in stock. I ordered mine last night. 'Tower' is still out of stock.
popsracer is offline   Reply With Quote
Old 05-28-2004, 06:30 PM   #5012
rc-zombies's Avatar
Default Re: Pro-4 parts
Originally posted by popsracer
Guys;
I ordered mine 2 months ago when it showed it in stock...and still haven't recieved it...
I hope your order gets delivered..
I ended up ordering the Integy/Atlas ones... 6.2 for the front and 5.2 for the rears...
Old 05-28-2004, 09:24 PM   #5013
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Guys;
Give you all a little heads up on the 6mm ones.... You can use the Older Pro3 ones to thats what I did because I had a set laying around after I sold my Pro3 Hara. a while back
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 05-28-2004, 09:52 PM   #5014
tomdav's Avatar
Trader Rating: 42 (100%+)
Default Parts
Ordered knuckles, hubs, 2.0 and 2.5 deg sus mounts, and even got some steel universals. This was from Rainbowten. They showed suspension arms as being in stock but they are also on backorder. Now I'm worried. At least the shipping was cheap, 13 bucks EMS. Thats also with four pair of sorex's.
Tom
The Couve, WA
davesrctracks.net
tomdav is offline   Reply With Quote
Old 05-28-2004, 11:58 PM   #5015
JusBox's Avatar
Default Re: Re: Pro-4 parts
-Dave
any chance you know where to pick up the pro 3 hubs? I haven't had much luck in finding any.
JusBox is offline   Reply With Quote
Old 05-29-2004, 12:14 AM   #5016
Default Re: Re: Re: Pro-4 parts
Have you tried Stormer Hobbies ?? or Hot Bodies..?
-Dave
Old 05-29-2004, 04:04 AM   #5017
VenomWorldOrder's Avatar
Default Re: Parts
any 6mm hex clamps will fit, from any brand. if you don't care about colour you can get the 3 racing clamps for the mtx3, or v1rr or fwo5 or the mugen seiki clamps for the mtx3.
VenomWorldOrder is offline   Reply With Quote
Old 05-29-2004, 04:21 AM   #5018
Super Steve's Avatar
Send a message via AIM to Super Steve
Default Re: Parts
I bought out the suspension arms from R10!
Actually, RC Zombies did, so blame him
Super Steve is offline   Reply With Quote
Old 05-29-2004, 09:07 AM   #5019
rc-zombies's Avatar
Default Re: Re: Parts
Zombies HS is now open... j/k
only 1 set left that I'm saving for my self...
the Pro3 hex hubs are #72036 same ones sold on Buy HPI...that they always show in stock...but never is....
Highly recommend getting the Integy/Atlas version...they are Purple. if you're running wide track in front and narrow rears get 1 set of each 6.2 and 5.2mm hubs. this you'll have 3 sets of hubs in different thicknesses..if you include the stock 4.7. you may not need those spacers any more... just change hubs and your wheel will be more secure.
Old 05-29-2004, 11:16 AM   #5020
coastaltony's Avatar
RCZ Tell me what you have to sell. I need a few things.
Meucci pool cue collector
coastaltony is offline   Reply With Quote
Old 05-29-2004, 10:18 PM   #5021
onnetz's Avatar
what dish rims will fit on the pro 4?
I noticed hpi only has 24mm ones..
onnetz is offline   Reply With Quote
Old 05-29-2004, 10:25 PM   #5022
onnetz, good question.
I have been using some Pro-Line rims.
Most of todays races use Take Off pre-mounted CS-27's as a "spec" tire. I'd like to hear from others.
Old 05-29-2004, 10:56 PM   #5023
rc_square24's Avatar
why does my setup system(hudy type) shows that one side of my rear axles as 2deg(exactly) and the other as 3deg.
the car is new, stock parts so the 2deg side should be 3 instead of 2.
anyway to fix this or its my systems problem? im using the integy made set.
i also found that on both diff cases there were material scratched off where the beveled gear spins closest to, even with one shim on the bearing.
this is what i did
rc_square24 is offline   Reply With Quote
Old 05-29-2004, 10:59 PM   #5024
this was how the gearbox was scratched
Old 05-29-2004, 10:59 PM   #5025
top half
