Like Tree6Likes
Old 05-27-2004, 09:59 AM   #4996
rc-zombies's Avatar
Originally posted by Skill
All of those look cool, but I admit they do look very much like other aftermarket parts, but there's only so many differences you can make I guess, it still has to fit on the same car!
One thing, does anyone know what these are?
The only thing I can think of is those things that go on the ends of the inboard suspension pins.
the next thing I buy!
those are delrin pivot block balls... repaces those heavy steel ones....
Old 05-27-2004, 10:09 AM   #4997
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Originally posted by raving-monkey
do PRP ship to the UK?
as i will definatley be getting a one-way brace if they do ship to the UK.
and i might aswell get a 'true-spin' spur plate while i am ordering
so do they?
PRP does do international orders. Here is the order info. page: http://www.teamprpracing.com/order.html
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 05-27-2004, 10:18 AM   #4998
TeamPRP's Avatar
Hopefully my part will stay alive now that HPI has come out with there own. Fortunately for me, our plate braces the entire gear, not just the small flat area of the gear. So that's a plus!!!
Originally posted by JDM_DOHC_SiR
Looks like the Ring Gear Backing plate from HPI is a tad it thicker than the PRP one hmmmm
-Dave
TeamPRP is offline   Reply With Quote
Old 05-27-2004, 10:35 AM   #4999
rod_b's Avatar
Send a message via AIM to rod_b
Originally posted by Barger
Rod_B....I run rebuildable stock on high grip tarmac with 40/40 foams
Front 2 degree block no 1 piston 70wt
Rear1.5 degree block no 1 piston 60w
oneway
standard springs(no others avaliable)
works good allround....would like to try harder springs...will try AE gold)
Barger - Running a lesser front and rear toe block also, by nature, lengthens the car's wheelbase. How well does it rotate around tight turns?
rod_b is offline   Reply With Quote
Old 05-27-2004, 10:36 AM   #5000
rc-zombies's Avatar
YOu'll want a shorter wheel base for tight technical tracks... long wheel base for open high speed tracks....
Old 05-27-2004, 11:47 AM   #5001
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
why wait for the HPI Derlin ones when the Square Derlin ones for the EVOIII are the same size ..thats what I use on my Pro 4
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 05-27-2004, 11:49 AM   #5002
I'll have to do a comparision when I get back to Japan next week ... from the pic's I have seen of yours .... Your Backing plate looks to be a bit more supportive
-Dave
Old 05-27-2004, 12:04 PM   #5003
rc-zombies's Avatar
-Dave
thanks for the tip Dave....I'll look into the Square ones....
When do we get to see your Pro4.....
found it...
Look like Square is coming out with an aluminum bevel gear...
might be a bit too pricey at $30.00usd..
Old 05-27-2004, 12:14 PM   #5004
Send a message via Yahoo to Doug Gaut
One thing about the PRP brace is that it is available right now.
Doug Gaut is offline   Reply With Quote
Old 05-28-2004, 07:01 AM   #5005
Got my PRP Oneway plate in and it looks great. Nice and purple
racingdc9 is offline   Reply With Quote
Old 05-28-2004, 07:08 AM   #5006
found it...
No problem Zombies
as for my Pro4 when I get back from Vaccation I'll put up some Pic's
Old 05-28-2004, 12:03 PM   #5007
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
I have my BMI HPI Pro4 on the For Sale Forum for anyone wanting a trick Pro4 without having to buy a car kit and then all the add ons. Check it out!!!!!!!!
ST Racing Concepts (STRC)
Old 05-28-2004, 03:32 PM   #5008
racer's Avatar
anyone running ceramic balls in their differentials?
if so, are there any differences compared to the stock ones?
any help would be appreciated.
Thanks!
racer is offline   Reply With Quote
Old 05-28-2004, 03:59 PM   #5009
rod_b's Avatar
Yes running Acer ceramic diff balls. The good thing is that they've been very resistant to feeling gritty. The bad thing is that they're so hard that if I crank on it hard enough the diff will slip. It actually makes a clicking sound. I took them apart to check for wear or damage and the diff looks fine...practically new.
Old 05-28-2004, 05:27 PM   #5010
raving-monkey's Avatar
Send a message via MSN to raving-monkey
but acer products look a little pricey
raving-monkey is offline   Reply With Quote
