Old 05-26-2004, 05:10 PM   #4981
Send a message via Yahoo to Doug Gaut
Thanks for the pics! I am really hoping mine gets here before this weekends racing!!!!!!
Doug Gaut is offline   Reply With Quote
Old 05-26-2004, 08:24 PM   #4982
rayhuang's Avatar
Default 2-steps forward-one step back
Well-I put the 2.5 degree front arm sweep back in and had a lot more steering on carpet/foam tires. I also reduced rear droop and liked that too. I made a small mistake by turning down my dual rate and that hurt me as I had to not go quite as hard into the corners. For some reason on my Helios I cannot thumb up d/r while driving. Gotta practice that. I also felt the rear of the car was rolling way too much and so I put 1mm shims under the rear hingepin blocks and that seemed to free up the rear by letting it run flatter. Sounds opposite of theory-but it worked for me.
Also-why i went one step back is both diffs loosened on me again!!! SO I think that might have hurt my rip off the corners a tad.
I am still too slow, but car handled better than last week. Jimmy went even faster this time and posted 13.2 second laps with his Pro4.
Old 05-26-2004, 10:55 PM   #4983
hi to all,
got my pro4 yesterday, wonder what kind of gearing I should use on 19T class.
I am using Trinity base motor. and race on a really tight and technical track with lots of hairpin. out door parking lot surface.
would stock( that comes with the kit) pinion and spur combination work?
thanks
yeuc001 is offline   Reply With Quote
Old 05-26-2004, 11:13 PM   #4984
Rod_B....I run rebuildable stock on high grip tarmac with 40/40 foams
Front 2 degree block no 1 piston 70wt
Rear1.5 degree block no 1 piston 60w
oneway
standard springs(no others avaliable)
works good allround....would like to try harder springs...will try AE gold)
Barger is offline   Reply With Quote
Old 05-27-2004, 01:37 AM   #4985
raving-monkey's Avatar
Send a message via MSN to raving-monkey
do PRP ship to the UK?
as i will definatley be getting a one-way brace if they do ship to the UK.
and i might aswell get a 'true-spin' spur plate while i am ordering
so do they?
raving-monkey is offline   Reply With Quote
Old 05-27-2004, 02:25 AM   #4986
Originally posted by yeuc001
hi to all,
thanks
You dont get a pinion with the kit.
Rich_p is offline   Reply With Quote
Old 05-27-2004, 04:33 AM   #4987
racer's Avatar
more option parts for the Pro 4.
click here for more purple stuff
some of the designs looks very familiar
racer is offline   Reply With Quote
Old 05-27-2004, 04:48 AM   #4988
Frank McKinney's Avatar
How many different ways do you think a gear brace can be designed? Buy the PRP one if you want, I don't think anyone will mind.
Minimal signature to save screen space! Big sigs suX0r
Frank McKinney is offline   Reply With Quote
Old 05-27-2004, 05:31 AM   #4989
Super Steve's Avatar
Send a message via AIM to Super Steve
OOOOOOOo
Some of those parts looks like RC square stuff!
But they are very nice
The price seems better with the HPI brace
Super Steve is offline   Reply With Quote
Old 05-27-2004, 05:58 AM   #4990
Has anybody compared the 3mm chassis from HPI and the 3mm chassis from BMI. Is there a difference. I want to get a thicker chassis but not sure about the pro's and cons of these 2
rudster is offline   Reply With Quote
Old 05-27-2004, 06:21 AM   #4991
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Looks like the Ring Gear Backing plate from HPI is a tad it thicker than the PRP one hmmmm
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 05-27-2004, 08:47 AM   #4992
rc-zombies's Avatar
looks like more stuff to buy...
Old 05-27-2004, 08:57 AM   #4993
tomdav's Avatar
Trader Rating: 41 (100%+)
Default Spares
Has anyone found a place to buy Arms, knuckles, hubs yet? Do we have to order from Japan? My first race is this weekend with my pro 4 and I'm not planning on finishing the day without being very conservative and having a little luck.
Tom
The Couve, WA
davesrctracks.net
tomdav is offline   Reply With Quote
Old 05-27-2004, 08:58 AM   #4994
Skill's Avatar
All of those look cool, but I admit they do look very much like other aftermarket parts, but there's only so many differences you can make I guess, it still has to fit on the same car!
One thing, does anyone know what these are?
The only thing I can think of is those things that go on the ends of the inboard suspension pins.
Skill is offline   Reply With Quote
Old 05-27-2004, 08:58 AM   #4995
cartmen34's Avatar
Default Re: Spares
cartmen34 is offline   Reply With Quote
