Hpi Pro 4
#4967
Indoor concrete with a 160ft straight and sweepers at both ends so it was more like 180ft or 190ft.
#4968
Hpi Pro 4 tuning
Doug Gaut;
Thanks for all of your set-up advice. With the manual and your suggestions, I've got a plan of action in mind.
Funny about how the stiffer Rear spring worked for you. I've also experienced the same thing once or twice over the years.
Guys;
It will be a week or two before I get the Car on the track again (this weekend is Off-road). I'll post my set-up changes and findings after I get some more track time with the new set-up (parts pending).
Thanks,
Steven
Guys;
Thanks,
Steven
#4969
I am looking forward to seeing your results!! The more information we can share the better off we will all be. Everybody has different driving styles and track conditions but there is always something to be gained by others experiences!! Best of luck!
#4970
good stock set up on ashalpt
looking for a good set up on pavement shock postion etc, i took the one way out put in diff but hve not drove it wth diff yet also still need a arms to get it up to full speed to race waht postion o need on arms
hi luis u got an a- arms yet at ur shop yet rpm holla
#4971
Re: Hpi Pro 4 tuning
Originally posted by popsracer
...Funny about how the stiffer Rear spring worked for you. I've also experienced the same thing once or twice over the years...
#4973
Rod, are you using the oneway as well? Are you running a mostly kit setup? Is this for mod or stock?
#4974
Tech Legend
Trader Rating: 51 (100%+)
Originally posted by coastaltony
rod
Let me know the affect after switching to the 2.5. My car dogs a little with 3.0. I can't find 2.5, 2.0, or 1.5 blocks.
rod
After you order over the computer you will get a order number and then a email of when you order goes out.
Brian
#4976
#4977
My track is high bite so I went the opposite way with the inner camber links to reduce roll/grip. What is nice is that 1mm raised or lowered makes a huge difference in handling.
#4978
Oneway on carpet
im not sure if this is what most people do but i hear some people saying that its better to have diff in the front than a oneway.
but isnt a oneway for high-bite sufaces like carpet?
#4979
sorry, they were saying a diff on carpet than a oneway
#4980
Here is a shot of the TeamPRP TruSpin & one-way plate installed for those who haven't seen them yet. The anodising on the one-way plate is a perfect match to HPI's purple, and although I'm betting most of you have seen my post praising the plate, I'll say it once again, not a single gear breakage since I've been running it - which is around 2 months now. www.teamprpracing.com
Ben, I'll send you an e-mail a little later tonight. Thanks.
