Old 05-24-2004, 06:43 PM   #4951
Super Steve's Avatar
Send a message via AIM to Super Steve
*[Edit]* double post...
Super Steve is offline   Reply With Quote
Old 05-24-2004, 07:04 PM   #4952
JusBox's Avatar
i saw some dry teflon lubricant at lowes near the registers the other day... i'll give that stuff a try.
JusBox is offline   Reply With Quote
Old 05-24-2004, 08:58 PM   #4953
Thumbs up TQ and a win!
A great day at the track sunday with the car. Ripped .4 seconds off the fastest lap and added another lap to the fasted quailfier. (keep in mind that that was with the current layout, it changes once a month)And all I did was change tires from last week. Picked up a set of premounted Take-offs. 32's for the front and 27's for the rear.
I was just looking at my car tonight trying to find out whats going on with my car on the 180 turns. It spins out but if i go wide it's controlable. I just don't lift and counter stear when it does. It was only one corner so I thought that was good enough because the car absoulutly flew on the rest of the track. Anyway, I just noticed that i was running what looks like 3 degrees of toe out in the front . I'll try the 2 of 0 degee caster C-hubs and take out as much of the toe as possible. That should take care of my problem. Won't know for 2 weeks due to the holiday next week. I'll post what happens later.
-Derek
Downforce is offline   Reply With Quote
Old 05-24-2004, 11:25 PM   #4954
Skill's Avatar
Originally posted by Barger
I had a major problem last race night......For the first lap I had MAJOR interferance,thenfor the rest of the race full control again.This happened 4 times...practise was fine...I tried putting the reciever (KO kr297fz)on the servo,I also changed crystals....Still the same problem.
Any ideas??????
My guess is that someone who was racing the race before you still had their transmitter on. There are some very selfish people about who take a long time to switch their transmitter off. I suggest next time if it happens again you look to see if anyone is on the same frequency as you the race before. If so, either have a word with that person, or change your crystals to something else.
I am in the UK, do you know if they sell the graphite powder here?
Skill is offline   Reply With Quote
Old 05-25-2004, 12:05 AM   #4955
onnetz's Avatar
Default springs
I'm looking to get a couple sets of springs..
running on asphalt what are the recommendations?
onnetz is offline   Reply With Quote
Old 05-25-2004, 12:13 AM   #4956
coastaltony's Avatar
I have been having
good luck with AE blues, and reds from
TC3 car.
Meucci pool cue collector
coastaltony is offline   Reply With Quote
Old 05-25-2004, 01:01 AM   #4957
onnetz's Avatar
thanks..
I will give those a try..
Old 05-25-2004, 02:16 AM   #4958
Skill.....You should be able to get graphite powder in UK...Try hardware Store etc...ask if they can get it for you.
Your answer to my problem could be true......so simple that I did not even think of it....I will check the race before me next time.
Barger is offline   Reply With Quote
Old 05-25-2004, 06:16 AM   #4959
I was looking at some of the pics a lot earlier on this thread. I noticed some of you guys did a really nice job of treating the graphites parts edges and they look smooth and shiny. But when I treat my graphite edges with CA, it looks dull and uneven after it dries off. So my questions are, what is the proper way to treat those edges, what type of CA do you all use, and what is the purpose of CAing the edges anyways? Appreciate the advice.
Silvercomet is offline   Reply With Quote
Old 05-25-2004, 06:29 AM   #4960
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
Trader Rating: 14 (100%+)
Silvercomet: wet sand with like 1000 grit or you can also use clear finger nail polish for a final coat.
Finger nail polish does take longer to cure though.
Tre's
TnT-Fx Custom Graphics
www.tnt-fx.com
Tres is offline   Reply With Quote
Old 05-25-2004, 06:52 AM   #4961
Tres: So its light sand, CA then nail polish?
Besides the looks, what are the benefits of treating the edges?
Old 05-25-2004, 07:48 AM   #4962
Send a message via Yahoo to Doug Gaut
I used the Losi thin tire glue and it has a nice shine to it. Takes no time at all and its dry.
Doug Gaut is offline   Reply With Quote
Old 05-25-2004, 07:52 AM   #4963
Tres's Avatar
CRC Chassis Prep Guide
Tre's
www.tnt-fx.com
Old 05-25-2004, 07:53 AM   #4964
As far as springs go, I had real good luck this past weekend running the stock gold front springs (19lb) and Losi green springs in the rear (17.5lb). The car was a little loose mid to exit on power but after I took the stock silver springs (16.9lb) off and put the 17.5lb ones on, the car was real stable. This was on a large track with mod motors and rubber tires.
Old 05-25-2004, 08:04 AM   #4965
Thanks Tres, that guide answers all my questions.
