Like Tree6Likes
Old 05-24-2004, 02:06 PM   #4936
cHckbOY5's Avatar
Send a message via AIM to cHckbOY5
do u guys run ur drivetrain dry?
cHckbOY5 is offline   Reply With Quote
Old 05-24-2004, 02:09 PM   #4937
rayhuang's Avatar
I do. But If I had a dry teflon lube-I Would use it. I cannot say I have had any noiceable wear in my TC3 trannies running them dry and have even hard from guys that they saw a lot of wear when running a lube!! Doesnt make sense.
Ray
Old 05-24-2004, 02:14 PM   #4938
Skill's Avatar
I run with grease on my gears...
Skill is offline   Reply With Quote
Old 05-24-2004, 02:38 PM   #4939
Super Steve's Avatar
Send a message via AIM to Super Steve
I laos run my gears dry with teflon lube
Super Steve is offline   Reply With Quote
Old 05-24-2004, 05:35 PM   #4940
Default Diff gears
I run mine dry, but usually I over grease my diff and it slings out onto the gears. And my car spins super free.
Downforce is offline   Reply With Quote
Old 05-24-2004, 05:41 PM   #4941
Registered User
I'm thinking using one of these. What do you guys think? Which one would be better.
http://www2.towerhobbies.com/cgi-bin...3&I=LXKR90&P=K
http://www2.towerhobbies.com/cgi-bin...3&I=LXKR69&P=K
Aku-Man is offline   Reply With Quote
Old 05-24-2004, 05:48 PM   #4942
rc-zombies's Avatar
The first one is the same is Bike Lube w/teflon...very messy....
get dry lube it sticks to the plastic better... a great alternative is Ultralon...but is discontinued at Tower... next best thing is
White Lightning bike lube...
Old 05-24-2004, 05:54 PM   #4943
Registered User
I have Ultralon and I don't like it. Once I put on, I have to keep spinning till it dry or the gears will seize up. And it is hard to remove. That's why I want to try somethingelse.
Old 05-24-2004, 05:54 PM   #4944
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Paragon makes liquid graphite or at least they use to. I used that on my Pro4 gears. Dries in like a minute or two and stays on a long time. My local shop was getting it for me all last year.
ST Racing Concepts (STRC)
Old 05-24-2004, 06:00 PM   #4945
rc-zombies's Avatar
For best results...It's usually applied before the car is assembled.
the standard grease that came with the car will work fine....
or soak your gears in WD-40
Old 05-24-2004, 06:04 PM   #4946
Graphite powder should also work very well
Old 05-24-2004, 06:05 PM   #4947
Registered User
I might try soak in Mobile 1 fully synthetic transmission fluid. But it stinks.
Old 05-24-2004, 06:10 PM   #4948
Guys The only thing to use on diffs is Graphite Powder.The brand I use is made here in Australia.Being a dry powder you just puff it on and Hey Presto no worries!!!!!!
I had a major problem last race night......For the first lap I had MAJOR interferance,thenfor the rest of the race full control again.This happened 4 times...practise was fine...I tried putting the reciever (KO kr297fz)on the servo,I also changed crystals....Still the same problem.
Any ideas??????
Barger is offline   Reply With Quote
Old 05-24-2004, 06:28 PM   #4949
Registered User
Graphite Powder, where can I get it?
Old 05-24-2004, 07:43 PM   #4950
you should be able to get them at hardware store.
Mine says it's great for all "locks"
Anyways, Ultralon is good stuff too!
