Like Tree5Likes
Old 05-23-2004, 01:23 PM   #4891
raving-monkey's Avatar
Send a message via MSN to raving-monkey
Default Re: Re: motor mount
Originally posted by AWOLsoldier
I bought my pro 4 second hand and the guy that owned it before me chopped the ends off to open up the motor mounts so you can just slide the motor on with the screws attatched. Doesn't look real slick but it works.
i use a ball ended allen key and the motor goes in really easy, no probs with not getting the screw in straight.
raving-monkey is offline   Reply With Quote
Old 05-23-2004, 01:37 PM   #4892
rod_b's Avatar
Send a message via AIM to rod_b
I'm actually suprised that they didn't originally make the mounts like this...with the ends open so you could just slide the motor in. I guess it could get tweaked if it was that way.
rod_b is offline   Reply With Quote
Old 05-23-2004, 01:46 PM   #4893
Super Steve's Avatar
Send a message via AIM to Super Steve
I also use a ball end drive for the motor and it works like a charm!
Super Steve is offline   Reply With Quote
Old 05-23-2004, 01:49 PM   #4894
JusBox's Avatar
Default Re: Re: Re: motor mount
tweaked? I don't see how unless you had a massive crash to force that kind of extreme leverage on the mounts. I think HPI has a new heatsink style mount out anyway, i'll probably just replace it with that.
JusBox is offline   Reply With Quote
Old 05-23-2004, 01:56 PM   #4895
onnetz's Avatar
I just ran my pro 4 for the first time. and I can say I dont care too much for the one way. I have a reedy ti 10x3 for a motor and couldnt even come close to putting the power down and stay under control. I ran it with the setup from the manual on dusty asphalt. it was slip and slide everywhere.
after a couple minutes it got real twitchy and I thought it was just me, but the servo saver was loose allowing play in the steering. got that sorted out but any suggestions to help with putting the breaks on and not throwing the rear end around?
I do have an lrp 7.1 so I can adjust the break to be a little softer.
onnetz is offline   Reply With Quote
Old 05-23-2004, 02:25 PM   #4896
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
You might like it better with a front diff on the dusty track or maybe use a spool in the front so you can get most of the advantages of the one way but have brakes
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 05-23-2004, 02:44 PM   #4897
JDXray's Avatar
Send a message via AIM to JDXray
My pro 4 is kinda twitchy, i need some help on correcting that. I have an M8 radio which might be the reason, can someone tell me there setup on there M8 (if you have one) to make it stop.
Jon
JDXray is offline   Reply With Quote
Old 05-23-2004, 02:50 PM   #4898
You can change the EXP so when you are close to neutral, steering input is very little and you get alot of high end control...
Anyways,
I found some springs.
Can anyone let me know if they are any good?
They certainly look shorter
http://www2.towerhobbies.com/cgi-bin...?&I=LXXG75&P=0
http://www2.towerhobbies.com/cgi-bin...?&I=LXCYC0&P=0
Dual springs set ups but I dunno where to get the middle part
http://www2.towerhobbies.com/cgi-bin...?&I=LXPU90&P=0
Old 05-23-2004, 02:53 PM   #4899
JusBox's Avatar
Originally posted by Aku-Man
I still have 3 more package coming.
where did you order from?
Old 05-23-2004, 03:00 PM   #4900
JDXray's Avatar
Super Steve- Dont those springs look kinda short.
Old 05-23-2004, 03:00 PM   #4901
maybe a shop that sells the....just a thought
Old 05-23-2004, 03:03 PM   #4902
Registered User
I order overseas from Champ, Precisionrc, RC Model, and etc..... Whoever have them in stock.
Aku-Man is offline   Reply With Quote
Old 05-23-2004, 03:39 PM   #4903
onnetz's Avatar
any recommendations for a front diff?
or just go with the same as in the rear.
Old 05-23-2004, 03:46 PM   #4904
JDXray's Avatar
as long as you are not running a big track stick with a regular diff, if you are on big track get a one-way.
Old 05-23-2004, 04:00 PM   #4905
onnetz's Avatar
thanks.. I will go with the regular diff then.
unfortunately there are no tracks around here for about a hundred miles, so I'm banished to parking lot racing..
its a shame to have such a sweet tc and not have a place to really run it.
I'd love to try it out on carpet.
