Old 05-22-2004, 10:00 PM   #4876
Super Steve's Avatar
Send a message via AIM to Super Steve
I just happen to be a smily guy...
I was laughing at my own situation
The perches are not pro 4 specific item. General HPI perches meant to work with all hpi shocks excluding micro, savage and pro 4.
Well, it does work with pro 4 but you can't really lower your cas as one would like.
I am also using one hole inword (closer to the inside of the arms) in all 4 corners which would stand the shock alittle more...
Super Steve is offline   Reply With Quote
Old 05-22-2004, 10:05 PM   #4877
Send a message via Yahoo to Doug Gaut
So its a bling,bling issue then.
I do hope you can find some shorter springs. Good luck.
Doug Gaut is offline   Reply With Quote
Old 05-22-2004, 10:57 PM   #4878
tomdav's Avatar
Trader Rating: 41 (100%+)
Default ae springs
AE gold also work with the stock perches.
Tom
Camas WA
davesrctracks.net
premierrcpdx.com
tomdav is offline   Reply With Quote
Old 05-23-2004, 12:27 AM   #4879
Default Re: low bite
Originally posted by tomdav
I'm just finishing mine and think that it might be a bit stiff. I'm going to leave off the swaybars and might ad a bit of antisquat. Does anyone have problems with using the 1.5mm of spacers for the wheels. I would think you might have issues with the hexes on the wheels rounding out after some light board tapping.
I bought some tamiya 6mm hexes and they work just fine. They may be 2mm wider but they sit in by about .3mm more that the hpi's, which makes them equivalent to to having 1.7mm spacers.
I am currently using Xray dark blue springs(25 lbs) all the way around, but I run the shocks in the outer holes of the towers to get them to work.
jbackslash is offline   Reply With Quote
Old 05-23-2004, 12:56 AM   #4880
Skill's Avatar
If you get really stuck then you'll have to buy the Tobee Craft purple spring perches which are specifically for the Pro 4
Skill is offline   Reply With Quote
Old 05-23-2004, 12:18 PM   #4881
onnetz's Avatar
Default motor mount
maybe its just me, but could hpi have made it any more difficult to mount the motor?
onnetz is offline   Reply With Quote
Old 05-23-2004, 12:27 PM   #4882
RCBuddha's Avatar
Trader Rating: 33 (100%+)
Default Re: motor mount
Try using a 2.5 mm Hudy Wrench that has the ball end. It'll help you to screw/unscrew the motor screws by putting the wrench at an angle....
RCBuddha is offline   Reply With Quote
Old 05-23-2004, 12:46 PM   #4883
onnetz's Avatar
thanks for the reply.
I do have a set of long hex's with the ball end and they definately do help, I guess I just got spoiled with the tc3 motor mount.
I'm sure once I get used to it, it will be no big deal, but at first it is a pain.
Old 05-23-2004, 12:50 PM   #4884
Registered User
Default Something to share
Just got the package. Still waiting for more to come.
Aku-Man is offline   Reply With Quote
Old 05-23-2004, 12:52 PM   #4885
Registered User
Very high quality Jet Racing 4 degree C Hub. Very thick and weight is good. I don't think its heavy at all.
Old 05-23-2004, 01:03 PM   #4886
that's aloooooooooot of stuff dude!
Old 05-23-2004, 01:05 PM   #4887
Registered User
I still have 3 more package coming.
Old 05-23-2004, 01:09 PM   #4888
What are the square parts on the bottom?
Also,
Do you know any mfg that makes short springs?
Old 05-23-2004, 01:12 PM   #4889
Registered User
They are Titanium Ball Studs and Telfon Piston.
Short spring, don't know.
Old 05-23-2004, 02:15 PM   #4890
JusBox's Avatar
I bought my pro 4 second hand and the guy that owned it before me chopped the ends off to open up the motor mounts so you can just slide the motor on with the screws attatched. Doesn't look real slick but it works.
JusBox is offline   Reply With Quote
