Like Tree5Likes
Old 05-22-2004, 11:22 AM   #4861
Send a message via AIM to ZER01
Southerfried, you could have too much rear traction and it is just "breaking loose" or that there just any traction period-none! Post you setup and I can decipher it to make a suggestion.
ZER01 is offline   Reply With Quote
Old 05-22-2004, 11:29 AM   #4862
popsracer's Avatar
Originally posted by Super Steve
3 degree rear toe should be good for low traction.
I guess you can try taking the sway bar off and maybe changing to softer spring on the rear shocks.
As far as antidive and antisquat, I haven't experiment with those yet. I just run the stock settings as far as pivotblock spacers
I am running Stock with this Car and would like to get/keep rear toe to a minimum.
Rear sway bar is off and softer springs really didn't help much.
This is why I am looking at other changes to get the Car better for the conditions that I normally have to race on.
Thanks,
popsracer is offline   Reply With Quote
Old 05-22-2004, 11:32 AM   #4863
Now that's a small track!
Old 05-22-2004, 04:36 PM   #4864
coastaltony's Avatar
Help, is anyone using a Zero Extreme 2002 ESC. I would like a few tips on the correct freq. for a Monster Stock 27t. motor.
Meucci pool cue collector
coastaltony is offline   Reply With Quote
Old 05-22-2004, 05:02 PM   #4865
tomdav's Avatar
Trader Rating: 41 (100%+)
Default low bite
I'm just finishing mine and think that it might be a bit stiff. I'm going to leave off the swaybars and might ad a bit of antisquat. Does anyone have problems with using the 1.5mm of spacers for the wheels. I would think you might have issues with the hexes on the wheels rounding out after some light board tapping.
Tom
The Couve, WA
davesrctracks.net
tomdav is offline   Reply With Quote
Old 05-22-2004, 05:09 PM   #4866
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Default Re: low bite
...Yup, Even more so with shallow hex wheels.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 05-22-2004, 05:12 PM   #4867
JDXray's Avatar
Send a message via AIM to JDXray
Default wheel hexs
do you need the silver spacers on the wheel hexes?
JDXray is offline   Reply With Quote
Old 05-22-2004, 06:55 PM   #4868
can anyone tell me what lbs the springs are and what the equal is in the associated springs.
sportracer is offline   Reply With Quote
Old 05-22-2004, 07:33 PM   #4869
Super Steve's Avatar
Send a message via AIM to Super Steve
um...
lol?
Super Steve is offline   Reply With Quote
Old 05-22-2004, 08:18 PM   #4870
I am running on a Med-Bite asphalt track. 125' back straight, with a semi complex inner area. red AE front, and blue AE rear springs
Pops, what type of track are you running on?
I have stock sway-bars F/R, 45 oil, front diff TIGHT, 3mm F/R droop, 5mm F/R R/H, moved the rear link in to clear inner wheel.
Old 05-22-2004, 08:22 PM   #4871
Send a message via Yahoo to Doug Gaut
The stock springs are gold-19lbs and silver-16.9lbs.
I have only been on low bite one time so I really am not sure what to say other than by raising the rear up to 3mm and the front to 2.5mm spacers helped quite a bit. You could also lower the inside camber link mounts be a few millimeters to help with traction as well.
On the high bite tonight my car was trying to overrotate on tight corners so I changed from the rear 16.9lb springs to 17.5 lb springs and that was all it took to lock the rear end in. Nothing like a 9x1 at full song down a 160ft straight!!
Doug Gaut is offline   Reply With Quote
Old 05-22-2004, 08:27 PM   #4872
I am having hard time reaching 5mm rideheight with hpi purple lower spring perches...
Are AE spring Definately shorter?
If they are shorter by 2mm or more that would deffinately help me...
Old 05-22-2004, 08:34 PM   #4873
Steve,you cannot get your car down to 4.5-5.0mm with the stock springs??
Yes Associated springs are shorter but you will need to use the Associated lower spring retainers because they are a smaller diameter as well.
Old 05-22-2004, 08:36 PM   #4874
hahaha that sucks...
It's because the hpi aluminum spring perch is taller compared to stock units...
maybe another brand like xray or kyosho springs are shorter?
Old 05-22-2004, 08:47 PM   #4875
I am not trying to make a joke, just trying to help.
Are the spring perches a Pro4 item? Even with the spring adjusters all the way up you still have too much tension if I understand you correct?
I just measured my Associated springs and the purple ones are 24mm but the blue and silver ones are 25mm which is the same as the Losi green and purple ones and the stock HPI springs too. The lighter springs from Losi measure 29mm. Hopefully some of the other guys may have experience with the other brands you named and you will find some shorter springs.
