Hpi Pro 4
#4726
Steve - Did you ever try dropping a couple teeth? You run 7minutes? Why is this?
#4727
Originally posted by Super Steve
look at my location
CORNWALL ONTARIO
I don't even know where speedworld is!
here is a picture i took of some guys practicing...
you can see part of the tight infield
look at my location
CORNWALL ONTARIO
Speedworld is one of my home tracks...probably one of the best in Northern California. take a look of some track pics..see the link on my sig..
#4728
Steve,
I think Racenut is refering to RC Zombie not you.
RC Zombie,
Are you sure that you're not burning up those Monsters?
RC Zombie,
#4731
Trader Rating: 32 (100%+)
Originally posted by JDXray
anyone have a good pinion gear i can drop in my pro 4? It has an Epic 19t Binary in it, and the Spur is 100t 64 pitch.
Jon
Jon
#4732
Whoa...
Look at these RC model people...
I can not beleive what they just did
He said
"I can't promise you can get the suspension arm 1-2 weeks later. Because your money order takes 1-2 week to HK. We have quite a lot of arms in stock at this moment!"
So I asked
"what would happen if the money order get to you but you guys are sold out of suspension arms?"
And he returns with the message
"Hi,
You better cancel your order because you have too many worries! I'll cancel
your order now!"
WTF?
I mean, that's no way to do bussiness?
What's wrong with him? he doesn't want to do bussiness just because I would like to know their store procedure for backordered items?
So I asked
"Hi,
your order now!"
WTF?
#4733
#4734
monster gearing
I ran expert stock at Speedworld last week. 36/98 with a monster stock. Won by over a lap and the fastest stock lap time. The next week at Ripon, same combination monster @ 36/98. TQ and won there. My TQ was only 2 tenths off the 19t TQ. 2 tenths for the whole run not per lap. I also ran a binary stock @ 33/98 with lap times within a tenth of the monster. You can see these results at rcracing.com
I've only been running this car for a month, but am VERY happy with it. Stiffer springs and 1 degree rear toe in helped a lot.
#4735
Whoa...
So I asked
"Hi,
your order now!"
WTF?
Whoa...
So I asked
"Hi,
your order now!"
WTF?
You know when you place things in your basket on that site It has an asterick if there's no stock. Well I placed 4 sets of arms in there without a problem and placed my order. Only to find out over a week later (yes it took them that long to process an order....... can you friggin belive it !! ) That those items were backordered.
(I only placed an order with them for the arms. Got some other stuff to to make the order worth while but really only wanted the arms)
What really bugs me is that they took over a week to put some items in a F'in box.
RCmodel.com can...... S.A.C !!!!!
#4736
Originally posted by stonedgti
Steve,
RC Zombie,
Steve,
RC Zombie,
Have you seen the track lately...set-up like Tamiya..running in reverse and virtually full throttle all around the track.
jrrc is very fast with that combo as well... I just wish I had more track time to be fast and consistant...with my schedule this year...looks like once a month racing...
racenut123
yes..you are right 7.0 is the target gearing I usually run...but with the current SWR layout it's a different story.. when the hot summer months come around it will be back to the 7.0+/- gearing..
#4737
foam/carpet continued.
The next practce day is coming up and I am hopeful of making it. I am still working on my Pro4 set-up on carpet. I have taken the front arm sweep completely out (had 1 degree last week) and put in anti-dive to stop some overotation on corner exit and last-stiffened up the rear spring to hopefully carry more speed in long corners and quicken up transition. I figure with me running the rear arms flat on the chassis-I probably should be running stiffer springs than on a Tc3 which I think has a higher rear roll center stock.
I also found I had a dud motor last two weeks and was undergeared by two teeth as well. So its slowly coming togethor.
#4738
Originally posted by SpeedDesignz
I ordered stuff from them a few weeks ago
I am going to see if I can work things out because it does look like he has arms in stock at the moment
#4739
