Old 05-12-2004, 11:30 AM   #4546
Send a message via Yahoo to Doug Gaut
Question regarding the sway bars. How does everybody have them tightened on the gearboxes? Shouldn't the set screws be just tight enough to keep them from moving up and down. Right now mine floats from side to side but not up and down. I would think that if they are locked it would take nothing at all to get a tweak in them and cause all kinds of handling problems. Wonder if this is what is causing some of the left turn/right turn issues. Maybe there is a fine line as to how tight the setscrews should be on the bars?
Doug Gaut is offline   Reply With Quote
Old 05-12-2004, 11:43 AM   #4547
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Doug I have set mine the same way as you. I have just a little free play from side to side.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 05-12-2004, 11:44 AM   #4548
RCBuddha's Avatar
Trader Rating: 33 (100%+)
Doug,
Get yourself some Dubro Collars to help eliminate the side to side play. The swaybar should move Freely up and down. Tighten the setscrews a little at a time to remove any other play. It takes some time to do, but it will ensure that they work right.
RCBuddha is offline   Reply With Quote
Old 05-12-2004, 11:54 AM   #4549
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Just get it tight enough to remove the play between the swaybar and the set screws. It shouldn't move up and down between the gearbox & the set screws, but should rotate freely as to not bind up the suspension.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 05-12-2004, 12:49 PM   #4550
Thats what I thought. I will get some dubro collars today to try and remove the side to side play. It would not take much at all to not have the setscrews correct and bind up the movement. Attention to detail!
Old 05-12-2004, 01:07 PM   #4551
crazy4rc's Avatar
Default Rear Differential Slipping
Dear fello Pro4 enthisiat.
Can someone help me? My rear differential is slipping on my Pro4. If I hold the right tire, I can still rotate the other left tire. It is very noticeable when I applied the the tire compound on the tire, the tire wont rotate when I press the applicator tight enough on it. Is this normal on Pro4? I have double check the instructions carefully (page 14 of the manual) but it is still the same. It is tight enough that it did not rotate when both the fiffs hubs are held.
thanks.
crazy4rc is offline   Reply With Quote
Old 05-12-2004, 01:14 PM   #4552
RCBuddha's Avatar
Default Re: Rear Differential Slipping
thanks.
Crazy,
You should tighten the diff so that when you hold the right rear tire and the spur gear, the left rear tire should turn with a fair amount of force. I've had success with TC3 diff spring, it seems to hold the setting much better than the stock spring. Give that a try, and let us know....
I'm still going to try using AE diff parts like Doug has, but move the spring and the locknut to the long diff outdrive side. Should have a result by this weekend.
Buddha
Old 05-12-2004, 01:36 PM   #4553
crazy4rc's Avatar
Default Re: Re: Rear Differential Slipping
thanks for the quick reply my friend. if you can also send me the TC3 parts number you used, i would appreciate it.
Originally posted by RCBuddha
Crazy,
Buddha
Old 05-12-2004, 01:42 PM   #4554
RCBuddha's Avatar
Assoc #6582 Spring
Old 05-12-2004, 02:06 PM   #4555
pucho's Avatar
Send a message via AIM to pucho
If your carefull you could use a drop of solder to keep it from moving from side to side.
pucho is offline   Reply With Quote
Old 05-12-2004, 02:08 PM   #4556
pucho's Avatar
I used these parts:
Assoc #6582 Spring
Assoc #6575 T-nut and Bolt
The bolt is a hex socket head and the threaded area is larger but the shank area is the same size as the stock bolt so the stock thrust washers work fine. The t-nut is an nylon outside/steel inside type used in offroad so I thought it might hold up better than the nylon style lock nut. I know on the Losi cars we switched to the monster diff nut from the nitro truck as well and worked great.
I agree WYD, the diff feels like it should slip like mad but its totally locked.
these are parts they where posted a few pages back.
Old 05-12-2004, 02:29 PM   #4557
coastaltony's Avatar
Lets try a pic of a black Trinity TC3 bumper
Meucci pool cue collector
coastaltony is offline   Reply With Quote
Old 05-12-2004, 02:30 PM   #4558
rc-zombies's Avatar
wow... in wide-screen...
that bumper should absorb some impact and save your diff gear...
Old 05-12-2004, 02:34 PM   #4559
I asked Olympus about this and they told me to use the lowest resolution, but it is still 16/9 format.
Old 05-12-2004, 02:57 PM   #4560
JusBox's Avatar
Has anyone used spacers other than the ones in the kit for the pivot blocks? All I have are two silver pieces so I was thinking to use some spacers from my R2. They're large round washers in various thicknesses. I don't think it'll cause any issues but any comments on this?
JusBox is offline   Reply With Quote
