Like Tree6Likes
Old 05-12-2004, 08:51 AM   #4531
Send a message via Yahoo to Doug Gaut
I used these parts:
Assoc #6582 Spring
Assoc #6575 T-nut and Bolt
The bolt is a hex socket head and the threaded area is larger but the shank area is the same size as the stock bolt so the stock thrust washers work fine. The t-nut is an nylon outside/steel inside type used in offroad so I thought it might hold up better than the nylon style lock nut. I know on the Losi cars we switched to the monster diff nut from the nitro truck as well and worked great.
I agree WYD, the diff feels like it should slip like mad but its totally locked.
Doug Gaut is offline   Reply With Quote
Old 05-12-2004, 08:53 AM   #4532
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Doug I will have to try the T-nut setup you used. I bought the parts but since my diffs are nice right now I hate to tear them apart.
ST Racing Concepts (STRC)
Old 05-12-2004, 08:56 AM   #4533
rayhuang's Avatar
Ditto here. I have two t-nut set-ups ready to go into the Pro4-but so far so good with just the AE spring in it.
Definately putting them into the diffs on next rebuild.
Old 05-12-2004, 09:07 AM   #4534
raving-monkey's Avatar
Send a message via MSN to raving-monkey
whats with this thing about diffs coming loose?
my diffs haven't come loose ever.
ime running the front diff to now and that is still as tight as i set it when i had run it in.
so i dont see where the problem is coming from???
raving-monkey is offline   Reply With Quote
Old 05-12-2004, 09:16 AM   #4535
wyd
Tech Legend
wyd's Avatar
Not every car will have the problem with the diffs coming loose. Some do and some don't. Mine seemed to be ok but I changed one to see if I saw a differance. The Assoicated spring is stiffer so you need to tighten the diff less to get the same results as the HPI spring. Not a big problem but somthing to try if you do have a problem.
Old 05-12-2004, 09:33 AM   #4536
rayhuang's Avatar
LIke WYD says-might not be a problem for all and also being able to lock it with less tension should provide higher performing diff.
Ray
Old 05-12-2004, 10:03 AM   #4537
rc-zombies's Avatar
Default Rear Bumper
I had a left over TC3 rear bumper...
with some minor cutting and drilling... it will fit.
good part is it's 2.5mm thick... so no spacers are needed...just the pivot blocks.
Old 05-12-2004, 10:18 AM   #4538
pucho's Avatar
Send a message via AIM to pucho
You better check your diff because all diffs take a seat after your first few runs, and they will need adjustment. One advantage to using the AE bolt is that it's a hex head and that makes it easier to adjust. Also and other problem I had was that the nut was slipping inside of the plastic holder on one of my diffs, using the AE nut takes away the chances of that happenig.
rc-zombies: Looks nice, but thats weight your adding there. I know the car is undeweight but you could use that weight to better balance your car.
pucho is offline   Reply With Quote
Old 05-12-2004, 10:20 AM   #4539
rc-zombies's Avatar
Weight... it's plastic and lighter or equal to the pivot block spacers....
Old 05-12-2004, 10:25 AM   #4540
pucho's Avatar
It's not much but it's some, What I have seen is most tc3 drvers end up taking it off NEways.
Old 05-12-2004, 10:27 AM   #4541
rc-zombies's Avatar
I'll probably take it off too... I had nothing better to do last night....
this is just for those who are concerned about rear end protection....
Old 05-12-2004, 10:29 AM   #4542
rayhuang's Avatar
YOu-know-if there werent kids here......
Old 05-12-2004, 10:39 AM   #4543
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Thats all you needed to say..
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 05-12-2004, 11:00 AM   #4544
wyd
Tech Legend
wyd's Avatar
Man I go to lunch and come back and you guys all have you minds in the gutter. Nice!!!!!!
Old 05-12-2004, 12:29 PM   #4545
just checked my diffs and they are the same as they where when i set them.
if they do start to come loose i will resort to the AE spring and nut.
thanks guys
matt
