Like Tree5Likes
Old 05-09-2004, 01:30 PM   #4456
raving-monkey's Avatar
Send a message via MSN to raving-monkey
hi guys.
ran my pro4 last night with not very good results.
in the first heat form about 30 secs in my motor started braking/accelerating on its own.
it wasn't just in certain places on the track, it was everywhere.
i changed to a crystal all the way at hte other end of the scale (695 to 965) and the same problem happened.
but the weekend before i didnt have any problems like this, using the same motor.
so i was wondering if any of you guys had similar problems, or maybe know what the cause is.
here is a pic to show where abouts i put the rx, esc etc.
bear in the mind this is the first time i have ever had this problem.
raving-monkey is offline   Reply With Quote
Old 05-09-2004, 01:53 PM   #4457
Super Steve's Avatar
Send a message via AIM to Super Steve
something is very wrong, sounds like receiver or ESC may be damaged
Super Steve is offline   Reply With Quote
Old 05-09-2004, 03:59 PM   #4458
lazyboy's Avatar
Send a message via AIM to lazyboy
i had the exact problem 6 months ago. if ur not running that novak capcitor they reently released thats now on all there gt7, i recamend getting one, it will fix all ur problems , if u have one already get another just incase the first on failed
lazy
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 05-09-2004, 04:10 PM   #4459
it looks liik ehe runs vega V3 not GT7
Old 05-09-2004, 05:12 PM   #4460
hmm, so maybe its my ESC that is faulty?
i was told earlier that the V3's often toast them selves like the GT7's sometimes do, is this a common problem with V3's?
any solutions that i could give a go?
thanks
matt
Old 05-09-2004, 05:23 PM   #4461
sorry, just checked that pic and noticed you cant see the electrics.
2 mins and i will get one so you can see the electrics.
Old 05-09-2004, 08:06 PM   #4462
cHckbOY5's Avatar
Send a message via AIM to cHckbOY5
for the steering plate, how tight do we screw the screws, if i make it tight, the steering doesnt feel free, so do i jsut tighten it as much as long as its free?
cHckbOY5 is offline   Reply With Quote
Old 05-09-2004, 09:52 PM   #4463
tc3 racer sc's Avatar
Default ffinally finish my pro 4
hey guys finally finish my pro 4 it run very smooth out in a parking lot just trying to get the feel of the car seems to be fast the real test will be saturday on the track, but i did notice that the spur gear is warp it must been like that out the box , and also i just recived the front diff to run instead of the one way i need to get use to, overall it get there also for stock where should i locate my shocks on the arm in the middle or out like the book says on rear/ front
tc3 racer sc is offline   Reply With Quote
Old 05-09-2004, 09:55 PM   #4464
Default Re: Which Rims to Run
Originally posted by morosis
I've been racing the Pro 4 for a few weeks and just love this car. My only problem is my HPI (dish)or Take-off rims seem to rub on the shock ends and camber linkage ball cups. What does everyone one else run for rims. Or should I bite the bullet and just move the ball cups in like I did with the shocks.
i notice that problem to just testing my car b4 i ran it in the parking lot the end of the shock ball cup rubbing on my take off tires to
Old 05-09-2004, 09:58 PM   #4465
rc_square24's Avatar
the steering shouldnt be tight no matter how tight u screw the screw cuz it runs on bearings, but if the screw doesnt go in straight then itll tighten the steering so make sure its straight.
as for gear warp i also noticed that on my stock spur, but didnt happen when i replaced it with another one. i tihnk the best way to prevent is to crosspattern tighten it.
if the bottom shock pos. hits the rim then just scrape some material off the ball end, change the pos. for handling finetuning.
rc_square24 is offline   Reply With Quote
Old 05-10-2004, 01:54 AM   #4466
Fire's Avatar
all 4 ball cups of the camber tie rods rub the speedmind rims too
Fire is offline   Reply With Quote
Old 05-10-2004, 06:21 AM   #4467
rayhuang's Avatar
Default Carpet
Hey,
Has anyone been running on carpet with foams? Got any new observations or learned anything new?
Ray
Old 05-10-2004, 06:27 AM   #4468
Skill's Avatar
I run on carpet with foams, I've been used to having big difference of shore ratings front to rear on my Pro 3, but with my Pro 4 I can run the same shore rating all round the car.
I was told to take all the spacers out of the suspension mounts to lower the roll centre as much as possible, this let the back end come out a little for really tight corners and made it handle really well.
Still running stock suspension mounts, springs, oil, no sway bars, changed the shock positions a little, but that's just about it.
Skill is offline   Reply With Quote
Old 05-10-2004, 06:37 AM   #4469
rayhuang's Avatar
skill-I am planning on another test night with my Pro4 soon. I have also dropped my hingepins back ont the chassis and nopw that I have the choice of 1, 1.5 and 2 deg front and rear toe in., I have a lot more to test.
Ray
Old 05-10-2004, 06:51 AM   #4470
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
Trader Rating: 14 (100%+)
Ray: my carpet test start this week....
I am starting with the stock set-up to get a baseline....
However, the track I run will be a little different than most.
It is an ozite oval with a roadcourse in the middle.
So a one-way may be faster due to the big sweepers
I do have a good baseline to compare against my TC3 & XXXs.
TC3 was better without a one-way, XXXs was better with.
Tre's
TnT-Fx Custom Graphics
www.tnt-fx.com
Tres is offline   Reply With Quote
