Old 05-06-2004, 02:42 AM   #4381
snoopy's Avatar
Originally posted by syntex1
your money would be better spent on bevel gears, hubs, arms and cvd's
I agree, i bought some of the rc square knuckles when the car first came out, thinking the standard might be a little weak like the tc3 ones. but the standard ones are strong enough not to need alloy ones. My alloy ones are still in their packet.
snoopy is offline   Reply With Quote
Old 05-06-2004, 03:11 AM   #4382
VenomWorldOrder's Avatar
quick question. do the tamiya derlin rear outdrives fit the pro 4?
VenomWorldOrder is offline   Reply With Quote
Old 05-06-2004, 05:48 AM   #4383
Super Steve's Avatar
Send a message via AIM to Super Steve
snoopy, want to sell me your aluminum ones?
I broke my knuckle first outing aluminum knuckle is very hard to bend I find.
venom, I doubt it but you can always try
Super Steve is offline   Reply With Quote
Old 05-06-2004, 08:21 AM   #4384
raving-monkey's Avatar
Send a message via MSN to raving-monkey
i think....a BIG think HPI have some delrin outdrives in production.
as hara was using some at the pre worlds....not sure if they were pro3 ones or actually pro4 ones in development.
raving-monkey is offline   Reply With Quote
Old 05-06-2004, 08:59 AM   #4385
Skill's Avatar
I very much doubt that they will be the Pro 3 ones, but possibly.
Does anyone know if they made Pro 2 delrin outdrives because the Pro 4 ones aren't far at all off the Pro 4 ones.
As said before, it will be more likely to be a HB part as the Pro 3 one was too.
Skill is offline   Reply With Quote
Old 05-06-2004, 09:16 AM   #4386
rayhuang's Avatar
A BMI equipped, but all plastic parts Pro4 put a whoopin on everyone at our track last night (carpet/foam tires). The only mods to it was the HPI 2.0 rear toe-in block. It was the racers first time with the car and he lapped consistently as fast as anyone has run on this layout with a Tc3. Even the sponsored guys. The Pro4 rally turned some heads last night.
Ray
Old 05-06-2004, 09:37 AM   #4387
pucho's Avatar
Send a message via AIM to pucho
Ray:
I got to put a pack on my 4 last night I can say that the chassis and the tow block have made a maked improvement on a good car to begin with. BTW who was the driver?
Luis
pucho is offline   Reply With Quote
Old 05-06-2004, 09:37 AM   #4388
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
yeah ray, pucho,
i didn't get to watch jimmy hermann run since i was chasing him all night, but he was more consistent last night than i have ever seen him. and every bit as fast. neither one of us contacted anything, and he had 8 seconds on me after the five minutes was up.
this was the first hurting that a pro4 has delivered at the gate.
things are looking up.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 05-06-2004, 10:32 AM   #4389
X2
X2's Avatar
Default Spring rates
Hi all. does anybody know the Pro4 spring rates in lb/in ?
If somebody does it would be a great help, Cheers
X2 is offline   Reply With Quote
Old 05-06-2004, 10:37 AM   #4390
rc-zombies's Avatar
Default Re: Spring rates
To convert gr/mm to lb/in
gr/mm divided by 454 x 25.4 = lb/in
from lb/in to gr/mm
lb/in divided by 25.4 x 454 = gr/mm
hope this helps.
Old 05-06-2004, 10:53 AM   #4391
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
...and HD ballcups
Turbo Joe is offline   Reply With Quote
Old 05-06-2004, 10:58 AM   #4392
Turbo Joe's Avatar
Default Thanks Zombie and Pops!
For the advice. I started to build a ball diff out of spares I have here, since I have Pro 4 outdrives and an extra gear and a bunch of everything else from the 2 and 3...something went awry (haven't checked it out yet) and I ended up with a spool...LOL
Sooo....how are spools for low traction?
Whatever I did wrong, it locked solid in 1-2 turns of the screw.
Old 05-06-2004, 10:59 AM   #4393
X2
X2's Avatar
Default Re: Re: Spring rates
from lb/in to gr/mm
hope this helps.
Yes Thank you
Old 05-06-2004, 11:20 AM   #4394
rc-zombies's Avatar
Default Re: Thanks Zombie and Pops!
maybe you forgot to put in the thrust bearing spring... I built one up from spare parts as well..and I forgot the spring...and it locked up...
Old 05-06-2004, 12:05 PM   #4395
Turbo Joe's Avatar
Default Re: Re: Thanks Zombie and Pops!
The spring is in there...I might have used the wrong bearings. Makes a really nice spool, though.
Would a spool work in a low traction parking lot?
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
