Old 05-05-2004, 05:05 PM   #4366
Super Steve's Avatar
Send a message via AIM to Super Steve
HAHAHA
as if tower put that in their description!
Super Steve is offline   Reply With Quote
Old 05-05-2004, 05:51 PM   #4367
popsracer's Avatar
Originally posted by Super Steve
As far as i know, isn't ti stronger then aluminum weaker then steel, lighter then steel but heavier then aluminum?
You are correct.
The Ti used in most R/C Car/Truck parts applications has less tensile strength than hardened Steel and more than low grade Steel.
However, because it is lighter than Steel, you can make the part(s) slightly stronger and still achieve a weight savings.
popsracer is offline   Reply With Quote
Old 05-05-2004, 06:57 PM   #4368
hpi3270's Avatar
Send a message via AIM to hpi3270
[QUOTE]Originally posted by Kevin K
Just get a whole diff kit.....HPI part number 75141....... Ball Differential Set for Pro 4 [/QUOTE
They come in a kit in whole put you do have to put it together. I got mine from www.stomerhobbies.com here is the link https://www.ssl-stormerhobbies.com/c...pl?pn=HPI75141 but it looks like there out of order!
hpi3270 is offline   Reply With Quote
Old 05-05-2004, 07:05 PM   #4369
thanks guys for the info.
Cheers,
Mossie
Mossie is offline   Reply With Quote
Old 05-05-2004, 07:23 PM   #4370
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
They did, check my link in that post.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 05-05-2004, 07:33 PM   #4371
rayhuang's Avatar
HEY ALL,
I changed my front arm sweep to one degree and my rear toe in to 2 degrees and it was definately better in some aspects, but I AM
it appears still way off the pace. I am a bit stumped. I think the cars good and the motor and battery are very good. Heck-I even think I am driving decent lines and hitting the apex's. But still I lapped a 0.9 off the fastest lap recently. And thats HUGE!!!
I need to sit down and run pack after pack soon and make one change at a time till I find the key.
What i found is the car not as smooth through transitions so I am going to change to #2 ackerman position. Maybe with the changed arm sweep-its affected the ackerman.
Awaiting more testing,
Ray
Old 05-05-2004, 08:06 PM   #4372
lol...
that's why i was laughing... i still can't believe it!
If your car is handling twitchy during transitions, maybe yous shocks are too hard?
Old 05-05-2004, 08:30 PM   #4373
rc_square24's Avatar
new tobee part, one peice input shaft and spur adapter in aluminum insted of Ti in previous models.
rc_square24 is offline   Reply With Quote
Old 05-05-2004, 08:31 PM   #4374
FR input sold as one set
Old 05-05-2004, 08:31 PM   #4375
oops sorry from RC Square
Old 05-05-2004, 08:36 PM   #4376
Entropy's Avatar
So is that a Tobee or RC Square part??
Coz I have the Tobee part that comes with the 2 shafts and some shims. Without the spur adaptor.
Entropy is offline   Reply With Quote
Old 05-05-2004, 08:40 PM   #4377
it's rcsquare
Old 05-05-2004, 10:53 PM   #4378
Has anyone bought the front knuckles by jet or square. Is there a difference. Are the square ones that much better to justify the large price difference?
Cheers,
Mossie
Old 05-06-2004, 02:11 AM   #4379
Frank McKinney's Avatar
A better question to ask is why get aluminum knuckles at all - they're heavier and more expensive. If they bend you're out of luck and will have to go with the plastic knuckles anyway.
Minimal signature to save screen space! Big sigs suX0r
Frank McKinney is offline   Reply With Quote
Old 05-06-2004, 02:36 AM   #4380
Cheers,
Mossie
your money would be better spent on bevel gears, hubs, arms and cvd's
syntex1 is offline   Reply With Quote
