Old 05-04-2004, 07:43 PM   #4321
popsracer's Avatar
Originally posted by lazyboy
question? whats the deal with the wireing with the batts?? from last couple of pages ppl have been saying stuff about not having the positive bar on the right hand lower coner(depends on how u look at the car)i ran my tc3 with a demon chassis and i ran my losi with the bars in same spot and well if i need to change could someone explain why?? thanks lazy
pro4 rules
As someone else has explained, the shortest path usually means slightly less resistance. To change the orientation, flip the pack lengthwise and resolder the end terminals (or plugs) so they are right side up again. Could probably save a few inches in Battery wiring this way.
popsracer is offline   Reply With Quote
Old 05-04-2004, 08:03 PM   #4322
lazyboy's Avatar
Send a message via AIM to lazyboy
thanks for the info, also how long do your guys/gals cars drivtrain spin for with the motor out??? ive got 5-6+ seconds on it and was jw
lazy
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 05-04-2004, 08:29 PM   #4323
Entropy's Avatar
I honestly think there is no difference other than it keeps the wiring neater.
This is because the negative wire would still have to cross over to the other end of the battery pack. What we will have in the end is a more or less same lenght of wiring between the batteries and the esc/motor.
So its really a choice between a longer positive or negative wire.
If anyone can dispute this, please enlighten me, thanks.
Entropy is offline   Reply With Quote
Old 05-04-2004, 09:18 PM   #4324
hpi3270's Avatar
Send a message via AIM to hpi3270
race hpi !!! the PRO4 Is awesome so far!!! no problems i did go to 48 pitch gears just because i like working with 48 pitch gears better!
hpi3270 is offline   Reply With Quote
Old 05-04-2004, 09:55 PM   #4325
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
lazy
Lazy - it will free up more when you run it. Mine spins for a long time.
As far as wiring, You don't need to change your battery packs. I run my positive lead back by the left rear tire, with the negative towards the front.
The length of wire + / - doesnt matter which is longer, just as long as they are both as short as possible.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 05-04-2004, 10:52 PM   #4326
RCBuddha's Avatar
Trader Rating: 33 (100%+)
My wiring configuration has more to do with the discharge trays that I use. My trays are polarized, so i have to run my packs the way I posted.
RCBuddha is offline   Reply With Quote
Old 05-04-2004, 10:59 PM   #4327
RCTech Member #2
TSR6's Avatar
I just run mine the way I do because when I started running electric sedans, I bought some used cells to get me started. They were wired this way, so I've done all my packs like that since.
I bought my promatch tray to match my cell position.
Troy
RCTech Member #2
Old 05-04-2004, 11:02 PM   #4328
RCBuddha's Avatar
Yup, i've been doing my packs this way since '87. The reason? I started in offroad, and packs wired in this way put the terminals closer to the ESC on an offroad car.
Old 05-05-2004, 02:03 AM   #4329
rc_square24's Avatar
Erik Shauver- are the bearings that came with the pro4 microlon treated?
rc_square24 is offline   Reply With Quote
Old 05-05-2004, 02:15 AM   #4330
Entropy's Avatar
I have a question, will the anodised center drive shaft short the batteries if the batteries ever shift out of the slots and come into contact with it??
I'm contemplating reversing my battery placement (I dun wanna resolder 8 packs!) so I can get the positive end of my side by side pack to be closer to the motor but it will result in the contact bars on the inside (closer but not touching the shaft) instead of along the side of the chassis.
Old 05-05-2004, 04:50 AM   #4331
Skill's Avatar
Where can I find the pics from the World's Warm Up race? I'm very intruiged to see these new bits
Skill is offline   Reply With Quote
Old 05-05-2004, 07:25 AM   #4332
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
Trader Rating: 14 (100%+)
Entropy: yes it can.
Tre's
TnT-Fx Custom Graphics
www.tnt-fx.com
Tres is offline   Reply With Quote
Old 05-05-2004, 08:16 AM   #4333
Regional Moderator
Darkseid's Avatar
Hey guys...
Anybody got a link to RainbowTen's site?
TLR 22...Tamiya F104...
Old 05-05-2004, 08:22 AM   #4334
raving-monkey's Avatar
Send a message via MSN to raving-monkey
i dont think it could as if you ever use a anodised heatsink on your motor...and it shifts upto the endbell and it touches -ve and +ve it doesn't short them out.
but only thing to do is try it...with the person u hate most batteries
raving-monkey is offline   Reply With Quote
Old 05-05-2004, 08:26 AM   #4335
hpi3270's Avatar
Entropy-It looks close i know but i have side by side batt packs and i never had a problem with that yet what i did is there is 2 holes on batt side in the chassie and i put in to screws with bolts so they wont hit the shaft try this.
SEO by vBSEO 3.5.0
