Hpi Pro 4
#4277
if you look carefully, it is a heatsinked motor mount so maybe its a prototype that is in development.
as he still has the stock purple thing that goes between the mount and top deck.
#4278
cant you just buy a normal washer the same size?
like from a hardware store or something?
#4279
i dont know, the end seems different
#4280
do you mean the 'steering block bushing'?
#4282
The disconnected was probably just to run without a swaybar. I do that all the time just to make a quick run without totally removing everything.
-Troy
-Troy
#4284
it doesnt let me delete my posts
i dont even have a delete button
#4285
Eh, Some boards allow you to use it, some don't. Only the Admin/Moderator delete buttons actually work though.
#4286
how come i dont even have a delete button then???
#4287
only when you go into the "edit post" mode.
#4288
i finally got a pro4 after puting up with the losi and its crap, if anyone could slap down a basic setup for stk rubber on carpet that be awsome
lata lazy
lata lazy
#4290
oooo i found it now TSR6.
ty
ty
