Old 05-03-2004, 07:00 AM   #4216
cartmen34's Avatar
Originally posted by cHckbOY5
how should i get my batts built, stnadard or reverse?
also, how else can i cut the ear of the servo without a dremel?
If you don't have a dremel I've found that wire cutter pliers work pretty well for snipping the ears off of servos. Just snip off the one ear you want to remove and then clean it up with a hobby knife or file.
cartmen34 is offline   Reply With Quote
Old 05-03-2004, 08:16 AM   #4217
VenomWorldOrder's Avatar
NO DON'T DO THIS!! i had a ko propo super duper servo and when i used this method it cracked the case. i fixed the case by sealing it with a bit of CA glue but it looks hacked now. use a small hacksaw and cut it in a controlled manner.
VenomWorldOrder is offline   Reply With Quote
Old 05-03-2004, 08:23 AM   #4218
cartmen34's Avatar
This may be true, as the ko servo case material may be more brittle than I'm used to. However, I've been doing it for years on my Hitec and Airtronics servos with zero cracking and no side effects.
Do it one small snip at a time, don't try to take the whole thing off in one big chunk.
Old 05-03-2004, 08:26 AM   #4219
raving-monkey's Avatar
Send a message via MSN to raving-monkey
i used side cutters on my 2123 and it didnt crack.
but then i used a dremel to clean it up at my dads
raving-monkey is offline   Reply With Quote
Old 05-03-2004, 08:30 AM   #4220
rod_b's Avatar
Send a message via AIM to rod_b
This works well if you have a small set with sharp edges. A large and/or dull pair will make matters worse.
rod_b is offline   Reply With Quote
Old 05-03-2004, 08:38 AM   #4221
rayhuang's Avatar
a hacksaw blade is the safest and best way to cut-off the ears on a servo. A cut-off wheel on dremel can melt the plastic which makes it even more brittle and side-cuts can break the case.
Who doesnt have a hacksaw blade somewhere in the garage!!
Old 05-03-2004, 10:32 AM   #4222
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
You never want to use CA around electronics, It can conduct electricity. ShoeGoo is a much better option.
I used a pair of pliers to break off the tab, then an exacto to clean it up.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 05-03-2004, 10:58 AM   #4223
rc-zombies's Avatar
Originally posted by popsracer
wyd;
What is so special about the Novak harness other than having the HF Schotty (sp) installed?
I have both the wire harness and HF Schotty seperately...
nothing really special about the harness... I just solder the schotty diode directly onto the motor...
Old 05-03-2004, 11:02 AM   #4224
rc-zombies's Avatar
Default Re: Springs
Originally posted by Mossie
Hey guys,
Is there a spring set for the Pro4? If so where can I get it?
If not is there another cars springs that will fit on e.g. TC3?
Cheers,
Mossie
the new HPI Pro4 springs are available now from Rainbowten in Japan.. here are the ordering info
3023430206545,HPI,380YEN,6545 RACING SHOCK SPRING 14*25*1.5MM 5.75 COILS(WHITE),
3023430206546,HPI,380YEN,6546 RACING SHOCK SPRING 14*25*1.5MM 5.5 COILS(YELLOW),
Old 05-03-2004, 11:04 AM   #4225
Skill's Avatar
Not trying to insult you, but how come in the manual it says the CA the battery slots to stop the batteries from shorting out?
Skill is offline   Reply With Quote
Old 05-03-2004, 11:12 AM   #4226
RCTech Member #2
TSR6's Avatar
Sorry, I was mistaken!
The glue & the fumes causes corrosion to circut boards. Thanks for questioning me.
http://www.teamnovak.com/products/in...CA_warning.htm
Troy
RCTech Member #2
Old 05-03-2004, 11:20 AM   #4227
Skill's Avatar
Lol, that makes more sense now
I was starting to get worried about my batteries safety
Old 05-03-2004, 11:22 AM   #4228
i runa vega v3 esc. and someone told me the shottky built into the speed controller can often fail. They said to be safe fit one direct to the motor.
so i did, and i went to try it and the car didnt go at all. i had it on the right way so thats not a problem.
might of i had a faulty shottky or is it safe just to go along with the one built in?
Old 05-03-2004, 11:22 AM   #4229
RCTech Member #2
TSR6's Avatar
..eh.. what can I say.
My alarm didn't go off this morning, so I just woke up, and am a little groggy.
Troy
RCTech Member #2
Old 05-03-2004, 11:46 AM   #4230
here are some pics of my pro4.
i know the wires aren't the right colours for +ve and -ve but never mind
here goes
SEO by vBSEO 3.5.0
