Old 04-21-2004, 10:07 AM   #3781
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Originally posted by RC Driver Gary
If a hack like troy can keep his drivetraine together, it should be just fine for the rest of us "non-hammers" out there.
At least I can build a car without breaking diff cases.
....and rubbin is racin'
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 04-21-2004, 11:12 AM   #3782
RCGaryK's Avatar
Actually, Walter did it...Or Erich..when reassembling the car after taking it apart for photos
Yeah, rubbing is racing, but that means you rubbing another car, not the boards.
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 04-21-2004, 12:44 PM   #3783
Send a message via Yahoo to Doug Gaut
THANKS TURBO JOE!!!!!!!!!!!!!
Doug Gaut is offline   Reply With Quote
Old 04-21-2004, 12:51 PM   #3784
RCTech Member #2
TSR6's Avatar
Thats not what Erich told me...
Troy
RCTech Member #2
Old 04-21-2004, 12:54 PM   #3785
X2
X2's Avatar
Default Tweak
Hey Cartmen,
I have sorta solved this problem, I found that it was my rear diffcase. I got some sand paper, put it on a flat surface and sanded down the top diffcase where it makes contact with the bottom one (If u get what i mean?) untill it was perfectly flat, ull be suprised at how 'warped' these are.
Then, seing as the diffcase now clamps down on the bearings harder, i dremelled off the little lip in the bearing holes.
It has made my chassis flat but my car still seems very easy to tweak, the slightest twist in any direction an there u go --> Tweak
Does anybody else have this problem? I think ill try some new diffcases.
X2 is offline   Reply With Quote
Old 04-21-2004, 01:05 PM   #3786
Skill's Avatar
I noticed that my front diff case was quite warped and did not go together very well...the rear one seems to be OK but for sure the mouldings on them aren't too good. Even with this distortion my car seems to tweak out ok when screwing the screws down with pressure on the car.
Skill is offline   Reply With Quote
Old 04-21-2004, 01:06 PM   #3787
cartmen34's Avatar
Default Re: Tweak
Originally posted by X2
Hey Cartmen,
Interesting....very interesting....
and to answer your question, no, my car does not re-tweak at the slightest twist. It stays tweaked no matter how much twisting I do!
cartmen34 is offline   Reply With Quote
Old 04-21-2004, 01:07 PM   #3788
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
I have the BMI 3mm top and bottom plates and it is very stiff. It ialmost impossible to twist in my hands. A ton stiffer than the stock setup. I had a huge wreck this week that ripped a few parts off my car. Good thing is the car is not tweaked. Now to just find some spare parts.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 04-21-2004, 01:09 PM   #3789
cartmen34's Avatar
It's starting to make me wonder a little though about this car... $280 + for a car that immediately needs $100 worth of new chassis plates to resist tweaking?
Old 04-21-2004, 01:17 PM   #3790
wyd
Tech Legend
wyd's Avatar
Alot of cars that cost that much seem to have this problem. The Pro 4 is not and prpbably won't be the last one with this problem. I think it is part of having a double deck chassis though. My Yoke did it and a bunch of the Schumacher cars I have had (98 SST, 99SST, Axis, Axis2, and my Mission to name a few. Also my Pro2 and my TC3 when the chassis got too hot one too many times and tweaked a little. I know the Xrays do as well because my buddy has ran them for over a year and if he takes a big shot or hits the wall hard it is tweaked a little.
Good thing is it seems to be easily fixed by loosening the topdeck screws and twisting it back.
Old 04-21-2004, 02:27 PM   #3791
wyd, Ultimate Hobbies still had a few arms left when I called an hour ago.
Old 04-21-2004, 02:33 PM   #3792
RCBuddha's Avatar
Trader Rating: 33 (100%+)
In all honesty, having a 3mm chassis isn't necessarily going to solve the tweaking issue. WYD has it correct, every car develops a tweak of some sort. NO car is totally immune. I'm sure neither BMI or PRP would be willing to guarrantee that their chassis will be "tweak proof".
RCBuddha is offline   Reply With Quote
Old 04-21-2004, 02:37 PM   #3793
cartmen34's Avatar
So...I can't help but notice you gots' yoself' one of those fancy schmancy BMI chassis for the Pro4. IYO, would you say this drastically helps the tweak issues on the pro4? As much as I hate spending this much on one car, I'll do it because this car has so many other great features.
Also...does anybody know if BMI is selling them to the general public yet?
Old 04-21-2004, 02:39 PM   #3794
cartmen34's Avatar
oops, buddha answered my ? before I got a chance to ask it!
Old 04-21-2004, 03:13 PM   #3795
Beeb's Avatar
Send a message via AIM to Beeb
My car doesn't need a new $100 chasis.
I'd just like to thank the powers that be for giving me one of the few kits out there that's perfect straight from the box.
(And if you can't tell, I'm being sarcastic)
Beeb is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
