Like Tree5Likes
Old 04-20-2004, 01:36 AM   #3736
Frank McKinney's Avatar
Originally posted by rc-zombies
You're right...taping does get old... I have several instances when new strapping tape have broken during a race. with the molded battery strap I have piece of mind that batteries will not fall out or hit the drive shaft... hope to get the aluminum one as soon as it's back in stock at RcModel...
If you're concerned about having as low a weight as possible or want to have as low a CG as possible (if you're adding weight anyway), taping is the way to go. I think Erik has said you can remove about 20g of weight right off the bat if you take off the battery strap, plus removing it helps improve the L-R balance of the car before you even have to add weight.
If you can't get a file in the tape slot, use a Dremel. For a short-term solution wrap some tape around the slot so you build up a cushion. This will prevent the tape from breaking in a crash.
Also, I've seen a ton of Pro 4 racers having problems with their batteries coming out, or using the plastic pieces on the chassis that are meant to keep the stick pack batteries in place. Many times they aren't filing down the chassis and/or they are using the battery strap but the clip posts are too high. Just use the cross wrench to tighten the posts down a half-turn at a time until the batteries fit snug in the battery slots. This also helps hide those bent battery bars.
Minimal signature to save screen space! Big sigs suX0r
Frank McKinney is offline   Reply With Quote
Old 04-20-2004, 03:58 AM   #3737
Originally posted by son_tgs
Hi,
Any news on the PDF setup-sheet with interaction?
Best Regards
Thomas Son
HPI Pro 4 - TEAM OMH
Denmark
Anyone ???
son_tgs is offline   Reply With Quote
Old 04-20-2004, 04:35 AM   #3738
cHckbOY5's Avatar
Send a message via AIM to cHckbOY5
man i was gonna buy some more parts from tower then the coupon i was gonna use didnt work anymore... i guess its just one time use
cHckbOY5 is offline   Reply With Quote
Old 04-20-2004, 04:51 AM   #3739
Super Steve's Avatar
Send a message via AIM to Super Steve
I also used those foam bumper tape piece under the batt strap which seemed to help holding the battery pack on there.
But now i use strapping tape
Super Steve is offline   Reply With Quote
Old 04-20-2004, 06:34 AM   #3740
VenomWorldOrder's Avatar
my remedy to stop the batteries flying out looks hacked but works. i attached a small peice of carbon fibre to the stick pack screw holes. this made a small extension, i then made a screw hole on this CF peice and used one of the servo mounts aS a stoper. i have the alloy servo mounts.
VenomWorldOrder is offline   Reply With Quote
Old 04-20-2004, 07:47 AM   #3741
coastaltony's Avatar
Frank or Venom
I think I have a handle on what you
both are saying.
I was gonna run a thin piece of servo
tape on the outer edge as a fence.got any pix?
coastal-tony@webtv.net
Meucci pool cue collector
coastaltony is offline   Reply With Quote
Old 04-20-2004, 08:40 AM   #3742
Trader Rating: 14 (100%+)
Default Tamiya toe blocks
Has anyone tried the Tamiya toe blocks off of the EVO III on the HPI car? I thought i saw something about them fitting a while back but I can't find it.
ALso, does anyone know what degree of rear toe these blocks are? all I can find are the A, B, C, and D listing. I'm looking for 0 an 1 degree blocks.
crisis641 is offline   Reply With Quote
Old 04-20-2004, 09:08 AM   #3743
Erik Shauver's Avatar
Erik Shauver is offline   Reply With Quote
Old 04-20-2004, 10:58 AM   #3744
cHckbOY5's Avatar
whats good starting pinion for monster stock on the pro4?
Old 04-20-2004, 11:03 AM   #3745
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
I'm no authority on *anything*, but I have a 34 in for SoCal (rubber) and I wasn't lacking for speed anywhere that my meager skills could use. It seemed to pull great on the straights and I could accelerate out of the tight spots with anyone in my class (Novice), and it stayed really cool.
Now if I could just stop hitting stuff.
Turbo Joe is offline   Reply With Quote
Old 04-20-2004, 11:10 AM   #3746
rc-zombies's Avatar
around 34T... geared to around 7+/- final drive ratio with the stock spur gear.
Old 04-20-2004, 11:20 AM   #3747
cHckbOY5's Avatar
k thanks
Old 04-20-2004, 11:21 AM   #3748
I have a 36 on now and
might try 37 next practice
session.
I'm running a Monster Stock that draws 12A @ 3V
Old 04-20-2004, 11:28 AM   #3749
cHckbOY5's Avatar
do u guys use the black or purple robinson pinions?
Old 04-20-2004, 11:29 AM   #3750
rc-zombies's Avatar
Other than color...They're both identical..
mine are all black...
