Like Tree6Likes
Old 04-19-2004, 03:37 PM   #3721
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Originally posted by xxxkat
The HPI diff kit does NOT come with bearings so you will need to pick up 2..
What bearings are you talking about? My two diff kits that I have both have bearings in them.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 04-19-2004, 03:53 PM   #3722
Send a message via Yahoo to Doug Gaut
Find any arms Ray?
Doug Gaut is offline   Reply With Quote
Old 04-19-2004, 04:05 PM   #3723
Erik Shauver's Avatar
Erik Shauver is offline   Reply With Quote
Old 04-19-2004, 04:11 PM   #3724
rc_square24's Avatar
Default oneway screw holes stripping?
will the holes on the aluminum housing stip easily if i go too far? its abit hard to feel it with the screw head goin in the plastic.
thanks
rc_square24 is offline   Reply With Quote
Old 04-19-2004, 04:16 PM   #3725
rc-zombies's Avatar
Default Re: oneway screw holes stripping?
thanks
If you really torque it down hard enough it will strip... if you have small 2mm washers..it will help distrubute the load..and the screw will not dig into the diff... also apply a little of the blue loktite on the threads...
Old 04-19-2004, 05:08 PM   #3726
EvilDriver's Avatar
Send a message via AIM to EvilDriver Send a message via Skype™ to EvilDriver
Hi all
I raced my pro4 last weekend for Mod onroad rubber tire race and I had a lot of glitches that day especially when I tried to go full throttle. anyone have the same problem ?
and another thing have any one have a setup for mid traction rubber tire. I looked through the forum and found one but It didn't state if it was high traction or low traction and I'm just wondering if any one have one.. I'm just trying to figure out the set up for the track..
and also have any one tried to run the pro4 with a high roll center to add more traction?
thanks
EvilDriver is offline   Reply With Quote
Old 04-19-2004, 05:21 PM   #3727
Oasis's Avatar
Trader Rating: 36 (100%+)
Erik the diff kit I bought did NOT come with any bearings,Anyways does David Poter still work for HPI ?
Oasis is offline   Reply With Quote
Old 04-19-2004, 06:19 PM   #3728
EvilDriver, I have ran on a slick concrete outdoor track and on a mid to high bite concrete track and the stock setup has worked awesome on both tracks. For the outdoor track I did drop to 40wt oil and raised the ride height to 5mm front and 5.5 rear but that was all it took. Oh, also moved the rear shock to the next to outside hole because the shock bottom was hitting the wheel.
Now on the indoor track I lowered the ride height to 4.5mm front and 5mm rear, went to 50wt oil.
I could be wrong but with the stock shims I would say the stock setup is almost a mid to high roll center versus no shims being low roll center.
I too experienced some glitches but once I added a couple layers of servo tape between the chassis and the receiver and also ran the receiver wire through some fuel tubing from the receiver to the antenna mast to keep the wire from directly touching the chassis I did not experience any more glitches.
Hope this helps.
Old 04-19-2004, 07:22 PM   #3729
I run Rebuildable Stock
No1 pistons F/R
70 wt oil fr
60wt oil rear
40/42 shore Fr
40 shore rear
try with or without sway bars
2dgree camber F/R
Rest is stock
Med grip tarmac
Barger is offline   Reply With Quote
Old 04-19-2004, 08:11 PM   #3730
popsracer's Avatar
Originally posted by Doug Gaut
What are you using for battery retention? I noticed with the stock brace that the battery could slide around a bit and possibly hit the drive shaft.
The Manual shows plastic spacers (73512) under the the Battery Strap screws (Z305).
If you omit the plastic spacers and tighten the screws all the way down, GP3300's in a side x side configuration fit nice and snug.
popsracer is offline   Reply With Quote
Old 04-19-2004, 08:28 PM   #3731
Thanks Popsracer. I will try that although I like the weight loss on the battery side. Taping does get old though.
Old 04-19-2004, 08:39 PM   #3732
rc-zombies's Avatar
You're right...taping does get old... I have several instances when new strapping tape have broken during a race. with the molded battery strap I have piece of mind that batteries will not fall out or hit the drive shaft... hope to get the aluminum one as soon as it's back in stock at RcModel...
Old 04-19-2004, 09:19 PM   #3733
popsracer's Avatar
Default Pro-4 sale this weekend
For all of you living in Southern CA & Nevada;
Just to let everyone know that the HPI Pro-4 will be on SALE at all of the 21 Hobby People store locations for the low price of: $269.99 usd. (reg: $299.99)
Fri - Sun. April 23rd-25th. (This is an In Store sale only, and not availible online)
Visit hobbypeople.net for store locations and hours.
Old 04-19-2004, 10:33 PM   #3734
rc-zombies's Avatar
Default Re: Pro-4 sale this weekend
That price is tempting... and I'll be in LA this weekend..taking my 2.5yo son to Disney...
Old 04-20-2004, 12:14 AM   #3735
cHckbOY5's Avatar
Send a message via AIM to cHckbOY5
u shoulda ordered from ultimate hobbies the other week or so, 259
cHckbOY5 is offline   Reply With Quote
