Hpi Pro 4
#3616
speedtech also has the tobee ones but they out of purple
#3617
Originally posted by son_tgs
Hi,
Any news on the PDF setup-sheet with interaction?
Best Regards
Thomas Son
HPI Pro 4 - TEAM OMH
Denmark
Hi,
Best Regards
Thomas Son
Denmark
#3619
well i can get some really cheap through my dads work as his work has a traders account witha fixing company down the road from his work place
#3620
woah....fastener-express.com is very very cheap......fixing company down the road from me dads work does about 100 for 3-4 pound depending on what size you get.
why #...would we need off fastener-express.com???
#3621
thats really cheap but ill rather get it sumwhere else where i can make good use of the shippin i pay
#3623
steve your car wont be going far until you add a few extra's
try using wheels nuts...they help loads
#3625
i can imagine someone thinking their leccy car is a nitro, they are stood on the rostrum making engine sounds....
do i see a coling hole thingy in the wind screen....ime sure you dont think its a nitro :O :|
i run 30mm foams on the back of my pro4
needs some 28's for front though, 30s dont fit
right ladies, its late (or early if u want to be fussy) so ime off to bed
#3627
sinking ship? i dont think so... its jsut about to get bigger ... places r sold out of the kit
#3628
#3629
any of you guys use the speedtech ti screw set? how are they?
#3630
does hpi make 1.5 and 2 degree blocks for the pro 4? i'm finding 2.5 degress rear toe too much.
also race on a slippery and dusty track which is very tight and technical, it has alot of transition corners (S type things) and high speed. my car is balanced in these sections but entering corners at high speeds it is taily. it kickes the rear end out and i loose a heap of momentum how do i get rid of this.
running stock setup with 60wt oil initially.
moved to associated reds front, greens rear, noswaybar at the rear and 2.5 rear toe and 2.5 deg camber all round but it still does it slightly sometimes. enough for me to slow down and be a hinderance to the faster drivers!
(tryed some of the pro 4 drivers setups from my track....no good for me )
