Like Tree5Likes
Old 04-12-2004, 01:44 PM   #3406
...anybody have an idea of what GT-Body or Pro10 Body might fit on the Pro4???
Ollymann is offline   Reply With Quote
Old 04-12-2004, 01:46 PM   #3407
rc-zombies's Avatar
none... the front shock towers are too high...
I tried to fit the new HPI NSX GT... no can do....
Old 04-12-2004, 02:08 PM   #3408
Send a message via AIM to Dougnuts55
What hop ups does the pro 4 need? Or is a stock one fine.
Im thinking instead of getting a bmi chassis for my tc3 might just get a pro4 but dont want to get one if i have to buy hop ups.
Doug
Dougnuts55 is offline   Reply With Quote
Old 04-12-2004, 02:10 PM   #3409
Send a message via AIM to True R/C Racing
Doug
Pro 4 Doesnt need hop-ups Really. A Hop-up thats sometimes good is a Aftermarket Chassis. BMI has good Feedback on theer pro4 Chassis.(Correct me if im wrong )
True R/C Racing is offline   Reply With Quote
Old 04-12-2004, 02:14 PM   #3410
noline's Avatar
I've just recently piked up a HPI Pro 4. Everything went well together but one problem, the drive train is all binding up can anyone tell me how to fix it so my drivetrain can run more free.Any help would be greatly appreciated.
noline is offline   Reply With Quote
Old 04-12-2004, 02:29 PM   #3411
raving-monkey's Avatar
Send a message via MSN to raving-monkey
mine was similar but after a couple of runs it all frees up. it just needs running in thats all.
raving-monkey is offline   Reply With Quote
Old 04-12-2004, 02:40 PM   #3412
rayhuang's Avatar
Mine is free as can be. Put three shims on the rear input shaft and make sure youve got them in the right place per the manual and not crunched by the diff cases.
Also-on the large shims on the outdrives-for a diff-I put two on the same side to pushl the diff AWAy from the crown gear. Hope that helps.
Ray
Old 04-12-2004, 02:52 PM   #3413
Super Steve's Avatar
Send a message via AIM to Super Steve
thats odd...
my was super free from the very begining
Super Steve is offline   Reply With Quote
Old 04-12-2004, 03:02 PM   #3414
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
Default Doesn't somebody make...
...a low-profile front shock tower? I could swear I just saw one the other day.
Here it is...would this work?
Low-profile tower for Pro-4
Scroll down...it's about half-way.
Turbo Joe is offline   Reply With Quote
Old 04-12-2004, 03:09 PM   #3415
rc-zombies's Avatar
Default Re: Doesn't somebody make...
2MM lower is not enough... the shock towers are approx 10-15mm too high for any NSX GT body to fit. Pro10 bodies will definately not fit no matter what shock tower you have in there...
the rear shock towers are too high as well....
why do you need a GT or Pro10 body anyways?
Old 04-12-2004, 05:13 PM   #3416
popsracer's Avatar
Default Binding Drive train
Guys;
Just wanted to add that even with my Tweak problem, my Drive-train is silky smooth even with everything tightened down.
popsracer is offline   Reply With Quote
Old 04-12-2004, 05:38 PM   #3417
cartmen34's Avatar
Ray
This is the exact same way I built mine. 2 shims spacing the gear away from the shaft gear. I found that trying to shim the diff with 3 shims made the drivetrain bind up when competely assembled.
Like ray's....it's free...like a bird.
cartmen34 is offline   Reply With Quote
Old 04-12-2004, 08:42 PM   #3418
cHckbOY5's Avatar
Send a message via AIM to cHckbOY5
is there a lot of room for electronics? or do i have to use the short servo?
cHckbOY5 is offline   Reply With Quote
Old 04-12-2004, 09:09 PM   #3419
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
It depends on the size of the electronics used. I have a shorty servo in my car but Im using a GT7 and I just wanted a little extra room. I will post some pictures of it later tonight or in the morning when I have time. But I would say that you should not have a problem with most electronics fitting....the GT7 is the biggest racing ESC out there I think and it would fit with a normal servo and receiver no problem.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 04-12-2004, 09:22 PM   #3420
JusBox's Avatar
didn't you sell your cuda because you didn't have time or money for it? now you're getting a pro 4?
JusBox is offline   Reply With Quote
