Like Tree5Likes
Old 04-11-2004, 09:12 PM   #3376
if you were into rcracing alot which car is better a tc3 or a pro4
HEWITT is offline   Reply With Quote
Old 04-11-2004, 09:14 PM   #3377
Super Steve's Avatar
Send a message via AIM to Super Steve
Come on now....
What kind of answers are you looking for in a pro 4 forum?
oviously we are gonna be a tab on the biased side... PRO 4!
Super Steve is offline   Reply With Quote
Old 04-11-2004, 09:21 PM   #3378
tc3 bmi i think is better
Old 04-11-2004, 09:23 PM   #3379
Hey!
you asked which one of the following two car was better: tc3 or pro 4
You never said BMI....
because now I can argue that BMI pro 4 is better...
Old 04-11-2004, 09:25 PM   #3380
name some of the better things of the bmi pro4 then the bmi tc3!!!
Old 04-11-2004, 09:29 PM   #3381
name some of the things that bmi pro4 is not better over bmi tc3!
lol...
TC3s are good cars. I am sure you will be happy with yours when you get a bmi chassis.
TC3 is a good car winning races sice it's debut...
If you still use stock gearcase with bmi tc3, your tc3 wouldn't be smooth as a pro 4
pro 4 is purple
pro 4 has awesome antisquat/kickup and rear antisquat adjuastability
pro 4 has niiiiiiiice steering system consisting of 6 ball bearings
pro 4 is "tuff"
Old 04-11-2004, 09:31 PM   #3382
popsracer's Avatar
Default Building the Pro-4
Super Steve;
The Gap in my Gearboxes is at the case halves, right where the outdrive bearings are. Yours look pretty good from the pictures.
I don't think that the Gap is there on purpose. Why have a Gap when you could design the box from the start to have the proper bearing fit?
Precision molding plastic parts is a very tricky science. The mold has to be designed to compensate for the plastic shrinking after it cools. If anything changes even slightly during the molding process, you can end up with bad parts.
Now I'm just not sure what is the problem with my Car. I just know that the Tweaking I am seeing is NOT acceptable to me.
I now have a new Upper Deck and 2 new Gearbox cases coming early next week (paid for).
Thanks,
Steven
popsracer is offline   Reply With Quote
Old 04-11-2004, 09:40 PM   #3383
Hm...
How do i check if my car is tweaked? just put it ona flat surface?
What is "flat" surfrace really... lol
Old 04-11-2004, 09:47 PM   #3384
RCGaryK's Avatar
Troy's head is pretty flat
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 04-11-2004, 09:52 PM   #3385
EDIT* oops wrong forum
Old 04-12-2004, 12:04 AM   #3386
cHckbOY5's Avatar
Send a message via AIM to cHckbOY5
ahhh i gave in to temptation, just bought a pro 4
cHckbOY5 is offline   Reply With Quote
Old 04-12-2004, 12:49 AM   #3387
RCBuddha's Avatar
Trader Rating: 33 (100%+)
Default Re: Building the Pro-4
Originally posted by popsracer
Super Steve;
Thanks,
Steven
Pops,
I thought you meant when the gear boxes were not screwed down. Mine has a little gap w/o tightening down the screws. When it is tightened down, it is like steve's, no gap....
RCBuddha is offline   Reply With Quote
Old 04-12-2004, 03:31 AM   #3388
cHckbOY5's Avatar
wat part seems to break first with the kit?
Old 04-12-2004, 04:52 AM   #3389
raving-monkey's Avatar
Send a message via MSN to raving-monkey
well i got a pro4, raced it for the first time on saturday.
i am very pleased with it so far except i found on a slightest knock the ball joint came out of the chub/steering block but threadlock soon cured that
i only qualified 7th in the B (not good for me ) but worked me way upto 1st after a bad start....my lap/times would of put me 5th in A (good for me )
i am very pleased with the one-way, also it is the first time i have runa one-way.
i had no problems with bevel gears, cant see any tweak problems.
and also pops....i have no gaps in my diff halves
raving-monkey is offline   Reply With Quote
Old 04-12-2004, 04:53 AM   #3390
most people are saying the bevel gears break first but if you boil them it softens thema bit and you shouldnt have any problems with them.
make sure you shim your diffs right to.
