Hpi Pro 4
#3241
also, they say tight rest your car flat on the setup board and tighten them, don't hold the car in your hand and tighten.
#3242
Chassis Tweak
Guys;
Just went over the Upper Deck tighening sequence AGAIN, and the same result.
If I put just the 2 screws for the Drive Shaft support, you can see that the rest of the holes are off about 0.5mm. It is like everything is off from front to back by this amount.
Guess I'm going to have to send it in and request a replacement.
Thanks,
Thanks,
#3243
#3244
R/C Tech Elite Member
Re: Chassis Tweak
Originally posted by popsracer
Guys;
Thanks,
Guys;
Thanks,
If not, then yes, you probably are owed a new one....
#3245
Re: Chassis Tweak
#3247
Originally posted by RC Driver Gary
Ben, are you going to the Reedy race? If I get in I "was" going to run my Pro4, but the gear problems are making me thing twice about it and I think I am at least going to bring my Surikarn along.
I probably need to pre sell around 25 of them and they look like they will cost around $18 currently. These are machined from 6061 T6 aircraft grade aluminum and will be purple anodize and include the M2 screws. I realize that cost might sound a little high, but if they save a few gears they are cheaper for us racers in the long run. But I will be sure to post exact pricing and info when it's ready.
Futureal, how about that Team PRP forum? Haven't heard back yet. You must be suuuuuper busy, eh?
#3248
#3249
18 bucks is fine with me. Thats cheap compared to the frustation of not finishing a race when you drive into a board and strip a gear. Its worse if your leading...
#3251
Trader Rating: 32 (100%+)
Pops....is the chassis sitting on a flat surface with out any shocks or tires on? If the chassis is not sitting flat on the ground then it might bow and that would lead to the holes not matching up. Just a thought.....
#3252
Ben - I got on him last night about it, and ill get on him again here in a second.
Beeb - not really.. We don't allow such "threads" unless they are a tech advertiser.
#3253
Obviously there's some red tape that I'm unaware of, but if he's the "real deal" then everything should be "cool" and the thread would flourish!
It seems silly that someone other than the thread "tech" would have to start the thread. I mean, what is going to happen if he makes an "Official Team PRP" thread? Is he going to stop it?
Obviously if I started the thread it would be crap. But if he started the trhead himself, then? Wouldn't it be legit?
#3254
i have seen many pictures of cars with the upper deck turned over and using counter sunk washers and screws.
this supposedly eliminates some of the tweak.
worth a try i guess.
Maybe he did file a little the misaligned holes.
#3255
beeb - ill pm you the short version ( tired ...sleep time... )
should explain it..
should explain it..
