Like Tree5Likes
Old 04-07-2004, 03:44 PM   #3196
blast's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to blast
hey Beeb put some electrical tape to cover that bear metal.
Patrick Connors
FTM Grip
You're not fast if you don't have the grip
A Master key can open any lock, but a lock that can be open by any key is an sloppy lock.
blast is offline   Reply With Quote
Old 04-07-2004, 03:50 PM   #3197
JusBox's Avatar
sounds like HPI is the new HUDY/XRAY... no parts available.
JusBox is offline   Reply With Quote
Old 04-07-2004, 04:15 PM   #3198
Send a message via Yahoo to Doug Gaut
Well I hope that they both are included in the diff kit because I have two kits coming in this week.
So far I am the only one in Wichita that has one and kinda hope it stays that way!
Doug Gaut is offline   Reply With Quote
Old 04-07-2004, 04:23 PM   #3199
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
awol, it's somewhat understandable being a new car, and having one single part that is a high demand part.
I'm pretty sure my shop has almost all the other parts in stock, just not the gear set.
I think I had a pinion in my diff set. I just wasn't going to say anything because I wasn't sure.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 04-07-2004, 04:59 PM   #3200
black-knight's Avatar
R/C Tech Charter Subscriber
re: gears
I have 2 Pro4's 1 is pretty new the other many months old. Each kit started of with the same placement for diff/output shaft shims. (as per Jap manual, i found the US front diff shim setup to be an issue)
Over time my 1st kit has required re-shimming. On two occasions i damaged rear pinion gears (diff gear did not get damaged). So i checked the mesh and found too much backlash to be present. I have now added more shims and moved the crown gear closer to the pinion gear, the reduces the chance of damage greatly. (just 1 additional kit shim was enough to sort this out).
Over time as the diff is adjusted / rebuilt etc varied shimming is required for optimal performance and gear life.
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 04-07-2004, 05:26 PM   #3201
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Man I got hosed then....I didnt get a pinion gear in my diff kit.....
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 04-07-2004, 05:36 PM   #3202
Super Steve's Avatar
Send a message via AIM to Super Steve
Anyways, i drove my pro 4 outside
Where I CA'ed the knukle together came off and I lost the screw too now since it was outside...
My droop screws from hpi still hasn't showed up yet.
Super Steve is offline   Reply With Quote
Old 04-07-2004, 08:03 PM   #3203
popsracer's Avatar
Default Building a Pro-4
Guys;
Well I got the Gear Boxes, Diff(s) and CVD's together so far.
I don't like using the spacers on the Wheel Hexes, so I used some spare Graphite Hexes from my Pro-3.
The Rear Diff went together nice and easy, chucked it up in my Drill press for a short break-in afterwards.
My kit came with a Lock Nut for the Diff. It is Silver and much smaller than any of the other Nuts so it's easy to recognize.
I did notice that the Thrust Bearing plates (A166) came in the bag with the larger size balls for the Diff. This might be confusing for someone who is less experienced building Cars.
Otherwise, so far so good.
popsracer is offline   Reply With Quote
Old 04-07-2004, 08:41 PM   #3204
raving-monkey's Avatar
Send a message via MSN to raving-monkey
well needless to say i decided to go for the pro4 over the cuda as spares backup is a doddle in the UK.
should arivve next week sometime, or maybe next (ordered US u see)
any tips on how to built it, like diffs (i will be running the one-way), shocks etc?
raving-monkey is offline   Reply With Quote
Old 04-07-2004, 08:58 PM   #3205
JusBox's Avatar
stock up on associated diff springs and front gear sets if you can find any. A guy I race with is stripping them like a drunk sorority girl.
Old 04-07-2004, 11:16 PM   #3206
Beeb's Avatar
Send a message via AIM to Beeb
I was thinking the same thing. Although it'll make my batts look like shite.
What about painting over it with acrylic paint? I could just use the clear "coating" liquid and it'd be covered but not black from tape. I don't see why it wouldn't work. ??
Beeb is offline   Reply With Quote
Old 04-08-2004, 12:13 AM   #3207
RCBuddha's Avatar
Trader Rating: 33 (100%+)
Default Re: Building a Pro-4
Pops,
Don't forget, Tamiya's Clamping hexes work fine, and I've been using them for the last few races with no problems....SoCal had some blue ones if last I checked if you were interested.
RCBuddha is offline   Reply With Quote
Old 04-08-2004, 12:14 AM   #3208
RCBuddha's Avatar
For some general building tips, see my signature....
Old 04-08-2004, 12:18 AM   #3209
RCTech Member #2
TSR6's Avatar
Beeb! Single cell shrink! ...heh..
It won't change the appearance of the cell, but will cover the bare metal.
Troy
RCTech Member #2
Old 04-08-2004, 12:31 AM   #3210
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
Default Re: Re: Building a Pro-4
Originally posted by RCBuddha
Pops,
I generally don't know my head from my arse, but I like the trick little Yokomo hexes...they have an "ultralight" one that holds the pin in with a little o-ring. REALLY trick and I'd swear it's lighter than the plastic ones. They usually have them at Ultimate or SoCal for 15 bucks or so for a whole set.
I think they may be the stock ones on the SD...even the pin is shorter.
(edit) found the number...ZS-011EL It is stock on the SD.
Turbo Joe is offline   Reply With Quote
