Old 04-06-2004, 06:47 AM   #3151
we have the pivot blocks for 10.40 and sway bars for 4.80 if you need them
revRCshop is offline   Reply With Quote
Old 04-06-2004, 06:59 AM   #3152
JohnA's Avatar
Default Orion Revolution 12x1
Does anyone knoe who has the Orion Revolution Hara motors in stock?
My Pro-4 needs one
JohnA is offline   Reply With Quote
Old 04-06-2004, 07:01 AM   #3153
Erik Shauver's Avatar
Erik Shauver is offline   Reply With Quote
Old 04-06-2004, 07:37 AM   #3154
rc-zombies's Avatar
Originally posted by Michal101
Anybody???
pivot blocks.. 2.5deg.front
3.0deg. rear.
1.6mm sway bars..
Old 04-06-2004, 07:50 AM   #3155
Michal101's Avatar
Great...Thanks guys!
Mike
(Team Driver)
R/C America
Team Tekin
ProMatch
Parma
Michal101 is offline   Reply With Quote
Old 04-06-2004, 08:19 AM   #3156
rc-zombies's Avatar
Originally posted by Super Steve
my pro4 looks fast and is fast..
BTW... here is what i wish i had in my hands
contact your local anodizer...he may be able to re-color your purple parts and turn them to the color of your choice... my Blue Pro3 cost me about $50.00 to do....
Old 04-06-2004, 10:15 AM   #3157
RBLove's Avatar
Trader Rating: 71 (100%+)
Erik,
I posted on BMI's thread, but I will gladly post it here.
Front:
#4 piston - 50 wt. - Losi white
inside on arm
laid in to third hole on tower
6 degree caster
.5mm anti-dive
outside hole on camber link shimmed 2mm (short)
kist sway bar
1mm up travel
stock askerman settings
2.5 arm sweep
Rear:
#4 piston - 45 wt. - Losi black or white
middle hole on arm
outside hole on tower
camber link is out on hub and in on bulkhead shimmed up 3mm
2.5 rear toe block
rc-square .5 rear hubs reversed (total of 2 degrees rear toe)
.5mm anit-squat - also like .5mm pro-squat - still deciding
standard wheel base (large spacer in rear)
2mm up travel
BMI
3mm chassis
3mm top deck
3mm shock towers
RBLove is offline   Reply With Quote
Old 04-06-2004, 10:54 AM   #3158
rayhuang's Avatar
RB-car should be at home-diff on Friday and BMI Chassis coming next week!! Waaahoooo!!! I'll pop your set-up on it and hopefully I'll get it on the track on the 25th!!!! I am getting the full blown BMI-chassis-top deck, shock towers and steering.
Do you feel car needs any Ackermann mods at this time? I think Downforce found lengthening the arm on the front spindle was advantageous on Nats layout.
Old 04-06-2004, 11:11 AM   #3159
RBLove's Avatar
FYI. Anyone having any issues with keeping their diffs locked................. Use the TC3 diff spring. It is much stronger and allows you to run the diff a lot looser and still be locked down.
Ray,
How are they lengthening it? Just going to the other set of holes on the hubs? I have yet to play with Ackerman. Once I get all of the tuning options out there (suspension blocks) I will play with a lot more settings. I'd like to get some of that arm sweep out the car, but 2.5 seems to be the only block available right now.
Old 04-06-2004, 11:20 AM   #3160
rayhuang's Avatar
Just like on the Xray's with a piece of carbon fiber with another hole. I am about to make a set for the Xray and may make set ofr the Pro4. Using old shock towers from my Xray!!
Ray
Old 04-06-2004, 11:59 AM   #3161
kewdawg's Avatar
Default BMI CHASSIS SET-UP
RB,
were you using a diff up front or a one-way? Foam or rubber tires w/ inserts? Indoors carpet? Asphalt indoor / outdoor?
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 04-06-2004, 12:31 PM   #3162
dr_hfuhuhurr's Avatar
If I'm not mistaken it was:
Diff (not entirely sure)
Foams (for sure)
Carpet (for sure)
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 04-06-2004, 12:33 PM   #3163
coastaltony's Avatar
RBL.
Do you just swap HPI # A165, for AE # 6582? Any tips on adjustment?
Meucci pool cue collector
coastaltony is offline   Reply With Quote
Old 04-06-2004, 12:37 PM   #3164
Erik,
Can you please post the set-up of the LRP race ?
many thanks
Ralf is offline   Reply With Quote
Old 04-06-2004, 12:53 PM   #3165
rayhuang's Avatar
Default Re: BMI CHASSIS SET-UP
Originally posted by kewdawg
RB,
Definately a diff- I know that for sure.
