Like Tree5Likes
Old 04-03-2004, 03:54 PM   #3091
rayhuang's Avatar
Default Diffs in mod and spring question
Hey all,
Thanks for chiming in everyone. I have the car on its way and a diff from Stormer. Also thaks for rc-zombies for some help!!
Ray
Old 04-03-2004, 04:11 PM   #3092
Superfly1967's Avatar
Originally posted by True R/C Racing
Go over, Suspension, Droop, Any Binding in drivetrain too.
Thanks for the info TrueR/C.
I did that all ready, all but suspension. Going to go over that tonite. I am kind of wondering if the chassis took a hard enough hit to tweak it. I loosened all the top deck screws and re tightened but that did not seem to help. Maybe I need to take apart and lie flat on flat surface and see. I wonder if not being perfectly balanced would cause it. Anyone have an opinion on this thought.
One more thing. Spring tension. Does anyone know what the rates are for the springs that come in the kit, or what they are close to? I want to firm up the front with AE springs but would like to know about where I am with the stock ones.
Superfly1967 is offline   Reply With Quote
Old 04-03-2004, 04:20 PM   #3093
One more thing on the car dog tracking. Do any of you experienced chassis tuners think it could be the middle brace between the upper and lower deck. I didn't put this in when I first built and raced the car and that is when it ran its truest and straightest. I put that brace in it and the second night at the races is when I started experiencing this the most.
One other thing that I noticed after putting this brace in is that from a stop or running forward at partial throttle, when I nail the throttle, the car tries to veer to the right. Once again, I only noticed this after I put the brace in.
For general info. I am running stock class on foams.
Thanks in advance for any and all help.
Old 04-03-2004, 04:38 PM   #3094
Oasis's Avatar
Trader Rating: 36 (100%+)
I never put it in..
Oasis is offline   Reply With Quote
Old 04-03-2004, 05:18 PM   #3095
RBLove's Avatar
Trader Rating: 72 (100%+)
Pro 4 racer's,
I will be testing the BMI 3mm chassis, top deck and towers tomorrow (carpet/foams). I also got some of the rc-square hop ups on the car. I was able to get the rear toe down to 2 for now (2.5 toe block with square .5 hubs on reversed).
I will provide feedback and any set up info I come across.
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, BSR Racing Tires
RBLove is offline   Reply With Quote
Old 04-03-2004, 08:30 PM   #3096
popsracer's Avatar
Default Hpi Pro 4
Guys;
Yesterday we received another Pro-4 kit at the store. Of course everyone had to check it out.
One thing that I did notice that unlike my kit, the countersinking on the Chassis holes were at the proper depth.\
popsracer is offline   Reply With Quote
Old 04-03-2004, 08:34 PM   #3097
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
I just ordered a Pro4 and was wonder what the rear toe is at in stock form? What does it have per side? My TC3 is pissing me off so I need to try something else. The TC3 graphtie parts strip too easily and break fairly easy. If the Pro4 holds up like the old Pro2 did then I'm in business.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 04-03-2004, 08:37 PM   #3098
Super Steve's Avatar
Send a message via AIM to Super Steve
Pro 2 is a tank...
Pro 4 is ok for a high performance tourer but will still break. (Not as much as AE graphite parts....)
I too find TC3's graphite parts strip easily...
I need some aluminum knuckles.
rczombies.... you sure you don't have to order from japan anytime soon?
Super Steve is offline   Reply With Quote
Old 04-03-2004, 08:39 PM   #3099
wyd
Tech Legend
wyd's Avatar
Does anyone know if the Rayspeed springs fit the Pro4 shocks or not?
Old 04-03-2004, 09:07 PM   #3100
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
superfly, Unless you tweaked you chassis while putting it in, the brace shouldn't cause it to veer. I put mine in from the start, and havent had a problem
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 04-04-2004, 07:05 AM   #3101
Thanks for the info. I am going to pull the chassis apart and see if I tweaked it. Think I will leave the brace out since it was running best for me with out it.
Old 04-04-2004, 07:09 AM   #3102
Default Hop Ups
I know this has already been talked about but could someone tell me where in the states I can get hop ups like the transponder servo mount and the different toe plates.
Old 04-04-2004, 09:53 AM   #3103
popsracer's Avatar
The Kit supplied mount provides 3 degrees TOTAL of rear toe. There are soon to be availible mounts that will allow adjustments in 1/2 degrees down to ZERO.
You can also use another front mount (2.5) if you need a little less in the Rear.
Old 04-04-2004, 11:53 AM   #3104
Techart27's Avatar
Where can i get it for the lowest price? I heard you can get it around 260.
Techart27 is offline   Reply With Quote
Old 04-04-2004, 12:10 PM   #3105
www.revRCshop.com has it for $280.00
revRCshop is offline   Reply With Quote
