Like Tree6Likes
Old 04-02-2004, 08:17 PM   #3061
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Cool, now lets hope that they are resistant to heat
It's a pain having to have to run metal outdrives in the tc3 to run mod.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 04-02-2004, 08:17 PM   #3062
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Originally posted by RC Driver Gary
I ran a 19T in mine at Road Rage for 4-6 packs, no visiable wear.
I hope your talking about the diffs, and not the arms.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 04-02-2004, 08:24 PM   #3063
RCGaryK's Avatar
No, I broke the arm in stock
God, I slammed into that pipe hard. I STILL have no idea how the ball stud broke in the left rear when I hit with the right front But I finally got new hubs and installed them last night, along with a pinion gear. But there was no damage to the ring gear.
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 04-02-2004, 08:47 PM   #3064
Super Steve's Avatar
Send a message via AIM to Super Steve
here is the movie!
http://www.rcpics.net/view_single.php?medid=27047
Watch alll of it...
let me know how good/bad my driving skill is. (remember, this is my first night with my pro 4)
the scene where i actually break the car was not caught on tape...
Super Steve is offline   Reply With Quote
Old 04-02-2004, 08:55 PM   #3065
Bodies work pretty well
That's a very small and very weird track...where is that?
USVTA Member #211
Old 04-02-2004, 09:04 PM   #3066
Cornwall Ontario
Old 04-02-2004, 09:24 PM   #3067
Send a message via Yahoo to Doug Gaut
Okay, I must be missing something here but why is the servo saver 90deg instead of 180deg like the picture shows???? There is no way the servo link can connect to the saver this way. Were the angles cut wrong on my servo saver? If so, any suggestions for a substitute till I can get some corrected parts? I was really hoping to hit the track Sunday.
Doug Gaut is offline   Reply With Quote
Old 04-02-2004, 09:39 PM   #3068
Beeb's Avatar
Send a message via AIM to Beeb
Are you using the correct 2 pieces? I'm thinking that if you used 2 of the "top" pieces then it'd be at 90 degrees. Check your parts tree for another part that makes it 180.
Beeb is offline   Reply With Quote
Old 04-02-2004, 09:40 PM   #3069
maresma's Avatar
Originally posted by Super Steve
here is the movie!
Watch alll of it...
Steve, good movie! Car was a little bit loose on the end. Should be better with body. IMO the track is a bit small for 1/10 but very nice for 1/18 scales.
maresma is offline   Reply With Quote
Old 04-02-2004, 09:57 PM   #3070
Beeb's Avatar
Default Super Steve
I agree, seemed like a tight fit for 1/10 but for what you had to work with that was great. I feel bad for you that you don't get to get your car up to speed on a track.
It's too bad you found a way to break it though.
Old 04-02-2004, 10:04 PM   #3071
Beeb, these are the only parts in the complete kit. The "v" is cut wrong.
Old 04-02-2004, 10:11 PM   #3072
Beeb's Avatar
That's what I don't get. It comes from a mold, so it'd be one HUGE mistake. My kit had 2 different top pieces and 1 bottom piece, so that's why I was thinking that you had both top pieces together.
If they did mold it wrong that sux. There must be a bunch of kits with the wrong cut out there.
Very surprising.
Old 04-02-2004, 10:43 PM   #3073
RCBuddha's Avatar
Trader Rating: 35 (100%+)
Default Easter has come early!!
Oh, the Easter Buddha has come early and lookie what he brung:
just click on the little magnifying glass...
RCBuddha is offline   Reply With Quote
Old 04-02-2004, 10:44 PM   #3074
coastaltony's Avatar
Doug, check in the big bag. Mine came off the tree, and I found it after about 20 minutes of searching.
Meucci pool cue collector
coastaltony is offline   Reply With Quote
Old 04-02-2004, 10:56 PM   #3075
RCBuddha's Avatar
Default @ Gary
Buddah, I will be at the Reedy race to cover it, and I hope to make it in the lottery as well. I just ordered a front diff today for my Pro 4, so I think I am either going to run that or my Surikarn, but I am leaning towards the Pro 4. Do you have any ideas on setups yet? I plan on getting my testing started in a week or two here on asphalt. Also thinking of trying a spool, but I dunno if that would be better than a diff or not. We might have to see about getting an "unofficial Team Pro 4" going for the Reedy race
Hi Gary,
I've been doing some reconnosince (sp?) at tamiya the last two months, and I'm gonig to start with these setups:
http://www.teamassociated.com/racerh...eedyRaceTC.pdf
Of course, they are for TC3's but they should be a decent starting point. I think Hara and Thad should be there, so they also could be a good source of setup help... I do plan on running a diff, I don't think I can get a spool quick enough to run. I figure a fully tightened diff you provide more consistent handling.
I'll see about making some T-Shirts....
