Old 04-02-2004, 10:57 AM   #3031
RandyB's Avatar
Buddha I think the dif cases were designed like that so when tightened down they dont put pressure on the bearings
just a thought
RandyB is offline   Reply With Quote
Old 04-02-2004, 10:59 AM   #3032
RCBuddha's Avatar
Trader Rating: 33 (100%+)
just a thought
Good point RandyB.... If I see Erik at the track, I'll ask him about it.
If anyone is interested, i've updated my building tips...just see the link in my signature....
RCBuddha is offline   Reply With Quote
Old 04-02-2004, 11:27 AM   #3033
Maj. Teeth's Avatar
BUUUUUUUUUDDDDDDDDDDDDDDDHHHHHHHHHHHAAAAAAA!
Man! yer turning PRO on us or what! Nice of you to drop by yesterday man! Can't wait to test out your car!
Dan
Maj. Teeth is offline   Reply With Quote
Old 04-02-2004, 01:03 PM   #3034
cartmen34's Avatar
just a thought
Well, I took the afternoon off of work to determine my problem...and I found it. Turns out I had one to many shims between the diff bearing and the diff. Took out one shim and the thing slid together like butta'!
So now I've got the slightest amount of side to side play in both of my diffs, but the drivetrain is MUCH smoother!! So I guess I have a building tip now..... don't use too many shims when shimming your diffs!!
Many thanks to Bhudda, RandyB, and Downforce for their advice!!
cartmen34 is offline   Reply With Quote
Old 04-02-2004, 01:50 PM   #3035
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
cartman - Yeah, You need to shim it, then tighten all the screws to check the shimming. You might have to pull it apart and re-shim it if it's to loose, or to tight.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 04-02-2004, 02:26 PM   #3036
rayhuang's Avatar
Default parts is parts
Hey all,
I do plan on buying all my spares from the LHS-but since they have none right now-I need to know about online shops. Well-one in particular that was having a free shipping offer for all orders over $50??? Anyone recall?
Thanks,
Ray
Old 04-02-2004, 02:43 PM   #3037
rc-zombies's Avatar
Ray..
Speedworld did have free shipping at one point...but I think that is over...
Tower has majority of the parts in stock...and stock car parts are only $3.99 shipping.
Old 04-02-2004, 02:59 PM   #3038
rayhuang's Avatar
rc-zombies-ygpm
Ray
Old 04-02-2004, 03:19 PM   #3039
coastaltony's Avatar
Are we still running 50W shock oil, or is softening it up a bit, and adjusting spring W better?
coastaltony is offline   Reply With Quote
Old 04-02-2004, 03:24 PM   #3040
RCTech Member #2
TSR6's Avatar
I've been running Losi 50wt oil. I built the car with Losi oil since I have each of the weights.
I don't think I'd go much lighter on carpet, but asphalt I would bet I'd drop a weight. I can't wait for outdoor season
Troy
RCTech Member #2
Old 04-02-2004, 03:34 PM   #3041
I'm in S. Florida and we
have a 125' x 75' tennis court grade
asphalt track. The weekend weather
will be in the low to mid 80's, not a
chance of rair.
Old 04-02-2004, 03:42 PM   #3042
RCTech Member #2
TSR6's Avatar
chance of rair.
..about 2 hours south of orlando?
I'm kinda "collecting" info on places to race within an hour or so of orlando.
Troy
RCTech Member #2
Old 04-02-2004, 03:54 PM   #3043
Coral Springs is about 4 hours south, but the track is 100%!
Look at the "Florida Racing" area,
there is a link to all the tracks down here, in one of the threads.
www.csrcroadrunners.com
Old 04-02-2004, 04:03 PM   #3044
RCTech Member #2
TSR6's Avatar
Ah, ok. I punched Palm Springs into maps.com to get what i posted there.
Yeah, Tim has been hooking me up with the local info down there, and I have been browsing the FL forum.
Troy
RCTech Member #2
Old 04-02-2004, 04:29 PM   #3045
RCBuddha's Avatar
Dan
Dan the Man!!! Yeah, i've been running the Pro4, its the first car in a long time that I actually find easy to drive, and not on the edge.....I'm hoping to make the Reedy Race; I've got some big plans if I make it in....muhahaha
SEO by vBSEO 3.5.0
