Old 04-01-2004, 04:14 PM   #3001
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
and new prototype CF camber link mounts
Yeah they look sharp.....Someone from Japan has Alum. ones...that look trick too.
BTW....3000 reply in here.....yeayyyy....
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 04-01-2004, 04:16 PM   #3002
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Square
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 04-01-2004, 04:19 PM   #3003
rc-zombies's Avatar
Originally posted by TSR6
Square
I'd buy the CF version when it gets released...
Old 04-01-2004, 04:21 PM   #3004
rc-zombies's Avatar
more pics of Hara's car can be seen at:
http://www.rcworld.ch/neueprojekte.asp?id=1073
Old 04-01-2004, 06:03 PM   #3005
Kevin K's Avatar
Thats the one that I saw before.....looks cool but the C/F ones would be even better.
Old 04-01-2004, 07:34 PM   #3006
Super Steve's Avatar
Send a message via AIM to Super Steve
hahaha..
me and hara has the same sticker on our servos...
I did it before he i saw his pictures too!
Super Steve is offline   Reply With Quote
Old 04-01-2004, 07:35 PM   #3007
Old 04-01-2004, 07:37 PM   #3008
the car looks so much more purple and so much more cleaner then in the pics
P.S. CA remover works very well!
Old 04-01-2004, 09:43 PM   #3009
RCGaryK's Avatar
Has anyone tried Tamiya Evo 3 outdrives with an HPI gear to make a front diff or one-way?
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 04-02-2004, 12:54 AM   #3010
Frank McKinney's Avatar
Heh - I hope Erik doesn't see that caption that says Miura designed the Pro 4 Miura did the TB03, Erik did the Pro 4...
Minimal signature to save screen space! Big sigs suX0r
Frank McKinney is offline   Reply With Quote
Old 04-02-2004, 06:44 AM   #3011
RandyB's Avatar
Zombies good work on those pics. I have thought about making the CF camber links too. Now I know its possible.
RandyB is offline   Reply With Quote
Old 04-02-2004, 07:01 AM   #3012
cartmen34's Avatar
Hey folks, got a ? for you.... Last night I finished up the rolling chassis. when I tightened down the top deck, I noticed that the drive train got quite a bit tighter, (not nearly as free as some I've played with at the track). So I was wondering, did you have to do anything special to keep the drivetrain free once you clamped all the parts on, or will my drivetrain free up with time? I assembled the entire kit as they describe in the manual. I used the stock white/clear grease on the gears, and was very careful and took my time assembling the gearboxes as per the directions.
I am a little concerned because, as I said, the others who have this car already said they assembled it exactly as the directions say, and their drivetrain are much more free than mine currently is.
Thanks for any help you can can provide!
cartmen34 is offline   Reply With Quote
Old 04-02-2004, 07:15 AM   #3013
You did something wrong then. Take it apart and check all of your spacers on the spur gear shaft. Also find out which screws make it tighter and back track. This car should free spin out of the box.
Downforce is offline   Reply With Quote
Old 04-02-2004, 07:25 AM   #3014
cartmen34's Avatar
I did this already. I went over the directions "with a fine tooth comb" so to speak, and I cannot find any errors in building, neither the actual gearbox or the spur gear shaft. I'll go over them again tonight when I get home from work. Perhaps I'm reading the directions wrong....but I've been building race kits for over 12 years....so I kinda' doubt this is the case.
I noticed that when I loosened the two outer screws that reside on the far ends of the gearboxes things got alot more free. This is obviously because now the gearboxes are now not clamped together, but clearly I cannot run the car with those two screws loose all the time.
It's not possible that I tighted the gearbox screws down TOO much....is it? I mean the plastic would strip out first, right?
Old 04-02-2004, 07:36 AM   #3015
RandyB's Avatar
did anybody else notice Hara is using rpm ball cups? what is everybody using for ball cups?
SEO by vBSEO 3.5.0
