Like Tree5Likes
Old 03-30-2004, 07:26 PM   #2941
robk's Avatar
Trader Rating: 22 (100%+)
"what are you guys doing to the steering knuckle? making them longer?"
Like Derek said, the arm coming off the knuckle is longer. The ones I made were like adding an extra hole with the same hole spacing as the stock ones. I found the car to steer well at low speed too, but I think my knuckles may heve been shorter than the ones Derek had. Basically you're getting the outside tire to have less of an angle, and the inside tire to have more angle.
Old 03-30-2004, 07:42 PM   #2942
tc3 racer sc's Avatar
Default my screw are hard to put in
i was talking to hpi i told them my screw are hard to put in they told me to get a 3mill tap i nver used one some plse explain what i need to do and also i got a screw stuck in the bulk head too
tc3 racer sc is offline   Reply With Quote
Old 03-30-2004, 07:46 PM   #2943
JusBox's Avatar
Default Re: my screw are hard to put in
They told you to pre-thread the screw holes. Righty tighty, lefty loosey with the stuck screw. Use some elbow grease.
JusBox is offline   Reply With Quote
Old 03-30-2004, 09:17 PM   #2944
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Well, I just got back from Trackside. I had the points lead wrapped up last week, but ended up extending it this week.
Just an idea until Team PRP finishes the gear brace: I put washers between the screw and the one way gear two races ago. I noticed that the screws were ended up leaving indents on the one-way gears, and the washers should help to spread the load from the screw to a wider area. I haven't roasted the one-way gear since then, so it may be to early to tell if it works, so far so good though.
TC3 - Please tell me you are using a quality tool set, and not the L-wrenches?!
Steve - on my first chassis, I used Losi thin tire glue. I ran a bead across the chassis, and smoothed it out with my finger. I don't really suggest this, but it works. After doing the whole chassis, I had a layer of glue thick enough on my finger that a few seconds under hot water, I was able to peal it off.
I used a thing called the "Microbrush" on the second chassis. Although I went through about 3-4 of the brushes, it was a little less messy on the fingers.
AJ's Raceway rocks as far as the surface and the barrier goes. I don't think it's possible to break ANYTHING on that track. It really is glass smooth, but I would suggest at least talking to the race director before you run. I don't know how they run the electric races, but when I went down there for nitro, I was told conflicting stories from the owner/race director on how qualifying is run. ( I asked if it was IFMAR, he said yes. Later, he told me it was a qualifying race, but your on your own clock. I asked if it was alright to start a little behind the guys to have a clean track with all the banging that was going on. He told me I better not, because it's a qualifying race. I asked again if it was IFMAR, and we were on our own clock, and he said yes. )
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 03-30-2004, 11:00 PM   #2945
Tek Nickal's Avatar
Default Re: Re: my screw are hard to put in
For graphite parts, use a tap first, a tap is something that makes threads for screws to go into. You can get a pritty good one thats not very expensive. About 10 bucks will get you a handle and a bit.
Tek Nickal is offline   Reply With Quote
Old 03-31-2004, 12:28 AM   #2946
RCGaryK's Avatar
But tell them about your pinion gear Troy...That was odd...
Steve, if you use Jet on a Q-Tip it doesn't get as bad as Losi or Proline glue. My nose started burning from the fumes of the Losi gule as it smoked on the q-tip. That's how I did my new chassis tonight...
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 03-31-2004, 12:43 AM   #2947
RCTech Member #2
TSR6's Avatar
No kidding, I was going back and forth with Ron for second qual spot during that heat too...
Troy
RCTech Member #2
Old 03-31-2004, 05:39 AM   #2948
rc_square24's Avatar
Default rear diff coming loose
how was the rear diff coming loose issue fixed? would putting threadlock on the nut help?
thanks
rc_square24 is offline   Reply With Quote
Old 03-31-2004, 08:59 AM   #2949
chr15tophe's Avatar
hehehe oh god dont ask about the diffs !!!,
What I foud on my car was that i had normal m2 nuts included in the kit instead of nylon m2 nuts, to rectify yes put threadlocker on the nut and let it set over night. I then bought 2 diff kits and made sure that the nylon lock nut was is in there.
Have also spoken to other pro 4 owners who have found the diff ring hasnt been sitting true, also causing diff to loosen. Other things could include checking the number of thrust balls you have in the thrust race.
Make sure the inner plastic diff ring is glued in and sitting evenly in the diff.
The last thing to check is that when I thought the diff was loose, was too actually remove the diff and check by using allen keys through the outdrives and check to see if the gear moved.
By holding the spur gear+ wheel and turning the opposite wheel often the wheel turned but only because you apply more force through the diff, the diff itself was actually locked when removed and checked.
Did anyone else find anything extra??
Hope this helps.
chr15tophe is offline   Reply With Quote
Old 03-31-2004, 10:08 AM   #2950
rc-zombies's Avatar
Eric...
Your Web guys did a great job... I have one requested..
an interactive/modifiable pdf file for the set-up sheet.
Xray just released one for the Factory team car...and hope you guys can do one for the Pro4 as well....
http://www.teamxray.com/teamxray/pro...82&kategoria=0
Old 03-31-2004, 10:12 AM   #2951
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
Trader Rating: 14 (100%+)
rc-zombies: I should have my Pro4 soon, so....
If they don't have one soon, I can make PDF setup sheet.
I have done it most all my cars.
Tre's
TnT-Fx Custom Graphics
www.tnt-fx.com
Tres is offline   Reply With Quote
Old 03-31-2004, 10:14 AM   #2952
rc-zombies's Avatar
Cool...
Old 03-31-2004, 10:36 AM   #2953
OSherman's Avatar
for those interested... SpeedTech R/C has complete (outdrives, balls, rings, hardware etc.. in one package) diff kits .......(just recieved mine yesterday) ... He may still have some in stock...
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 03-31-2004, 10:41 AM   #2954
StewartFan20's Avatar
Default Pro4 Shock
I just bought the Pro4 about two weeks ago and was wondering if anyone has any tips on how to build to shocks so they all feel the same. I am using th 50 weight oil that came with the kit.
Thanks in advance
StewartFan20 is offline   Reply With Quote
Old 03-31-2004, 10:50 AM   #2955
rc-zombies's Avatar
Default Re: Pro4 Shock
Thanks in advance
Pretty much build per instructions... the shocks are self bleeding so majority of the time all the shock will feel the same. After you build do the rebound test...2 at a time...compress the shocks without any springs...and they should fully extend approx the same time....
50wt oil...if our running outdoors on asphalt you may want to drop it down to 40F / 30R depending on your track...
