Like Tree6Likes
Old 03-30-2004, 04:46 AM   #2896
RandyB's Avatar
Derek,
cant wait for lazer to start up. I am looking forward to running the pro4 this year and was hoping you'd point me in the right direction for a starting set up. I was up at larrys last weekend and nobody I swear nobody has parts in michigan or ohio so hopfully that will change before on road starts
RandyB is offline   Reply With Quote
Old 03-30-2004, 05:07 AM   #2897
Hey Randy-I'm just going to start with the stock setup and go from there. Riders in Ypsi and The Hub in Lansing have some parts. Seems like the LHS on the east coast are at the bottom of the food chain.
Downforce is offline   Reply With Quote
Old 03-30-2004, 05:25 AM   #2898
Trader Rating: 37 (100%+)
Here's one of the happiest Pro 4 owners from the Nats...Great run in the main Teacher, you schooled them!
LOL you caught Pro4 owner Rob King in the background also....holding the silver car :P
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 03-30-2004, 05:33 AM   #2899
Send a message via AIM to Proteus
Originally posted by The Teacher
Proteus, did you hook a brotha up???
David Joor, wish you could have ran the HPI at the Nats, I really needed setup help. That BMI chassis looked like the way to go, do you know how we can go about getting one???
hehehe....MAYBE!!!!!!!!!!!!!!!!!
Proteus is offline   Reply With Quote
Old 03-30-2004, 06:35 AM   #2900
David Joor's Avatar
R/C Tech Charter Subscriber
Originally posted by Downforce
I seen David Joors car and talked to him for a few minutes. I'm not sure the lower 3 mm chassis is needed. The upper deck did raise and eyebrow. If you do use a 3mm chassis I see 3d cutting is a high priority. The thickness of the chassis changes your roll centers and cg too much. 3d cutting will take care of that.
As TeamPRP mentioned, the .5mm is not enough to justify a jump in geometry changes since everything is raised .5mm. If you added milling cuts to lower the stuff back down, the front and rear would have to be almost completely cut out so that you could get the arms down, pivot blocks, and the diff housing which in my experience would allow the nose and the rear to flex making the 3mm chassis close to worthless for the most part.
Avid Racing Concepts LLC.
http://www.avidrc.com
AE | Reedy | KO | Tekin | Powermaster | Avid | Upgrade | BCE | Paint by Smiley
David Joor is offline   Reply With Quote
Old 03-30-2004, 07:52 AM   #2901
Ares17's Avatar
Default Pro 4 keeps veering right.
Been trying to keep my pro 4 going straight but to no avail. It keeps veering to the right. I followed the manual closely when building it. What can be wrong? Anybody has any ideas to correct it? Thank you.
Ares17 is offline   Reply With Quote
Old 03-30-2004, 07:53 AM   #2902
kewdawg's Avatar
Originally posted by TSR6
Rubber tire
Now it all makes sense. thanks I was bangin' my head on that one.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 03-30-2004, 07:55 AM   #2903
Doug - I would use some springs from the Super Nitro. I used the stock springs that came with the kit. Meaning super Nitro Kit. They worked really good. As far as the pro-4. No clue, what so ever. Hope this helps.
Could not resist.
Yep-Man is offline   Reply With Quote
Old 03-30-2004, 08:44 AM   #2904
acutts's Avatar
Default Re: Pro 4 keeps veering right.
My mate had this problem .... if you look at the graphite plate that attaches to the servo saver, it is probably not centered. Even if you fiddle with trim it will not help. Need to adjust the length of the turnbuckle attached to servo.
Hope that helps.
Scott
acutts is offline   Reply With Quote
Old 03-30-2004, 09:29 AM   #2905
popsracer's Avatar
Default Re: Set-Up
Originally posted by Coxy
Question about the Pro 4 Set-up guides in the Manual.
How can MORE castor give you more turn in and less exit steering
Coxy.
From my experience, LESS Caster (smaller #) results in more low speed steering, with a loss of steering in high speed corners.
MORE Caster (Larger #) results in more high speed steering, with a loss of steering in low speed corners.
This has been the general rule for all of the Cars that I've ever driven Electric or Nitro.
For fine tuning turn-in and exit steering, I would work on Shock mounting positions.
popsracer is offline   Reply With Quote
Old 03-30-2004, 10:09 AM   #2906
The Teacher's Avatar
Trader Rating: 48 (100%+)
robk, so you made the extentions for your steering knuckles at the Nats??? You car did carry more speed through the corner than mine, I'll have to try it....
Downforce, thanks for letting me use your drill bit for the hubs. I should have tried your trick on the front hubs as well...
The Teacher is offline   Reply With Quote
Old 03-30-2004, 11:06 AM   #2907
Trinity2's Avatar
Post
Originally posted by rc-zombies
no...
what did you read...?
a link would be helpful.. for those who don't want to look...
Sorry, if i confused you guys. I just wonder that name of spurgear. It`s mean at that spurgear is made by Xenon?
Trinity2 is offline   Reply With Quote
Old 03-30-2004, 11:45 AM   #2908
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Hey guys here are some pics of my New Pro-4...man this thing is sweet....I cant wait to get more wheel time with it.
http://home.comcast.net/~anthony.isl...oms/pro4_4.jpg
http://home.comcast.net/~anthony.isl...oms/pro4_3.jpg
http://home.comcast.net/~anthony.isl...oms/pro4_2.jpg
http://home.comcast.net/~anthony.isl...stoms/pro4.jpg
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 03-30-2004, 12:51 PM   #2909
RandyB's Avatar
Derek,
yeah chuck hooked me up last weekend on a steering knuckle I need a front arm and few other things but I am sure this parts shortage will clear up soon.
Old 03-30-2004, 12:53 PM   #2910
rc-zombies's Avatar
Originally posted by RandyB
Derek,
what are you guys doing to the steering knuckle? making them longer?
