Old 03-29-2004, 03:36 PM   #2881
robk's Avatar
Trader Rating: 22 (100%+)
I was at the nats and i talked to the Teacher and Derek manchester (not sure if he's on here). It was nice to meet both guys. Didn't talk to David though.
I DNF 3 of the 4 rounds. !st round was an arm, 2nd, my wheel nut backed off, 3rd somebody was stopped at the 180 at the end of the straight and I piled him. Yes I sucked this weekend. 4th round i went 23 5:02 or 03 which was good, but I probably could have done a 24 the round earlier, had i not broken. None the less, i found out a TON about the car. The results don't show it but my car got multi times better as the weekend went on. I started with the Hara setup and made changes from there.
Derek manchester told me he had tried extending the steering knuckle out to reduce the ackerman in the car. That was probably one of the best ideas that came out of the weekend. He told me it freed the car up and it did by quite a bit. One thing I noticed was that my car would steer well, but it felt bound up in the mid corner. This helped a lot, and it also seemed to make the final wheel positions close to that of a TC3, depending on your choice of ballstud position on the steering rack.
Raisng the front roll center by spacing the front mount up helped to get the car steering better as well as rolling thru the corner better. I went 2mm in the front and flat on the chassis in the rear. This might not be ideal, but worked in the limitations of the weekend. I also had no kick up or down in the front, the car seemed to like that best. i layed the front shock into the 3rd hole in from the outside to keep up corner speed as well.
I also ran pro squat in the rear, which will make the car rotate more. I used llike 1mm (?) of difference in the rear. I put the rear ballstud in the inner hole on the hub to get more rotation as well.
Also, i went to 60 wt oil in the rear, and that seemed to really control the roll of the car at the rear.
Like i said the showing was sad considering i was in the H main, but I started 7th and passed everybody except the Teacher. I wish i could have gotten close enough to race him, but time ran out. I got down to a 12.8 in the 3rd round, after which i wrecked my car. Mainly i need to get all the bugs worked out and go clean. Duh.
Old 03-29-2004, 03:43 PM   #2882
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Originally posted by rc-zombies
Ahhhh....dorm life...the good ol' days...
I would have partied... on second thought building the car is more fun... there's always a party going on....
had some great times in the dorms....
even though I was never an official resident...
haha.. you were one of "those" people huh? haha.. They're here all the time, most of them moochers. The way I see it, if your a guest, your staying in their room, better bring a bottle, unless it's a lady of course.
Rob - At least you learned about the car at the race. I'll definately keep your comments in mind when I get the #2 ready for putzing around with some foamies.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 03-29-2004, 03:54 PM   #2883
rc-zombies's Avatar
me no moocher...
mainly a weekend resident...
Old 03-29-2004, 03:57 PM   #2884
Coxy's Avatar
R/C Tech Charter Subscriber
Default Set-Up
Question about the Pro 4 Set-up guides in the Manual.
How can MORE castor give you more turn in and less exit steering
Coxy.
Coxy is offline   Reply With Quote
Old 03-29-2004, 04:05 PM   #2885
just my opinion...more caster gives more camber change when the car settles in...therefore it would give more steering. Some people see it different but this is what I have seen on the track.
James Nguyen is offline   Reply With Quote
Old 03-29-2004, 04:08 PM   #2886
Super Steve's Avatar
Send a message via AIM to Super Steve
OOOOO
gears in different polymers?
sounds interesting and let us know what you are up to!
Super Steve is offline   Reply With Quote
Old 03-29-2004, 04:14 PM   #2887
rc-zombies's Avatar
Default Re: Set-Up
Coxy.
having more caster does result in more initial steering..
the angle of the of the tires is greater when going into a turn..thus having more grip. the car tends to be more stable in the straights vs one with less caster...and the opposite is true..
less caster...more mid and exit speed... you'll have to tune to find that sweet spot...
my 2 yens...
Old 03-29-2004, 05:03 PM   #2888
Rob-Derek here. Glad to here it helped your car. I need to make my set a little shorter. I didn't try it there due to the lack of spare parts at this time. I used a front shock tower to make the extentions if anyone was wondering. At the nats, I was a victim of my own stupidity. I forgot to change my rear camber back to were it was in practice. I was running losi 1 degree hubs reversed in the rear. And those require a longer camber link. So with the camber change I had to run about 3 degrees of rear camber. Sounds like alot but it worked great. I went to 2 degrees and it spun out in everyother turn. Opps! My car was dialed before I got there and in practice but I changed TOO much stuff before the quailifiers.
I seen David Joors car and talked to him for a few minutes. I'm not sure the lower 3 mm chassis is needed. The upper deck did raise and eyebrow. If you do use a 3mm chassis I see 3d cutting is a high priority. The thickness of the chassis changes your roll centers and cg too much. 3d cutting will take care of that.
I too learned alot about the car this weekend. I have a few good ideas in the works for next season. But with our outdoor season 4-6 weeks away. I'll be getting ready for that.
Laser R/C Speedway
Adrian, Mi.
"Everyplace else is just a parking lot!"
Downforce is offline   Reply With Quote
Old 03-29-2004, 09:36 PM   #2889
Beeb's Avatar
Send a message via AIM to Beeb
Default Question
I just put together a diff for my front end and when I turn one side while holding the bevel gear it moves in steps. Like it has no resistance then a little then none etc...
Does this mean that the balls have flat sides on them? or maybe the D-discs have divots in them? or what?
I didn't feel this in the original diff that I put in my car so I'm curious if I've ruined the diff or something??
Thanks for any help.
Beeb is offline   Reply With Quote
Old 03-29-2004, 09:43 PM   #2890
RCGaryK's Avatar
Here's one of the happiest Pro 4 owners from the Nats...Great run in the main Teacher, you schooled them!
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 03-29-2004, 09:44 PM   #2891
Beeb's Avatar
Thank God there was a pro4 running in the mains.
Old 03-29-2004, 10:05 PM   #2892
Send a message via Yahoo to Doug Gaut
What springs will be the most commonly used for outdoor asphalt and concrete? We used to use white springs on the older rs4 cars.
Doug Gaut is offline   Reply With Quote
Old 03-29-2004, 11:08 PM   #2893
TeamPRP's Avatar
I don't think the .5mm will make too much of a difference. It's not as big of a change as rasing or lowering your hinge pin height on their own.
TeamPRP is offline   Reply With Quote
Old 03-29-2004, 11:09 PM   #2894
TeamPRP's Avatar
Default Re: Question
Originally posted by Beeb
I just put together a diff for my front end and when I turn one side while holding the bevel gear it moves in steps. Like it has no resistance then a little then none etc. . .
Your diff rings might not be fully seated. Does your diff look like it "wobbles" when you spin it?
Old 03-30-2004, 04:05 AM   #2895
The Teacher's Avatar
Trader Rating: 47 (100%+)
hehehehe....thanks for the pic RC Driver Gary it was nice meeting you.
The Teacher is offline   Reply With Quote
