Like Tree5Likes
Old 03-29-2004, 09:58 AM   #2866
kewdawg's Avatar
Originally posted by V12
http://www.rc-square.com/
Good lookin' out, V12! Thanks
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 03-29-2004, 10:10 AM   #2867
kewdawg's Avatar
TSR6,
are you running the stock spur with that spring set-up? If, you are, it seems you should definitely be running a much bigger pinion than what you quoted(closer to what i'm running).
Quinn Moon
Old 03-29-2004, 11:04 AM   #2868
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Originally posted by kewdawg
TSR6,
Nah, I buzzed my spur gear on one of my first runs. I had the motor loose and pegged the wall sideways.... BBbzzzzeeeewww!!! hehe...
I got a RW spur with the same teeth though, so yea, basically the same as stock. I know that it sounds low, but at S&N Trackside, it's not ( for me at least, I don't really keep track of what the other guys run ). I know the guy with a Cuda ( same internal ) is running a tooth more than me on his motors, but I'm not sure what spring/brushes he uses. I tried to pull his gearing, and I only come off the track WAAAY to hot, and it's doggy in the infield.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 03-29-2004, 12:06 PM   #2869
kewdawg's Avatar
TSR6,
is the layout tight with a lot of short straights? Are you running foam or rubber tires?
Quinn Moon
Old 03-29-2004, 12:08 PM   #2870
Trinity2's Avatar
Post
Hey guys. Last weekend i changes Speedtech`s ceramic bearings for my pro4 and check everything else in same time i saw something intresting.
Have you seen what is read about that stock delrin spurgear?
98- 64 XENON
Trinity2 is offline   Reply With Quote
Old 03-29-2004, 12:24 PM   #2871
rc-zombies's Avatar
98- 64 XENON
no...
what did you read...?
a link would be helpful.. for those who don't want to look...
Old 03-29-2004, 01:10 PM   #2872
RandyB's Avatar
oooo I hope its good
rw is the only spur for me
RandyB is offline   Reply With Quote
Old 03-29-2004, 01:36 PM   #2873
Default Broken Gears
I found a few different plastics to make these gears from that will not break. They also contain properties that will reduce friction.
Question is, do you really want this problem fixed? I ask this because in an accident, the energy needs to go somewhere. Given enough energy, something is going to break. As pointed out earlier, it will be a driveshaft, CVD, oneway bearing, or a gear. It seems to me that a gear is a lot less expensive than a new oneway assembly. But then on the other hand, which one can you break/bend and still finish a race with.
What is HPI going to do about the gears? Will they start making them from a stronger plastic or take the Tamiya approach of "just don't hit anything". Either way, I will probably continue with making these, even if it is just for a polymers exercise. Any thoughts on the subject (hopefully from HPI)?
Thanks,
Louis
BallisticHobbie is offline   Reply With Quote
Old 03-29-2004, 02:04 PM   #2874
tc3 never came with a front oneway neither did the losi so they basicaly have no problems
sportracer is offline   Reply With Quote
Old 03-29-2004, 02:11 PM   #2875
RCTech Member #2
TSR6's Avatar
TSR6,
Rubber tire on a layout much similar to THIS. It's changed every week, but it gives you a general idea of the track. Usually it's a within a pinion size larger or smaller compared to this layout.
Troy
RCTech Member #2
Old 03-29-2004, 03:05 PM   #2876
CraigH's Avatar
I can't imagine putting two kits together, my hand hurt for days after doing one.
CraigH is offline   Reply With Quote
Old 03-29-2004, 03:10 PM   #2877
RCTech Member #2
TSR6's Avatar
Yeah, I picked the first one up on I beleive a thursday, had it finished early friday morning, raced it tuesday, practiced thurs & friday, bought the second kit sat ( stole a gear out of it ) then built it on monday or tues.
By the time it was together, my hand was toast.
Troy
RCTech Member #2
Old 03-29-2004, 03:17 PM   #2878
rc-zombies's Avatar
you youngster make me joulous...
wait 'til you get married and have kids... you won't have time to build and race...
Enjoy it while you can....
the best part is.. father & son things.....racing picks up again when your kid is old enough to go the track and the wife can't complain like before....
Old 03-29-2004, 03:27 PM   #2879
RCTech Member #2
TSR6's Avatar
Yeah, It's all about the dorm life.
That weekend when I got the first kit, The biggest choice of the night was between building the kit, or partying. I built the kit.
Troy
RCTech Member #2
Old 03-29-2004, 03:34 PM   #2880
rc-zombies's Avatar
Ahhhh....dorm life...the good ol' days...
I would have partied... on second thought building the car is more fun... there's always a party going on....
had some great times in the dorms....
even though I was never an official resident...
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
